How To Hotwire A Jeep? - JeepForum.com
post #1 of 19 Old 11-24-2009, 01:18 AM Thread Starter
Blue84JeepCJ7
Blue84JeepCJ7's Avatar
My ignition switch is broke again. Maybe the slider. Is there a way to install a pushbutton switch by using the wires in the ignition switch? If so, which wires?
84 CJ-7
Chevy 350, Mild Cam. (325hp)
Summit (600 CFM) Carb.
1987 TH700R4 "K" Case
32x11.5x15 Cooper ATs
3" Body Lift
Be-Cool Radiator
Black Magic 175 Cooling Fan
Blue84JeepCJ7 is offline
post #2 of 19 Old 11-24-2009, 01:31 AM
billymac4511
autozone.
Duralast Ignition Switch.
12.99
problem solved
Webmaster and official do-gooder of interwebbish thinggies at
Also guilty for the plague, broken egg yolks and the spork.
billymac4511 is offline
post #3 of 19 Old 11-24-2009, 08:36 AM
ARJeepNerd
1981 CJ5
Hrm... On the ignition switch plug, there is a main supply wire. There should also be outgoing wires for the ignition power, acc power, etc. The blue outgoing wire should run to the starter solenoid. If I were you and I just flat out didn't worry about the Jeep being keyless (which is a long shot- what if a kid climbs in and flips the switch?), I would wire the ignition/acc/etc circuits to a switch fed by the main power supply. Switch on, ignition/truck live. Would have to be a HEAVY switch, be sure and check amp ratings and use proper connections. Then, I would mount a horn button on the dash with a supply wire from the acc circuit (hooked to main switch so that starter won't turn without ignition on) and the outgoing wire as the blue starter solenoid wire. That way, to start it up you just flip your toggle switch then press your button.
Does that make any sense? Feel free to try it, but again, fixing the factory lock cyl would be a safer option for anything but a dedicated farm truck.
Good luck!
ARJeepNerd is offline
post #4 of 19 Old 11-24-2009, 05:10 PM Thread Starter
Blue84JeepCJ7
Yeap, thats what I want. The push button will be under the dash not seen when sitting in the seat! My dad had one on his 1948 Willys Stationwagon. I'll give it a try!
I want to turn the key switch to the "on" position and then push a button to engage the starter.
84 CJ-7
3" Body Lift
Be-Cool Radiator
post #5 of 19 Old 11-24-2009, 07:10 PM
kercher
kercher's Avatar
That is how my willys is setup. Turn key on ignitioin, dash mounted push button. I really like it, except when I forget to turn the key and push the button and nothing happens. I usually panic for about 5 seconds.
kercher is offline
post #6 of 19 Old 11-25-2009, 09:53 AM Thread Starter
Blue84JeepCJ7
I got it. No problem. On the ignition switch I cut the blue starter wire and connected it to the pushbutton switch. Found a battery source directly from the battery and connected it to the switch.
Thanks for the photo for comparison John!
84 CJ-7
3" Body Lift
Be-Cool Radiator
post #7 of 19 Old 11-25-2009, 11:18 AM
Fatman
Fatman's Avatar
2008 CJ7
Originally Posted by Blue84JeepCJ7 View Post
... Found a battery source directly from the battery and connected it to the switch. ...
I'd be concerned that that switch could be activated with the ignition in the off position.
Thread Links:
Fatman is offline
post #8 of 19 Old 11-25-2009, 11:42 AM Thread Starter
Blue84JeepCJ7
It can be, but the engine wont start unless the ignition switch is on.
84 CJ-7
3" Body Lift
Be-Cool Radiator
post #9 of 19 Old 11-25-2009, 01:31 PM
Cutlass327
Cutlass327's Avatar
1978 CJ5
If it has to go thru the ignition switch anyways, why bother with the toggle/pushbuttons?? Over-complicating things that way? Other than hiding the toggle/button for security, but then you are just making it a hassle to drive.
Rick
Cutlass327 is offline
post #10 of 19 Old 11-25-2009, 03:22 PM
Fatman
Fatman's Avatar
2008 CJ7
Still. Bumping that starter button while in gear is a hazard. Not a risk I'd want while doing work on mine.
Thread Links:
Fatman is offline
post #11 of 19 Old 11-25-2009, 03:24 PM Thread Starter
Blue84JeepCJ7
If you think that is a hassle, please stay away from airplanes!
No, its not a hassle. The "slider" sucks and is "broke"...again! No more screwing with disassembling the steering wheel! THAT is a hassle!!!
I could make it like an airplane...probably like race cars too! Replace existing garbage with two solenoids. Install a Master Switch, Ignition switch, circuit breaker buss along with some accessory switches. But then again if I wanted an airplane....I would not have sold mine!
84 CJ-7
3" Body Lift
Be-Cool Radiator
post #12 of 19 Old 11-25-2009, 04:38 PM Thread Starter
Blue84JeepCJ7
Nope, gear shift safety switch prevents this.
84 CJ-7
3" Body Lift
Be-Cool Radiator
post #13 of 19 Old 11-26-2009, 01:14 AM
Cutlass327
Cutlass327's Avatar
1978 CJ5
Wow, CJs have starter safety switches?? Mine don't..
Rick
post #14 of 19 Old 11-26-2009, 08:05 AM Thread Starter
Blue84JeepCJ7
Mine does, B&M Ratchet Shifter that I welded up to make a normal shifter cause I ain't got no mo $$$$ to get a Lokar....lol
84 CJ-7
3" Body Lift
Be-Cool Radiator
post #15 of 19 Old 11-26-2009, 09:00 AM
JeepHammer
Running On Empty...
1973 CJ5
LUBRICATION!
Correct alignment and lubrication will keep that switch working 20 years or so with NO maintinance.
If you put in a 'Steal Me' switch, then you are asking for bad things to happen.
REMEMBER,
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
JeepHammer is offline
Neew to hotwire or something 85 CJ-7. Lost key. everfine Jeep CJ Forum 9 06-17-2009 01:19 PM
Jeep Turning Radius (Jeep Turns To The LEFT Great, Not So Much To The RIGHT) Military Jeeper Jeep CJ Forum 8 02-27-2008 11:08 AM
Can you 'hotwire' a CJ... and who wants to play find my electrical problem? part.changer Jeep CJ Forum 25 02-11-2008 10:03 PM
hotwire how-to 90xj4x4 Jeep CJ Forum 6 02-26-2004 05:24 PM
