Quantcast How fast can a CJ-5 go?.... - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > How fast can a CJ-5 go?....
TJ 5.25" Speaker Adapters - NalinMFGSpartan Lockers FREE SHIPPING Excellent PricesRough Country Deals at JeepHut.com
Old 03-13-2009, 03:40 PM   #1
TravellinMan_15
1955 CJ5
its a 55 F-134 T-90 , and 5.38 axle gears
1955 CJ-5/ Maybe a 53 CJ-3b one day "If i leave hear tommorw would you still rember me?"
TravellinMan_15 is offline   Reply With Quote
Old 03-13-2009, 04:04 PM   #2
JoonHoss
1968 C101
with a little work, about 150 MPH (give or take)
http://www.jeepforum.com/forum/f8/project-cj-7-aka-worlds-fastest-jeep-pics-606064/
on a serious note, I'm guessing a tp speed of about 40-45, depending on tire size.
Hoss
It's hard to say no to yoo-hoo, the name literally beckons...
Don't mind me, I'm just another FNG around here...
JoonHoss is offline   Reply With Quote
Old 03-13-2009, 05:26 PM   #3
TravellinMan_15
1955 CJ5
realy 45 thats it can't i change the axle ratios or a overdrive?
Old 03-13-2009, 05:38 PM   #4
Lifesgoodhere
1989 XJ Cherokee
no you can go 55 w/o an overdrive, but the engine would be screaming in the mid 3000s
buy an overdrive and you can do 60 all day long, cause the rpms will only be in the mid to upper 2000s that's where those engines like to run.
1949 Jeep Truck; just needs paint
*My YouTube videos Subscribe!
*My Jeep Build Thread >>Epic project
Certified Jeep Expert, and Volvo Mechanic
Lifesgoodhere is offline   Reply With Quote
Old 03-13-2009, 05:40 PM   #5
TravellinMan_15
1955 CJ5
were can i get a od thanks
Old 03-13-2009, 05:41 PM   #6
TravellinMan_15
1955 CJ5
all i need is to do 55 and keep up with traffic, no highway!
Old 03-13-2009, 05:42 PM   #7
Lifesgoodhere
1989 XJ Cherokee
herm the overdrive guy...google it
or keep your eyes peeled for one that is used.
overdrive will run about $1000
Old 03-13-2009, 05:45 PM   #8
TravellinMan_15
1955 CJ5
no way 1000$ any alternitives
Old 03-13-2009, 05:49 PM   #9
Lifesgoodhere
1989 XJ Cherokee
an engine which has a higher RPM range instead of the f-head's 4,000 limit.
or
a bigger engine and lower numerical # gearing.
but
if you think about it, an overdrive is well worth it, because it is the cheapest way.
Old 03-13-2009, 05:51 PM   #10
TravellinMan_15
1955 CJ5
axle swap?
Old 03-13-2009, 06:00 PM   #11
Lifesgoodhere
1989 XJ Cherokee
it will become a SLUG without the 5.38 gearing
Old 03-13-2009, 06:01 PM   #12
TravellinMan_15
1955 CJ5
i thoght the 5.38 were the slowest.
Old 03-13-2009, 06:09 PM   #13
Lifesgoodhere
1989 XJ Cherokee
Or the engine, 72 HP and 115 ft/lbs or so, the 5.38 give the engine good acceleration, but you loose top speed, because that is limited by the engine's max RPMs.
if you put on 4.88 gears (for example) you will have a higher top speed, but the engine WILL NOT BE ABLE TO REACH IT because it does not have enough power. In other words with higher gearing, you might be able to reach 60 (without an overdrive) on a sunny day, with a tailwind, down a good sized hill.
Old 03-13-2009, 06:13 PM   #14
JeepHammer
Running On Empty...
1973 CJ5
About 120 MPH if you drop it out of an airplane.
JeepHammer is offline   Reply With Quote
Old 03-13-2009, 06:17 PM   #15
dkg4244
1997 XJ Cherokee
I can hit 60 in mine on a good day. I have the overdrive on it with 5.38 gears. Although it's about on the floor at anything over 50. Older CJ5's love 45 mph all day long. If you can I would definitely spring for an overdrive, I think they run about $800 or so from Herm. Check out hermtheoverdriveguy.com for prices
dkg4244 is offline   Reply With Quote
Glock Forum
