How to install a Motorcraft 2100/2150 carb to replace the Carter/Rochester? - JeepForum.com
post #1 of 13 Old 07-13-2010, 03:21 PM Thread Starter
superjoe
superjoe's Avatar
I am looking for a detailed with pics write up for installing a Motorcraft 2100/2150 carb to replace the Carter/Rochester that came on the 258.
I have seen lots of sites and lots of write ups but does anyone one a REALLY good detailed write up in thier favorites or somthing that they could put up?
Joe Clark 210-639-0276
/l ,[____], 82 CJ 8 Scrambler Currently all stock but that will change.
l---L--0lllllll0-
()_) ()_)----)_)
superjoe is offline
post #2 of 13 Old 07-13-2010, 03:44 PM
walkerhoundvm
1981 CJ8
If you're patient, I can email you the write up that came with mine from the eBay seller. Have it at home, can't send now.
Take it for what it's worth, I didn't use it a bit. There is some information in this thread, though: http://www.jeepforum.com/forum/f8/ca...-help-1064615/
...that may help you sort out how to connect to the canister. If you've got an electric choke, the write-up may help, but I can't.
-N
walkerhoundvm is offline
post #3 of 13 Old 07-13-2010, 04:52 PM
Ken4444
Corripe Cervisiam
Ken4444's Avatar
MC2100 technical writeup with conversion procedure (PDF file):
http://street2mud.com/webfiles/MC-2100%20set%20up%20for%20a%20258.pdf
General discussion:
Motorcraft 2100 - Pirate4x4.Com Bulletin Board
In particular, this specific post has a good summary of the general hurdles and issues to overcome:
Pirate4x4.Com Bulletin Board - View Single Post - Motorcraft 2100
Another doc on the conversion procedure (another .pdf file). Not sure if this is the same as what's included in the first link:
http://files.meetup.com/633539/Installing%20the%20MotorCraft%20on%20a%20258.pdf
"I give you a republic, if you can keep it." - Benjamin Franklin
Ken4444 is offline
post #4 of 13 Old 07-13-2010, 05:48 PM
SparkyB
1988 FSJ Wagoneer
Those are the instructions from the ebay guy.
79 CJ5
88 Grand Wagoneer
SparkyB is offline
post #5 of 13 Old 07-13-2010, 06:15 PM
walkerhoundvm
1981 CJ8
I see I'm no longer needed here
post #6 of 13 Old 07-13-2010, 07:06 PM Thread Starter
superjoe
superjoe's Avatar
WOW thanks for the fast responses those PDF files are exactly what I was looking for thank you very much!!!
l---L--0lllllll0-
()_) ()_)----)_)
superjoe is offline
post #7 of 13 Old 07-13-2010, 07:57 PM
Ken4444
Corripe Cervisiam
Ken4444's Avatar
Glad to help. Last week I was convinced my Carter BBD rebuild project was hopeless, so I did a bunch of research on the MC2100 swap. Luckily I got the BBD working just fine so the MC2100 is on the back burner.
Ken4444 is offline
post #8 of 13 Old 07-14-2010, 10:46 AM Thread Starter
superjoe
superjoe's Avatar
well right now i am in the research stage right and just trying to figure out which way to go
Motorcraft 2100, Webber, or junkyard TBI? or if i want to try and to a 4.0 head swap and go MPFI.
right now i just need it to RUN and decently, it only gets driven about 1/2 to 1miles per day just driving from the house to the street where i park my commuter car, since it is not street legal yet i have a little time. I ordered a rebuild kit for the carter and will work on that when my dad (old race car nut) gets home from KS so he can help be make sure i get it adjusted properly.
Right now i am leaning toward the Motorcraft but still up in the air right now. I know that Weber makes a good product but like a holley they can be a pain to adjust. The Junkyard TBI sounds fun, but there is something to be said about sticking with a carb and cutting out as much electronics as possible. Now then there is the idea of the 4.0 head swap. This "sounds" great and all but i understand it can me a major PITA.
So, i dont know i guess i will just have to wait and see what i can find deals on.
Who knows maybe i will find my dream driveline and drop in a FI 5.0 with an auto tranny that i can mount my Dana 300 to? Hmmmm then go with 9" in the rear and a built D44 in the front :: but that is not likely to be in my budget anytime soon unless i just happen to win the lottery (but first i would have to play to win)
l---L--0lllllll0-
()_) ()_)----)_)
superjoe is offline
post #9 of 13 Old 07-14-2010, 11:01 AM
CJ8Extreme
1983 CJ7
I think you'll find the MC2100 the best choice for a "budget" carb. They are very forgiving with adjustments, gives the I-6 plenty of power, and it lets the jeep idle much better than the carter 2bbl. You can find the MC2100 in most junkyards for 20 bucks and the rebuild is extremely simple to do. Just my 2 cents though, goodluck with whatever you decide to do!
CJ8Extreme is offline
post #10 of 13 Old 07-14-2010, 11:25 AM
walkerhoundvm
1981 CJ8
If you really want to get rid of electronics, go with a manual choke. I love mine - it takes some practice to get right, and with changing outdoor temperatures it behaves differently, but has been really easy to get tuned with the MC.
-N
post #11 of 13 Old 08-23-2010, 07:50 PM
ppd1108
1978 CJ7
is there any way to convert to the 2100 from a single barrel carb setup?
ppd1108 is offline
post #12 of 13 Old 08-23-2010, 08:46 PM
zillla
1930 VJ
here's a link to instructions. At one time i found a great install article online. It was written by the guy in Colo Springs selling the conversions. But I can't find it now and I believe he may have taken it down.
How to install Motorcraft 2100 in 258 jeep (detail - Off-Road Forums & Discussion Groups
zillla is offline
post #13 of 13 Old 08-23-2010, 09:10 PM
ppd1108
1978 CJ7
I read that but it appears those instructions are for a two barrel carb conversion. The intake manifold I have is a single barrel carb.
ppd1108 is offline
304 Needs a Motorcraft 2150 carb Woolys_CJ7 Jeep CJ Forum 5 11-30-2009 12:21 PM
Motorcraft 2150 carb ID? Mike1084 Jeep CJ Forum 6 06-25-2009 10:44 AM
Motorcraft 2150 carb b1gbee Jeep CJ Forum 1 03-26-2009 05:14 PM
Motorcraft 2100 replace Carter YF 1 Barrel? jeepco Jeep CJ Forum 1 02-24-2007 08:22 PM
Motorcraft 2100/2150 Conversion ?'s for 232/258 Orange Juice Jeep CJ Forum 3 04-18-2005 01:53 PM
