How to get a 258 running smooth with a weber - Page 5 - JeepForum.com
post #61 of 88 Old 05-12-2012, 08:07 PM Thread Starter
kovic
1983 CJ5
I don't think its a mechanical issue because I had it running pretty smooth before I ever even tried to get rid of the bog upon acceleration, then all these issues arose and here I am.... But I am not ruling anything out.... So I really appreciate your advice and I will try anything.
What worries me is the 1 1/4 out mixture screw..... thats the farthest in that it has ever had to be in...... I dont know why!!
Anyways Ill let you know how the team rush goes.
Thanks man
kovic is online now
post #62 of 88 Old 05-12-2012, 08:15 PM
86cj74.2L
86cj74.2L's Avatar
Next question
Was the bog lean or rich. They can both feel the same. But one will burn exhaust valves (especially if your egr is unhooked) and the other just wastes gas.
A lean bog will make the response to throttle feel spungy. Like a time delay.
A rich bog feels blubbery and more rough feeling. Like the engine is trying to clear its throat.
86cj74.2L is offline
post #63 of 88 Old 05-12-2012, 08:26 PM
mcmud
1983 CJ8
For the time being forget the vacuum tubes. Of course a layout will be provided should you get to the point you need one. Vacuum routing (other than vacuum advance)is not part of the issue at this point.
I'm not sure anyone read this as was intended.
If after a thorough check on these things are behind and he still experiences the stall he might try to eliminate that with opening the throttle plate to the point of reading 2-3" of vacuum at the "S" port, without re-adjustment to the mixture. It would at least tell us if this symptom is related to an air leak or a restricted flow.
Please allow me to emphasize DO NOT RE-ADJUST the mixture screw once the throttle plate has been opened to the point that you read 2-3"Hg at the "S" port nipple. The idle speed will be what it is, not a concern at this point.
In other words find what you consider a lean best setting while the throttle plate is closed to the maximum that it can be set and still read zero vacuum then open the plate and give it a trial run with attempts to create hesitation and stalls.
If you experience either symptom pull the advance tube at the distributor and plug that tube for the return trip and report how either run worked out for you.
If you still experience hesitation or stalling after both runs back the initial timing down to 6* up to 8*BTDC (max) and retry the tests.
mcmud is offline
post #64 of 88 Old 05-12-2012, 10:50 PM Thread Starter
kovic
1983 CJ5
Ok, will give this a go tomorrow. Now, do I do these tests with manifold vacuum or ported vacuum, or does it matter?
Thanks mcmud,86cj, and swatson.
kovic is online now
post #65 of 88 Old 05-13-2012, 12:27 PM Thread Starter
kovic
1983 CJ5
Was unable to do the test at the moment as I could not even achieve a noticeable good lean best idle, never got smooth and was mostly on the verge of dying.
kovic is online now
post #66 of 88 Old 05-13-2012, 02:52 PM Thread Starter
kovic
1983 CJ5
Ok, did the team rush. Was able to achieve a lean best idle at 1 1/4th turns out on the mixture screw, timing set to 8*. Drove it, still stalled. Turned the idle screw in until the S port read about 2-3 hg, then went and with two hard runs it did not stall on me. And the hesitation was not bad at all, almost non existent.
kovic is online now
post #67 of 88 Old 05-13-2012, 04:44 PM
mcmud
1983 CJ8
Which vacuum signal for advance was used with the first and last test...and did you make a run with neither?
mcmud is offline
post #68 of 88 Old 05-13-2012, 04:45 PM Thread Starter
kovic
1983 CJ5
Both manifold vac.
And no run with neither, I thought You only wanted me to try that if it still stalled after increasing the idle.
kovic is online now
post #69 of 88 Old 05-13-2012, 05:34 PM
mcmud
1983 CJ8
Originally Posted by kovic View Post
Both manifold vac.
And this lean best setting was performed while the manifold vac signal was plugged...right or wrong?
This is true, just wondering. Trying to pin point what mixture the carb is producing at that point immediately before and at the overrun.
How about one more trial if you will .
Without any further adjustment other than this time on ported vacuum and a completely warm engine of course.
mcmud is offline
post #70 of 88 Old 05-13-2012, 05:39 PM Thread Starter
kovic
1983 CJ5
I found the lean best while the vacuum advance was attached, not unplugged. I have it disconnected and plugged while I adjust the timing, then connect it, then find the lean best, is that wrong?
And for the next trial, dont adjust the timing at all when I switch to ported?
kovic is online now
post #71 of 88 Old 05-13-2012, 06:00 PM
mcmud
1983 CJ8
Originally Posted by mcmud View Post
Disconnect the vacuum advance tube and plug the source while adjusting the baseline settings.
Stalling at the stop is a clear indication of needing more fuel flow below the throttle plate. I suggest that you once more run through the lean best setting this time starting with the hot engine and the mixture screw preset at least 3 turns out, air filter in place and vacuum advance tube disconnected and plugged.
The lean best setting as well as the trial run results are invalid.
mcmud is offline
post #72 of 88 Old 05-13-2012, 06:10 PM Thread Starter
kovic
1983 CJ5
Ok, sorry. I will re-due them, but I cant have the mixture screw out 3 turns or the engine will not run.
I will report with the results when completed
kovic is online now
post #73 of 88 Old 05-13-2012, 06:54 PM Thread Starter
kovic
1983 CJ5
Run tests will have to wait till tomorrow, but I did go out and re adjust baseline setting with vacuum advance disconnected. With the timing set to 10* I found the lean best idle to be 1 1/2 turns out on the mixture screw. With 1 1/2 turns in on the idle screw and zero vacuum from S port.
kovic is online now
post #74 of 88 Old 05-14-2012, 05:03 PM Thread Starter
kovic
1983 CJ5
Ok, did the run tests. But When i got out there today i had to adjust the timing again, i put it to 8* and the mixture screw out 1 1/2 turns. Seems I have to re adjust everything every time I start the jeep up
Did the run tests, same results. Stalled, so I increased the idle till the S port read 2-3 hg then drove it and it did not stall, however watching the oil pressure I noticed it did dip.
Also, When it stalled on the first run test it took a moment for it to start back up and it chugged black smoke for a few seconds.
Another thing, Backing out of my drive, when I hit the breaks fairly quick the motor almost dies.....
kovic is online now
post #75 of 88 Old 05-14-2012, 05:12 PM
keith460
Jeep. There's Only One
keith460's Avatar
Do you have power brakes? Perhaps a vacuum leak internally within the brake booster itself and what may be causing your stalling problems.
What is manifold vacuum at idle? should be 17-22Hg with a steady idle without fluctuations. A steady vacuum under 8Hg is a vacuum leak of the brake booster or other vacuum lines.
1984 CJ-7 Renegade
keith460 is online now
Weber 38 still running rich jaminb Jeep CJ Forum 18 01-02-2016 02:26 PM
weber 2 bbl running terrible! bigbadge Jeep CJ Forum 3 07-08-2011 04:39 PM
81 cj7 amc 304 Got it running smooth what next? 81cjproject Jeep CJ Forum 7 01-07-2010 06:25 PM
Weber carb mod will not keep running petep1 Jeep CJ Forum 7 02-05-2009 04:28 PM
Weber 32/36 Running Rich CompGuru Jeep CJ Forum 13 08-28-2008 10:40 PM
