How to install and adjust a 1998-1999 4.0 distributor? (CJ-7 MPFI upgrade) - JeepForum.com
post #1 of 2 Old 12-01-2011, 02:02 PM Thread Starter
Colt44
1983 CJ7
I know this is basic, but I haven't done this type of distributor before.
I'm moving from a hybrid EFI system that used the old CJ (Motorcraft) distributor to a new HESCO/MOPAR setup that uses the newer 98-99 type.
I'm familiar with installing the old type, setting the timing, etc. but the new one apparently only controls the injector timing. How should I install it, synch up with the #1 cylinder, etc.?
Most of the articles I've found talk about marking the position of the old one, etc. but obviously that is not possible here. I know it's probably a simple thing, I just need some instructions.
"We are all of us in the gutter...
Some of us are looking at the stars."
~ Oscar Wilde via Chrissie Hynde
Colt44 is offline
post #2 of 2 Old 12-01-2011, 03:19 PM
gmakra
Yes you should line it up with cylinder #1 spark plug tower which is at the 5 oclock postion on the distribtutor then pull the indexing pin on the the timining plate. Benny at Hesco should be able to help you if you have problems.
gmakra is offline
Timing and carb adjust after ignition upgrade... BuckleshootCJ5 Jeep CJ Forum 8 12-01-2011 08:48 AM
304 Distributor Upgrade 77-304-CJ5 Jeep CJ Forum 4 12-09-2010 01:21 PM
Cold Air Kit Install on CJ w MPFI fredrok Jeep CJ Forum 9 09-09-2010 09:50 AM
hei distributor upgrade for 258 chucksrustyjeep Jeep CJ Forum 20 08-06-2010 06:47 PM
HEI Distributor upgrade omfdcapt2 Jeep CJ Forum 9 03-02-2010 07:34 PM
