how to make a onboard welder for about $100 - JeepForum.com
post #1 of 15 Old 12-07-2010, 06:43 PM Thread Starter
mayeux
I just got done putting a welder on my Jeep for about $100. here is the price list (rounded to the nearest dollar)
Alternator-$45
2 wheel pulley-$9
belt-$8
jumper cables-$33
alternator bracket from junkyard-$5
I got a spare alternator for my jeep (if mine dies I can rewire the welder back to a alternator)
and took out the capacitor, exciter diode, and insulation screw from the brush, you have to do this because a alternator can produce plenty of power but these parts prevent it from producing to much for your vehicle but this is gonna be to weld not to run your jeep. then I put it back together and mounted a second alternator bracket on my wheelwell and put the "weldinator" in that bracket. I put a 2 wheel pulley on the alternator to run a belt to the weldinator. I then took some 4 gauge jumper cables and cut the clamps off one side and put on eyelet connectors to put on the positive and negative on the back of the weldinator. Also there are 2 prongs on the back of the weldinator, if looking at it from the back the one on the left needs a 12v power source you can wire it to the ACC box with a inline fuse (you need power to make power). I was told its about the same as a 200 amp welder but Im not sure, I know today I was able to cut a 1/16 plate in half with a 6013 rod. If yall want to look into this more I used these 2 webpages for most of my information. Also I know the video is not for a jeep but it shows how to wire everything up.
http://www.midwesternmedicalmachine....tor/index.html
http://www.youtube.com/watch?v=xQQJej8PbKs
mayeux is offline
post #2 of 15 Old 12-08-2010, 10:28 AM
CJhollic
1980 CJ7
Cool!
Weber 32/36 DGEV,
4" Suspension Lift , 1 " body lift
8000 lb Winch,
ViAir Onboard Air
TeamRush ignition upgrade with MSD 6a CDI
Dual Batteries
KC Daylighters
Cold Air Intake
Lock-Right Lockers
Yukon 1 piece axles
Custom Bumper& Swing Out Tire Carrier
Mile Marker Hubs
Chevy Blower Upgrade
1500 lb airbag suspension
Floor mounted gun rack (2 guns)
CJhollic is offline
post #3 of 15 Old 12-08-2010, 02:04 PM
SlikRic
Muddin Maniac
SlikRic's Avatar
1983 CJ7
Sounds sweet, have any Pics?
United States of America
Born: July 4, 1776
Died: Nov 4, 2008
SUICIDE
SlikRic is offline
post #4 of 15 Old 12-08-2010, 02:06 PM
Hussler
1992 XJ Cherokee
oPICS OR BAN!!!!!!!
Originally Posted by chris87xj View Post
Sometimes a restoration project is a labor of love, at which point cost, time, and labor involved become irrelevant.
Originally Posted by BorderC View Post
I see you also twizzled your scart lead. Well done! :thumbsup:
92 XJ with ARB's, 5" lift, too much armor, 33's and some other garbage
Hussler is offline
post #5 of 15 Old 12-08-2010, 02:36 PM Thread Starter
mayeux
no problem Ill run out to the garage and take some pics real quick
mayeux is offline
post #6 of 15 Old 12-08-2010, 02:52 PM
VACJ7
VACJ7's Avatar
Originally Posted by mayeux View Post
If yall want to look into this more I used these 2 webpages for most of my information. http://www.midwestern... http://www.youtube.co...
Your links are kinda jacked up.
VACJ7 is offline
post #7 of 15 Old 12-08-2010, 02:54 PM
CJ258
1974 CJ5
Would it be possible to set it up like an AC compressor using an electric clutch to power it up ? Just thinking out loud.
CJ258 is offline
post #8 of 15 Old 12-08-2010, 03:10 PM
LT1CJ7
LT1CJ7's Avatar
1983 CJ7
I think he meant:
On-Board Welder
And
YouTube - Trey's Onboard Welder
LT1CJ7 is offline
post #9 of 15 Old 12-08-2010, 03:16 PM Thread Starter
mayeux
OK I cant get the pics to upload here so I put them on photo bucket
http://s1209.photobucket.com/albums/cc382/mayeux1/
and heres the links from before...
I know the youtube video is not for a jeep but it explains how to wire everything up.
and
mayeux is offline
post #10 of 15 Old 12-08-2010, 03:19 PM
benullman
1981 CJ7
links dont work
Originally Posted by Gregg79CJ7304 View Post
Great minds think alike, but so do serial killers......Thanks.
benullman is offline
post #11 of 15 Old 12-08-2010, 03:47 PM
Unlimitedlou
Awesome idea. I wish you had more and better pics.
2005 Unlimited Rubicon, too much junk to list!-sold
2012 JKU Orange Crush
Unlimitedlou is offline
post #12 of 15 Old 12-08-2010, 07:43 PM
waterdowg
Cool. Got a few questions. What is the Alt bracket from? Also how do you remove the jumper cables when they are not be used for the welder. Last I noticed that your alternator is not hooked up. Is that just do to you not finishing or does it need to be unplugged during welder use.
waterdowg is offline
post #13 of 15 Old 12-08-2010, 07:49 PM
cjdogtoy
1976 CJ5
very cool and I hapen to have the stuff to do it!!
cjdogtoy is offline
post #14 of 15 Old 12-08-2010, 08:30 PM
lucdog
lucdog's Avatar
1980 CJ5
As I remember, Jeephammer had a post about onboard welders a while back. A quick search didn't help find it. If I remember correctly, he mounted the alt( a ford one) to the steel front fender with a fabed bracket and a turnbuckel to tighten the belt when welding is needed. I think the belt is just left off when not in use as a welder. Mabye someone can find the orignal post. Im probley not typing the correct words. I have glass front fenders, but, if a piece of square tube were welded to the frame in the correct position, that could be a starting point for a bracket.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #15 of 15 Old 12-08-2010, 10:45 PM Thread Starter
mayeux
I got the alt bracket from a postal jeep with a inline 6 I found in a junkyard, Its identical to the one holding on my alternator but instead of putting it on the engine I just put it on a metal plate and shaped the plate to fit the wheelwell. I remove the jumper cables when not in use, I wanted to do this as cheap as possible but eventually I will run leads from the welder to a box with connectors for real welding leads to connect to so all I will have to do is pop the hood, plug in the leads and flip the switch. You dont have to unplug the alternator you need the jeep to be running for this to work so your gonna need your alternator working, Also you control the power with the RPMs. Tommorrow I will take off the welder and take some pics of the bracket and TRY to clean up some wires so its a bit easier to look at and figure out.
mayeux is offline
Onboard Air wrongway92407 Jeep CJ Forum 88 10-26-2010 07:25 PM
onboard air gregric Jeep CJ Forum 7 05-25-2010 09:18 AM
york or gm type for onboard air? lotus Jeep CJ Forum 5 06-01-2008 02:07 PM
a/c compressor out of an 84 cj7? (onboard air) mmerlina Jeep CJ Forum 6 04-04-2008 11:54 PM
Onboard air backstrap Jeep CJ Forum 27 03-14-2007 04:33 AM
