how to fix my bobblehead steering wheel - JeepForum.com
post #1 of 2 Old 01-10-2010, 01:23 AM Thread Starter
luapkb
do i have to replace my entire steering column, or the internal shaft, or is there a tilt column rebuild of some kind.
luapkb is offline
post #2 of 2 Old 01-10-2010, 01:42 AM
ChiliPepperTJ
ChiliPepperTJ's Avatar
There are 3 reverse torx head (I believe they are labeled as E-XX in sockets) screws that come loose in the tilt columns over time. My CJ's column was pretty bad when I got. Heres a good breakdown of a saginaw column, its from a buick but its the same as in CJ's. Now the one part where they take the outer housing off doesnt really need to be done. You can use a flashlight to look down into the column and get a socket in there with an extension. I did not use one of the E sockets I just used a regular one that fit it and it worked. Without tearing the whole column down you can only get to 2 of the 3 bolts but doing that is enough to tighten it up. I did that just to try it years ago, as I didnt have time to tear the whole column down and it is still nice and tight. Heres the link: Tilt Steering Column Wobble
Kevin
84 CJ-7 Renegade- 258,GM TBI w/ ESC, HEI, T-5, D300, D30, AMC 20 w/ trac loc and superior shafts, 2.5" BDS lift, 1" daystar BL, MORE shackles, Tie rod flip, 33" Swamper SSR's, Full cage, OBA, A to Z rocker guards, A to Z rear cage, Warn 9.5ti, Taurus fan, Herc'd tub, LED tail lights, Hand throttle, Hella Fogs, Hella headlight conversion, more to come...
02 WJ Limited, 4.7 H.O., RB1 Nav, DD and toddler hauler
Checkout my Junkyard TBI writeup:
ChiliPepperTJ is offline
How to straighten steering wheel after steering box install. SuperSportCJ Jeep CJ Forum 6 11-18-2009 02:57 PM
Replaced steering shaft-steering wheel 90 deg. out jshi218 Jeep CJ Forum 9 08-25-2009 08:39 PM
Steering wheel my73CJ Jeep CJ Forum 3 11-26-2008 12:34 PM
No Wheel/No Steal System for Grant Steering wheel Ridettu02 Jeep CJ Forum 12 11-11-2008 01:44 AM
Size of the nut for steering column to hold steering wheel supraman1990 Jeep CJ Forum 4 02-07-2008 07:16 PM
