How long will it take me? - JeepForum.com
post #1 of 13 Old 04-29-2010, 03:25 PM Thread Starter
JennetteJeep7
I am planning on redoing my 1984 cj7. i want to take the body off and keep it as a rolling chassis. all i am planning to do is grind the rust off the frame and repaint it so that it hopefully will not rust. and grind and paint any other major metal structures on the frame, then put the body back on. how long will it take me?
JennetteJeep7 is offline
post #2 of 13 Old 04-29-2010, 03:57 PM
neals80
1980 CJ7
until the money runs out,,,,only kidding,,,,you have a few weekends if work,,if steady and no cash flow issues and help from some friends....video what you can and mark every little detail..good luck post the pics
Neal Trombley
1980 CJ 7
SW FLORIDA
IF I WANTED A HUMMER I WOULD HAVE CALLED YOUR GIRLFRIEND!!
neals80 is offline
post #3 of 13 Old 04-29-2010, 06:06 PM
jeepskate
It'll take as long as it takes you with pit stops along the way to fix other stuff that you find...it's kinda like opening Pandora's Box. HackFab (he's on here sometimes) refers to it as MAW's (Might As Wells).
'86 CJ-7 Laredo: 4.2,T-999,D300,D30/D44,'94 YJ tub, full cage, Shrockworks rockers, OYR corners, AC,cruise,restored seats,3 tops,2.5" Superlift,F-T shackle reversal, RS9000x's,35" Dunlop Mud Rovers.
'83 Scrambler: time & money pit under construction with parts from CJ's,YJ's,TJ's,FSJ's,GM,Ford,IH,Honda,Toyota and a whole lotta aftermarket & custom stuff.
jeepskate is offline
post #4 of 13 Old 04-29-2010, 06:11 PM
SlikRic
Muddin Maniac
SlikRic's Avatar
1983 CJ7
A yr or 2
United States of America
Born: July 4, 1776
Died: Nov 4, 2008
SUICIDE
SlikRic is offline
post #5 of 13 Old 04-29-2010, 06:13 PM
Fatman
Fatman's Avatar
2008 CJ7
Forever plus two days.
Take lots of notes, pictures, and bag everything.
Click the yellow link in my sig ... "reassembly" that thread began ONE year after I started the frame off.
Thread Links:
Fatman is offline
post #6 of 13 Old 04-29-2010, 06:14 PM
crzdmnky
1978 CJ5
I would suggest buying everything up that you know it needs and having it sitting there when you start. That way you will be driven to get it all off and back on, and that way there is no wait inbetween. This way everything is fresh on your mind. my.02... I am one of the few people that can just say this is what I set to do, and just do the minimal. hehe
crzdmnky is offline
post #7 of 13 Old 04-29-2010, 06:14 PM
TRex
1979 CJ7
I did the same thing with my 79 CJ7. When planning my project, the best advice that was given to me by CertifiableJeep and that was this:
"It will take 2X as long as you think, cost 3X as much and take up 4X as much space.... you don't even want to know what the 5X and 6X are... but it relates to money either way"
I laughed at first and now I know it to be true. I've averaged about $3500 (including the price of the Jeep) a month for the past 4 months if that gives you any idea of the financial impact. an I've got at least another month to go.
1979 Jeep CJ7
Follow My Build Thread: http://www.jeepforum.com/forum/f8/1979-cj7-build-project-trex-935022/
TRex is offline
post #8 of 13 Old 04-29-2010, 06:19 PM Thread Starter
JennetteJeep7
wow thats a lot to take in. lol im hoping ot have most of the parts here before i start, and im really crossing my fingers that i dont find ant surprises when i get under there. i have lots planned and will take twice as many pics for everyone to see.
post #9 of 13 Old 04-29-2010, 07:17 PM
NelsonATC
1980 CJ7
I did just what you are looking to do. Started in December 2009 and the rig is being painted as we speak. Should be compete in a couple weeks. Did most of the work on weekends, averaged about 10 hrs/week. Budget was around $1500, but I am somewhere near $2500-3000. Stopped counting. The MAW's will kill your budget FAST!
