How hard is a disc brake conversion? - JeepForum.com
post #1 of 6 Old 04-06-2006, 06:22 PM Thread Starter
imtheant
Looking to flip my 83' CJ7 from drum to disc brakes in the front. Is this a weekend, fairly easy project or should I expect a lot more in the way of problems. Any pointers ?
1983 CJ7 - Project "Surf Jeep Restoration"
imtheant is offline
post #2 of 6 Old 04-06-2006, 08:06 PM
PrimerFJ40
Depends! What axles, have you ever pulled your axle shafts before, do you have experience with bleeding brake systems and are you changing master cylinder, proportioning valve etc.
I did one on a Dana 44 out of a scout and the biggest problem I had was getting the hydroboost system I installed at the same time, dialed in. The actual install of the brackets, rotors and calipers is pretty straight forward. I had to grind down some spacers to get the calipers to run true over the rotors. I have heard some guys having a hard time getting the cadillac calipers to bleed properly, but I did not run into that problem, fortunately.
PrimerFJ40 is offline
post #3 of 6 Old 04-06-2006, 10:45 PM
dcarlton
Had a rather hard time with mine (76 CJ7). I even used a whole axle form another CJ, so all I had to bolt on were the outers, mc/booster and new P valve.
After new brake lines and wheels (since the discs were too big for the old ones), I had to bleed the system 5 times, and there is still air in the lines.
Very frustrating. If it is your daily driver, it will be a long weekend getting it back together.
dcarlton is offline
post #4 of 6 Old 04-07-2006, 08:34 AM Thread Starter
imtheant
yeah, i figured it wasnt a quick and easy conversion. how bout just adding one of the brake boosters to my drums instead? is that a easier solution? i'm getting ready to go from 32" to 35" and i'm a little worried in the braking department.
imtheant is offline
post #5 of 6 Old 04-07-2006, 09:09 AM
jlynch
If you have a stock model 30 jeep axle it is a very easy upgrade. You need the steering knuckles and all the outers off a model 30 disk brake axle.
92 Jeep wrangler/ Chevy 350/ sm465/ 205/ Dana 60/ Dana 70/ 4.56 gears/ detroit locker/
jlynch is offline
post #6 of 6 Old 04-08-2006, 06:31 PM
CJ51973
CJ51973's Avatar
Your Jeep should have had discs stock. Before you decide on how you need to figure out what has been swapped in. If its a drum 30 from like 72-77 then Chevy truck parts will work without swapping knuckles. Is it narrow track? Six bolt lock outs? If it still has the stock MC you shouldn't have to do anything there. Does it still have the proportioning valve?
Anything is possible if you don't know what you are talking about.
CJ51973 is offline
4 wheel disc brake conversion kit for my 81 cj7 JSCHAFER2233 Jeep CJ Forum 1 07-26-2009 11:05 AM
CJ disc brake conversion ? NCHornet Jeep CJ Forum 11 12-06-2007 07:47 PM
Drum To Disc Brake Conversion 68 Cj5 dstrebor Jeep CJ Forum 5 05-26-2007 12:37 AM
Disc brake conversion question Tractor Boy Jeep CJ Forum 1 03-28-2007 02:47 PM
Disc Brake conversion CJmadison Jeep CJ Forum 4 02-24-2006 03:14 PM
