How to ID OEM unmolested CJ fenders? - JeepForum.com
post #1 of 8 Old 11-30-2011, 08:48 AM Thread Starter
Outnumbered
When I bought my CJ it had a perfect tub with no rust. But, the front fenders and hood have been repaired and don't line up well. I took measurements and have fount the frame to be solid and square with no repairs, rust, tweaks, or cracks.
However, the driver fender and driver side grill sits back about a 1/2 inch when measured from the front of the frame. It looks presentable but I want to start to hunt Craigslist for an unmolested set of fenders so that I can some day restore it.
So, any tips on what to look for?
Thanks in advance
1985 CJ7, 258, TF999, D300, D30, AMC20, 4.5" lift, 33" BFG's
Outnumbered is offline
post #2 of 8 Old 11-30-2011, 08:51 AM
Stumpbumper
factory paint colors on the inside! or under hinge and clamp areas!
1984 CJ7, 258..HEI..MC2100, T176/D300, D30/M20 lockers, lift, warn winch!
"When in doubt! Gas it out!"
Stumpbumper is offline
post #3 of 8 Old 11-30-2011, 09:02 AM Thread Starter
Outnumbered
Thanks, but mine has that (Jeep is original color red) but one fender is shorter than the other. It almost looks like it was welded together too short. I'll take some pics to show what I mean.
post #4 of 8 Old 11-30-2011, 09:48 AM
JeepHammer
Running On Empty...
1973 CJ5
I'm not sure what you are talking about, but here are some general guide lines...
HOLES HAVE TO BE SLOTTED. No fender fits EXACTLY from the factory...
The holes are punched in the metal BEFORE it's bent into fender shape, so you can't have EXACTLY located mounting holes...
I hate it, but it's a fact of life. Bending/Forming dies stretch & shrink metal in ways that are unpredictable, so the holes are virtually NEVER exactly where you want them...
Enter a burr for slotting the holes...
REMEMBER,
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
JeepHammer is offline
post #5 of 8 Old 11-30-2011, 10:05 AM
only in a jeep cj
The fast wY I can tell an aftermarket fender is to look at the rear most inner skirt. The oem fenders are formed smooth while the imports are rippled where the metal was forced into the curve. Also, the oem fenders will have more spot welds and have them closer together.
Ed
1975 CJ-6 1983 CJ-8
1986 CJ-7 Laredo 1986 TJ-7 Trail Jeep
2003 Inca Gold TJ Rubicon
only in a jeep cj is offline
post #6 of 8 Old 11-30-2011, 10:32 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Originally Posted by Outnumbered View Post
..... the driver fender and driver side grill sits back about a 1/2 inch when measured from the front of the frame....
Are you sure all the parts are original and genuine JEEP ? Are you sure the front of the frame is square and the frame rails are equal length ? Remember, you are dealing with 1960's automotive technology (even with an 1980's CJ). Back then, close enough, was close enough. Measure forward from the tub or the firewall and you will probably find it measures a little better. If all the parts fit snugly, nobody else will notice a 1/4" difference here or there.
CJ7-Tim is offline
post #7 of 8 Old 11-30-2011, 01:57 PM Thread Starter
Outnumbered
I think one fender is aftermarket. That makes sense and is probably why one looks to be welded differently where the seam is between the front and rear fender sections. When I get time I'll shoot some pictures.
The frame horns and frame are square and the top of the grill measures pretty square to the tub. The bottom of the grill is in 1/2 inch on the driver side or out 1/2 inch on the passenger but matches the fender OK. If I were to adjust the grill 1/2 inch it would be no where near matching the fender bolt holes even with slotted holes. I'm not sure which fender is "wrong"
post #8 of 8 Old 11-30-2011, 07:40 PM
keith460
Jeep. There's Only One
keith460's Avatar
Thickness of the gauge steel is another way of telling if it is OEM or aftermarket. Jeep OEM panels and tub are 18 gauge steel and most of the Taiwan panels are 20 gauge steel or 1mm thick since metric thickness is more common over there. If you take the front fenders off, you will be able to feel the weight difference between OEM and aftermarket.
1984 CJ-7 Renegade
keith460 is offline
Anyone running flat fenders or tube fenders on there CJ5? BamaLonghorn Jeep CJ Forum 14 10-18-2011 03:54 PM
Stock Fenders vs Flat Tubular Fenders ctappan94 Jeep CJ Forum 3 08-03-2011 12:51 AM
Making tube fenders out of 2 piece CJ5 fenders SonicR1 Jeep CJ Forum 1 02-14-2010 01:59 PM
Interesting unmolested CJ7 find... kconnor123 Jeep CJ Forum 47 06-18-2009 08:43 PM
CJ-6 Unmolested with no title kiowamtp Jeep CJ Forum 13 01-04-2005 09:42 AM