Mike
1980 CJ7
NelsonATC is offline
post #10 of 13 Old 04-30-2010, 03:13 AM
RobsCrawlin7
no balls
RobsCrawlin7's Avatar
i know mine took about 2 weeks. I wound up needing quite a few new parts along the way and still its not perfect (tank fill lines dont line up etc) but its drivable.
'01 TJ 4.7/NV3550, 2" lift, 35's, locked.
'79 CJ7 stock, 304
'98 XJ sold
'79 CJ7 sold
'82 CJ7 parted
'89 MJ sold
SSG David Mejias, SSG Eric Vick, SGT William Bowling, SGT Robert McDowell
1 April 2007
Rest In Peace Brothers
RobsCrawlin7 is offline
post #11 of 13 Old 04-30-2010, 04:15 AM
HackFabrication
HackFabrication's Avatar
1976 CJ5
...how long will it take me?
Asking that is like asking how long it'll take to lose 50 pounds....
Conservatively (working eight hours max a day):
One day to remove body
One day to pressure wash, let dry, and start grinding/wire brushing/blasting
One day to finish up grinding/wire brushing/blasting (wear eye protection or factor in another day spent at the ER having the doc's pick steel out of your orbs)
One day to paint (POR-15 + top coat - wear old/disposable clothing and cover your hair)
One (or more) day(s) runnng around finding hardware/parts (that you've either broken or lost) and/or surfin' the net for it
Two days (or more) to reassemble, depending on how much repair, cleanup, and paint work you plan on doing to the rest of the CJ. Depending on what MAW's you've decided on.
EDIT:
Add One/two days to trouble shoot all the problems that will crop up after it's all back together
This is estimated for working by yourself, or having an occassional 'helper'. I would limit the number of 'helpers', unless they are familiar with CJ's, because you'll spend more time keeping an eye on them than you will working. Also, 'Helpers' tend to dissipate the longer a project takes.
To be honest, it'll be a rare situation if everything goes 'like clockwork'. Tearing down this 30 year old junk is a crap shoot at best, you are blessed IF you don't break something in the process. In that situation, Hack's Law will prevail: The parts broken the easiest, will be the most difficult, time consuming, and/or expensive to replace.
Good Luck.
"In the end...It's all Hack."
HackFabrication is offline
post #12 of 13 Old 05-02-2010, 01:23 PM
Hybrid Jeep
1976 CJ5
I had the same idea as you.. just take the body off to clean up underneath and put it right back on. HAHA.
Turned out I ended up taking literally ever bolt, screw, and connector of that Jeep apart. That was in August of 2007. Now the frame is done.. engine totally rebuilt.. axles done.. power disc brake front / rear conversion, trussed one piece axle in the rear.. etc.
I just got the body back from the media blasters and it's on to that phase of the rebuild.
Basically I thought I'd have the thing back together in a few months and now I'm going on 3 years!
Hybrid Jeep is offline
post #13 of 13 Old 05-02-2010, 02:03 PM
80cj
80cj's Avatar
1980 CJ5
Originally Posted by HackFabrication View Post
... Hack's Law will prevail: The parts broken the easiest, will be the most difficult, time consuming, and/or expensive to replace.
Good Luck.
Figure that Hack law and Murphy's Law will be working hand in hand. Whatever can go wrong will go wrong at the most inopportune time, etc....
80cj is offline
New 360 dipstick too long? NoNeck Jeep CJ Forum 2 08-15-2009 04:33 PM
long studs? allornothin Jeep CJ Forum 1 05-29-2009 08:25 PM
Any bets on how long this CJ8 ad will last? davemci Jeep CJ Forum 7 03-02-2009 05:25 PM
How long was the CJ-8 (Scrambler) around for? WILLY348 Jeep CJ Forum 10 08-28-2007 10:47 AM
ARRGH!!! Sorry got long... elkhuntrwinn Jeep CJ Forum 2 09-27-2005 02:46 PM
