How to get the ignition switch out?And plug on Steeringtube. - JeepForum.com
post #1 of 3 Old 09-11-2009, 05:52 PM Thread Starter
Intruder66
1961 CJ5
Hello,
in my Cj I have the column shifter( ca. from 1978). Now I can soon start with the new electrics, and so I had the idea to expand the original ignition switch. Instead of the original, I wish to mount the supplied EZ ignition switch. Is that possible?
Or is the shift lever then blocked??? It is now blocked without the key. If it is possible, how do I get the original ignition switch out ? And the other thing is, can someone tell me how the original plug on the Steeringtube evidence is? Possibly, a wire drawing wich wire are for Turn signals, horn, etc. on that plug there Thank you & greetings Mario
Intruder66 is offline
post #2 of 3 Old 09-14-2009, 08:43 AM
John Strenk
John Strenk's Avatar
1976 CJ5
Well the ignition switch is separate from the key lock. The switch is just bolted to the steering column and very easy to remove. The Lock is a little more difficult and you need a steering wheel puller and lock plate compressor to make it easy on yourself.
John Strenk is offline
post #3 of 3 Old 09-14-2009, 04:00 PM Thread Starter
Intruder66
1961 CJ5
Hello John Strenk,
perfect description. Many thanks, it can not be better.
Perfect, THX Mario
Ignition Switch bad??? Texas_CJ7 Jeep CJ Forum 8 12-01-2009 02:06 PM
Is this the right ignition switch plug? davemci Jeep CJ Forum 6 04-06-2009 10:46 AM
Bad Ignition Switch? chadcarter Jeep CJ Forum 1 11-10-2008 08:37 PM
HEI Ignition Plug Wires dreski1 Jeep CJ Forum 2 05-16-2005 10:21 PM
Ignition switch CJ Fanatic Jeep CJ Forum 0 07-10-2003 04:45 PM
