-   -   How I made my Jeep more awesome (http://www.jeepforum.com/forum/f8/how-i-made-my-jeep-more-awesome-1435240/)
Dadamsnv 11-05-2012 10:08 PM
3 Attachment(s)
I made the jeep at least 130% cooler this week. I decided that since I can't fix all of the rattles and squeaks, I might as well fix em the old school way....
With MUSIC!
P.S. there will be a few posts with a lot a pictures and a little write up, so be patient while I copy and paste the info form my build thread.
Dadamsnv 11-05-2012 10:21 PM
10 Attachment(s)
Here is how I made the enclosures. I got the idea from one of the UTV forums in a search for economically price roll bar mounted speaker enclosures.
Start with 6" PVC end caps
Attachment 502619
Also start with some 3/16" MDF and put a poor mans compass centroid (screw) thoroughly it for making perfect circles.
Attachment 502620
Poor mans compass at work
Attachment 502621
First circle cut out with dremel router attachment and bit
Attachment 502622
Speaker mounting ring cut out and sanded to fit cap and speaker
Attachment 502623
Perfect fit
Attachment 502624
Perfect fit
Attachment 502625
Perfect fit (just happened that way)
Attachment 502626
Second ring before sanding
Attachment 502627
Caps sanded down for paint
Attachment 502628
Dadamsnv 11-05-2012 10:24 PM
4 Attachment(s)
I JB welded the inside lip of the PVC cap and then set the caps on top of the rings an let the JB sag into place over night.
Attachment 502631
The rings fixed to the PVC
Attachment 502632
I used JBs sagging nature to glue the parts togeter
Attachment 502633
Silicon sealer to block all air leaks in JB weld
Attachment 502634
next is the clamp!
85LaredoCJ7 11-05-2012 10:24 PM
Do you have a hook up at Kicker?
Dadamsnv 11-05-2012 10:36 PM
10 Attachment(s)
This how I made the theft resistant mounting brackets
Attachment 502639
First i started with two 2-3/4" exhaust clamps. I have 3" bars, so these had to be overbored slightly
Attachment 502640
More boring
Attachment 502641
Drill a 1/4" hole through the clamp to fit a 1/4" bolt like so
Attachment 502642
The 1/4" bolt ha to be grinded on a bit to fit
Attachment 502643
Next I cut out my antitheft tube
Attachment 502644
It also gets a centered 1/4" hole
Attachment 502645
It fits on the clamp like so
Attachment 502646
Now it needs two 5/8" holes...
Attachment 502647
...so it will clear the nuts. Once the clamp is tightened, this tube is put over the nuts and held in place by the speaker. At this point, it will be impossible to get to the nuts to loosen them.
Attachment 502648
Second clamp finished
Dadamsnv 11-05-2012 10:43 PM
7 Attachment(s)
The caps provided all the squared up drill points I could want. This hole is 1/4" for the clamp mount...
Attachment 502651
...Like so
Attachment 502652
This hole is for wire exit
Attachment 502653
This handy pipe plug fits in the wire exit hole...
Attachment 502654
...like so
Attachment 502655
And the wire runs out of this hole. The wire loom should stuff right into this grommet and look really nice.
Attachment 502656
Wire grommet.
Attachment 502657
Next I will go over painting and install.
Dadamsnv 11-05-2012 10:57 PM
10 Attachment(s)
Painting wasn't that great. It's so dusty and breezy in Nevada you have to paint indoors, but I have no way of doing that, so I just hope for calm days.
Attachment 502660
I thought sanding the caps down with 220 grit would be enough to make the paint stick, but I was wrong.
Attachment 502661
So they got sanded down for round two.
Attachment 502662
Attachment 502663
Attachment 502664
The metal bits turned out okay. I used VHT glossy roll bar paint covered in rustoleum clear coat for extra shine and UV protection. As I was painting them, they were basically lint rolling the atmosphere around them.
They turned out great despite all that.
Attachment 502665
Round two was much better. I had to pull hair and spider webs out of the wet paint as I was spraying them, which really pissed me off, but they don't look too bad. At least my roll bar looks worse
Attachment 502666
JB weld the grommet in place
Attachment 502667
Another shot of finished speaker box
Attachment 502668
And the finished clamp. Inked some parts zinc for some spicy flavor
Attachment 502669
Clamp mounted with antitheft tune
Dadamsnv 11-05-2012 11:03 PM
7 Attachment(s)
Protected zinc nuts
Attachment 502670
Mounting holes for speaks. Notice just how close the fit was
Attachment 502671
I love the sound of airtight speaks, so I made a gasket to fit between the speak and the box. This called for the poor mans compass again.
Attachment 502672
Notice the finished gasket in the background
Attachment 502673
Perfect fit!
Attachment 502674
The last two are pics of the fully assembled box hanging in the jeep!
Attachment 502675
Attachment 502676
Dadamsnv 11-05-2012 11:10 PM
6 Attachment(s)
it's time for pics of the final product! Some are duplicates, but now they have captions.
Attachment 502685
Notice the wireloom crawling along the roll bar
Attachment 502681
The wire looms meet here an travel along the passenger side where the tub folds over
Attachment 502678
Another glam shot
Attachment 502679
Pics with the new seats
Attachment 502680
Pointed slightly forward makes great stereo sound.
Attachment 502682
View from the back. Never mind the calendar girl.
All with $50 worth of materials, four days after work, and $100 kicker marine speakers. The brackets are theft resistant, and I used spanner screws (two hole security screws) for the speakers. This means unless someone has a #8 spanner driver on hand, the only way those speakers will come off is if they are removed by force. Which still may happen.
BTW, the speakers sound amazing! They hit 35 Hz. Sounds like a lie. I was skeptical at first, but with a 100% air tight enclosure, the sound quality easily doubled, and the sharpness is unimaginable! And they really do hit about 35 Hz. Plus they are waterproof!
sjones26573 11-05-2012 11:17 PM
Nice! Seeing this inspired me to research wakeboard pods for my future cage. Found one I like, but at $1350, that's not happening. Maybe I can get the old man to upgrade the boat's speakers and steal the Nautique pods.
Dadamsnv 11-05-2012 11:19 PM
No sir, I paid full retail at Best Buy for those
Nice festive avatar haha!
Dadamsnv 11-05-2012 11:22 PM
haha serious! After choking on a few crazy internet prices, the DIY wheel began churning. I saw some speak pods made with those flat PVC caps and figured I could do that pretty easy. I spent the most mental energy on the antitheft tube part of the design. The clamps and antitheft were all my creation.
sjones26573 11-05-2012 11:34 PM
It is a nice DIY. Electrical/audio tends to be my favorite projects.
Dadamsnv 11-06-2012 12:11 AM
Thanks man :D
BagusJeep 11-06-2012 12:28 AM
At first I thought, oh dear some overpriced ICE applied to the poor CJ. Then I saw what you had done and my hat is off to you, nice work.
The time now is 01:48 PM.
