How to make amc 360 motorcraft carb stop running rich? - JeepForum.com
post #1 of 5 Old 04-08-2013, 08:26 AM Thread Starter
jeepdawg3
I have an 82 CJ7 with an AMC 360. It has the factory motorcraft carb. I have rebuilt carb and all adjustments seem correct. Still runs rich. Any ideas? Thanks.
jeepdawg3 is offline
post #2 of 5 Old 04-08-2013, 08:35 AM
revelc
1985 FSJ Wagoneer
By replacing it with a Holley
Wag Rebuilt 360, 260H, 727, Locked 44, AMC 20, 208, 31" M/T's, 4" Rustys, 2.5" Duals. SOON:SOA SF, 496, T400, Doubler, D60's, 37" M/T's <-TOY
Cherokee Rebuilt 360, 2" Duals, mostly stock. SOON: Hot Street 401, 4'' Rustys, 33" BFG A/T's maybe a T-case to get rid of Q-Track <-TOW RIG
revelc is offline
post #3 of 5 Old 04-08-2013, 08:36 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
When does it run rich, idle, partial throttle, WOT, or all of them?
Matt
Matt1981CJ7 is online now
post #4 of 5 Old 04-08-2013, 08:46 AM Thread Starter
jeepdawg3
Pretty much all of them. I have the mixture screws down to about one turn. It is better but still rich. I thought about replacing but from reading around the forums, these carbs get a pretty good rap.
post #5 of 5 Old 04-08-2013, 09:21 AM
Matt1981CJ7
1981 CJ7
I assume it's a MC 2150.
It could be a bad needle and seat, or misadjusted gas-soaked floats. When was the last rebuild on the carb?
Lastly, depending on the year of the engine, and what it came out of (a 360 wasn't a factory option for a CJ), the carb may be set up to have "controlled vacuum leaks". For example, a charcoal canister is a controlled leak because it doesn't hold vacuum. Therefore, the leak adds air to the A/F mixture, by design. If you, or a PO, disconnected and plugged this "controlled leak", the carb would run rich.
Hope this helps,
Matt
