Quantcast How to make a CJ flex? - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > How to make a CJ flex?
TJ 5.25" Speaker Adapters - NalinMFGFree Shipping on TIRES at KrawlOff-RoadGenuine Italian leather shift boots for your Jeep!
Old 01-16-2005, 04:06 PM   #1
2001svt
My cj doesn't flex...it tips. What can I do with my suspension to increase the flex? As attractive as a 4 link setup with coilovers sounds, I'm not rich. So what else is out there?
Need a new jeep...
2001svt is offline   Reply With Quote
Old 01-16-2005, 06:15 PM   #2
jeepskate
We kinda need to know what you have suspension-wise now...
jeepskate is offline   Reply With Quote
Old 01-16-2005, 06:31 PM   #3
2001svt
Just about 4-6" of suspension lift by way of superlift springs.
Need a new jeep...
Old 01-16-2005, 07:11 PM   #4
390fastback
Pull the sway bar out,it really inhibits flex. Second, make sure your shackles aren't biding. I have a 4" skyjacker soft ride in mine with one inch lift shackles (home made H style). and I can stuff oposite corners in the wheel wells while the other tires droop quite a bit. I think its a pretty good set up and works for me.
2000 Cherokee
68 Mustang Fastback (in progress)
71 Mach 1
68 Wildcat (also in progress)
68 International 1200 4x4
78 F150 4x4 400 4spd
390fastback is offline   Reply With Quote
Old 01-16-2005, 07:12 PM   #5
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
In order for a Jeep (or any vehicle for that matter) to flex, it's gotta have soft enough springs, long enough shackles, and long enough shocks. I suppose the first thing I would do is make sure the shackles aren't super tight. I like using a Nylock nut on my shackle bolts so I can just barely cinch them up without worrying about the nut coming loose. Next, I'd check the shocks for travel. Disconnect one shock and then use a jack or engine hoist to fully droop and then alternately compress that corner. At each extreme take a measurement and compare that to the shock to see if it's limiting travel (especially droop). Might want to check the front brake hoses to. Since it's already got a lift on it, make sure that the brake hoses aren't getting tight under droop. That stuff might help a little but honestly, it's all about springs... if those springs are stiff, there's not a whole lot you can do short of swapping them out for some flexier springs... and from what I've seen you get what you pay for. Funny you should mention cost of a 4 link.. FWIW I'm in the middle of doing that very swap on my CJ. As far as cost goes.. I'm in to it about $700 for a pair of 14" Fox coil over shocks and a half dozen different springs of various rates, $200 for 4 Johnny Joints, $50 for a set of Wrangler spring bushings (for axle side of links), and about $250 into the DOM tubing and various pieces of metal (had to order the DOM off the internet because I couldn't find it locally).
'80 CJ5 w/AMC360, T176, D44 w/Detroit 3.73s, RE 4" YJ lift and 35s..
Ground Pounder Fab
Lower 2
Guardrail
Down Schoolbus
Slickrock Tellico
Save
Crozet
More Crozet
BESRK is online now   Reply With Quote
Old 01-16-2005, 07:30 PM   #6
1973CJ5
Revolver shackles help quite a bit, put those on with some Rancho 5000 or 9000's and you should improve it dramatically. Also remove or add quick disconnects to the sway bar.
1973CJ5 is offline   Reply With Quote
Old 01-16-2005, 08:41 PM   #7
jeepskate
Let's call it 4" since Superlift doesn't make a 6" CJ lift. Do you have the Super-Ride springs or the Heavy Duty springs? The Heavy Duty ones won't flex much. Superlift uses the cheap 'bend-over' spring clamps...take a pry bar and pry the clamps open a bit. As others already said, disconnect the sway bar off road. What are you doing for shackles?
Old 01-16-2005, 08:49 PM   #8
2001svt
Thanks for all the input everyone. I'm not sure what springs I have beyond the brand since they were there when I bought the jeep. As far as shackles go, what ones should I get? If I wanted to replace my springs, what ones do you guys have good experiences with? I think I'm going to start over with new springs/shackles/shocks so I know what that I have what I need. That's a disadvantage to buying a modded jeep. I have to say that whoever built this one knew just enough to be dangerous. He should have his tools taken away. I've spent most of my time and money fixing everything he screwed up, so why should the suspension be any different? Thanks again.
Need a new jeep...
Old 01-16-2005, 10:59 PM   #9
jeepskate
Personally, I'd work with what you've got since most of the tweaks are free or cheap. Keep in mind that you're running 35's with a 4" lift, so you don't have a whole lotta flex room...I'm running about 5 1/2" with 35's with the 2 1/2" version of the springs that you have. I run greasable bushings all the way around and use slightly longer shackles with bolt in cross-braces. If you just want to pony up the cash & replace, arguably the best on the market is the Rubicon Express Extreme Duty 4 1/2" lift. It is about the most complete lift on the market.
Old 01-17-2005, 07:05 PM   #10
John C
My 2cent. I use a four inch leaf spring lift. I run 1.75" shackle lift, and I have a home-made 1.5" body lift. Long brake lines, long vent lines, long travel drive shafts, and double swaybar disconnects. I use skyjacker shocks made for the six inch lift monolinear leaf spring. I dropped down to 34" tires because I am able to stuff them so deep the 35's scrubbed at wheel lock. I lowered my front bumpstops about 1/2 inch to keep the shocks from bottoming out. (they are completley colapsed at this point) I can ramp 1031 with this set up and so far that has been fine for what I want to do. On a Note: besides the sway bar disconnects (no brainer) the longer shackles have made the biggest difference in my Jeep. I ramped just under 900 before adding them. And I also use greasable bushings.
BlueJeep
BLUE JEEP CLUB MEMBER #156
84' Caribean Blue Laredo w/ black leather interior
Frame off restore 6 years ago
7 inch lift w/ 34" TRXUS MT
DANA 44 front Solid axle converted Model 20 rear
AMC 360 / T-400 / Model 300 transfer case
SOLD
but never forgotten
If I can't hunt it, fish it, f**k it, or wheel it, I might not be that intrested in it
John C is offline   Reply With Quote
Old 01-17-2005, 07:08 PM   #11
Tri_X_Troll
1986 MJ Comanche
give it to me and buy a tj
Ryan- "I went from one crap-tastic drive train to another. At least the engine is the weak link this time"
Tri_X_Troll is offline   Reply With Quote
Glock Forum
