How I made my Jeep more awesome - JeepForum.com
post #1 of 65 Old 11-05-2012, 10:08 PM Thread Starter
Dadamsnv
1977 CJ5
I made the jeep at least 130% cooler this week. I decided that since I can't fix all of the rattles and squeaks, I might as well fix em the old school way....
With MUSIC!
P.S. there will be a few posts with a lot a pictures and a little write up, so be patient while I copy and paste the info form my build thread.
I'm looking for a Scout II Dana 300. Drop me a line if you have any leads. Thanks
Dadamsnv is offline
post #2 of 65 Old 11-05-2012, 10:21 PM Thread Starter
Dadamsnv
1977 CJ5
Here is how I made the enclosures. I got the idea from one of the UTV forums in a search for economically price roll bar mounted speaker enclosures.
Start with 6" PVC end caps
Also start with some 3/16" MDF and put a poor mans compass centroid (screw) thoroughly it for making perfect circles.
Poor mans compass at work
First circle cut out with dremel router attachment and bit
Speaker mounting ring cut out and sanded to fit cap and speaker
Perfect fit
Perfect fit
Perfect fit (just happened that way)
Second ring before sanding
Caps sanded down for paint
Dadamsnv is offline
post #3 of 65 Old 11-05-2012, 10:24 PM Thread Starter
Dadamsnv
1977 CJ5
I JB welded the inside lip of the PVC cap and then set the caps on top of the rings an let the JB sag into place over night.
The rings fixed to the PVC
I used JBs sagging nature to glue the parts togeter
Silicon sealer to block all air leaks in JB weld
next is the clamp!
Dadamsnv is offline
post #4 of 65 Old 11-05-2012, 10:24 PM
85LaredoCJ7
Do you have a hook up at Kicker?
The Dude abides....
85LaredoCJ7 is offline
post #5 of 65 Old 11-05-2012, 10:36 PM Thread Starter
Dadamsnv
1977 CJ5
This how I made the theft resistant mounting brackets
First i started with two 2-3/4" exhaust clamps. I have 3" bars, so these had to be overbored slightly
More boring
Drill a 1/4" hole through the clamp to fit a 1/4" bolt like so
The 1/4" bolt ha to be grinded on a bit to fit
Next I cut out my antitheft tube
It also gets a centered 1/4" hole
It fits on the clamp like so
Now it needs two 5/8" holes...
...so it will clear the nuts. Once the clamp is tightened, this tube is put over the nuts and held in place by the speaker. At this point, it will be impossible to get to the nuts to loosen them.
Second clamp finished
Dadamsnv is offline
post #6 of 65 Old 11-05-2012, 10:43 PM Thread Starter
Dadamsnv
1977 CJ5
The caps provided all the squared up drill points I could want. This hole is 1/4" for the clamp mount...
...Like so
This hole is for wire exit
This handy pipe plug fits in the wire exit hole...
...like so
And the wire runs out of this hole. The wire loom should stuff right into this grommet and look really nice.
Wire grommet.
Next I will go over painting and install.
Dadamsnv is offline
post #7 of 65 Old 11-05-2012, 10:57 PM Thread Starter
Dadamsnv
1977 CJ5
Painting wasn't that great. It's so dusty and breezy in Nevada you have to paint indoors, but I have no way of doing that, so I just hope for calm days.
I thought sanding the caps down with 220 grit would be enough to make the paint stick, but I was wrong.
So they got sanded down for round two.
The metal bits turned out okay. I used VHT glossy roll bar paint covered in rustoleum clear coat for extra shine and UV protection. As I was painting them, they were basically lint rolling the atmosphere around them.
They turned out great despite all that.
Round two was much better. I had to pull hair and spider webs out of the wet paint as I was spraying them, which really pissed me off, but they don't look too bad. At least my roll bar looks worse
JB weld the grommet in place
Another shot of finished speaker box
And the finished clamp. Inked some parts zinc for some spicy flavor
Clamp mounted with antitheft tune
Dadamsnv is offline
post #8 of 65 Old 11-05-2012, 11:03 PM Thread Starter
Dadamsnv
1977 CJ5
Protected zinc nuts
Mounting holes for speaks. Notice just how close the fit was
I love the sound of airtight speaks, so I made a gasket to fit between the speak and the box. This called for the poor mans compass again.
Notice the finished gasket in the background
Perfect fit!
The last two are pics of the fully assembled box hanging in the jeep!
Dadamsnv is offline
post #9 of 65 Old 11-05-2012, 11:10 PM Thread Starter
Dadamsnv
1977 CJ5
it's time for pics of the final product! Some are duplicates, but now they have captions.
Notice the wireloom crawling along the roll bar
The wire looms meet here an travel along the passenger side where the tub folds over
Another glam shot
Pics with the new seats
Pointed slightly forward makes great stereo sound.
View from the back. Never mind the calendar girl.
All with $50 worth of materials, four days after work, and $100 kicker marine speakers. The brackets are theft resistant, and I used spanner screws (two hole security screws) for the speakers. This means unless someone has a #8 spanner driver on hand, the only way those speakers will come off is if they are removed by force. Which still may happen.
BTW, the speakers sound amazing! They hit 35 Hz. Sounds like a lie. I was skeptical at first, but with a 100% air tight enclosure, the sound quality easily doubled, and the sharpness is unimaginable! And they really do hit about 35 Hz. Plus they are waterproof!
Dadamsnv is offline
post #10 of 65 Old 11-05-2012, 11:17 PM
sjones26573
Nice! Seeing this inspired me to research wakeboard pods for my future cage. Found one I like, but at $1350, that's not happening. Maybe I can get the old man to upgrade the boat's speakers and steal the Nautique pods.
The Offroad Club @ NC State; Founder
The Yellowtail Build
Jeep-Owner.com
sjones26573 is offline
post #11 of 65 Old 11-05-2012, 11:19 PM Thread Starter
Dadamsnv
1977 CJ5
No sir, I paid full retail at Best Buy for those
Nice festive avatar haha!
Dadamsnv is offline
post #12 of 65 Old 11-05-2012, 11:22 PM Thread Starter
Dadamsnv
1977 CJ5
haha serious! After choking on a few crazy internet prices, the DIY wheel began churning. I saw some speak pods made with those flat PVC caps and figured I could do that pretty easy. I spent the most mental energy on the antitheft tube part of the design. The clamps and antitheft were all my creation.
Dadamsnv is offline
post #13 of 65 Old 11-05-2012, 11:34 PM
sjones26573
It is a nice DIY. Electrical/audio tends to be my favorite projects.
Jeep-Owner.com
post #14 of 65 Old 11-06-2012, 12:11 AM Thread Starter
Dadamsnv
1977 CJ5
Thanks man
Dadamsnv is offline
post #15 of 65 Old 11-06-2012, 12:28 AM
BagusJeep
1981 CJ7
At first I thought, oh dear some overpriced ICE applied to the poor CJ. Then I saw what you had done and my hat is off to you, nice work.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
