How to find correct headight switch - JeepForum.com
post #1 of 3 Old 08-23-2017, 10:43 PM Thread Starter
carpesdiem
Hi,
Changing my headlight switch for 84 cj. My old one has threads all the way to base where it connects to the dash and is used by a nut to keep it attached to the dash. All new replacements have threads only at the top of the brass but are clean for about 1 inch after. Not sure what I am missing since I do not see how the new one will attach to my dash using that nut?
Thanks again
Jeeps and motorcycles..is there anything else?
carpesdiem is offline
post #2 of 3 Old 08-24-2017, 03:21 AM
ECJ-7
1976 CJ7
what is your problem? is the hole in your dash larger than the threaded end on the new switch?
ECJ-7 is offline
post #3 of 3 Old 08-24-2017, 04:09 AM
John Strenk
John Strenk's Avatar
1976 CJ5
Does it look like this?
This is what it should look like.
as ECJ-7 says that if the hole is to big then it will slip through the hole in the dash You might be able to put a thin washer behind it to hold it in the right position.
John Strenk is online now
