How far can you stretch the front and not move the steering box? - JeepForum.com
post #1 of 4 Old 09-08-2011, 10:54 AM Thread Starter
Chewtoy
1976 CJ5
Hey folks, I have been searching but I have not found a solid answer to this particular question. So I am throwing it out for general discussion.
I am working on going SOA on my '76 CJ5 using a Waggy 44 front and Rodeo 44 rear. The two spring choices seem to boil down to YJ rear springs with an extra main leaf for support or Waggy front springs with an extra main leaf for support. I do realize there are a bazillion other combinations, but these seem the be the common junk yard choices.
YJ springs are soft, give a good ride and are almost a straight bolt in.
Waggy springs are softer yet, and are supposed to ride better and flex better than the YJ springs. They are also offset allowing you to stretch (move) the axle about 2". Or you can turn them around and get 0 stretch but still have longer, softer springs, although you still have to move one end of the spring mounts to accomodate the longer spring.
I am going full high steer and can mount my tie rod and drag link in the stock "Y" pattern or both directly to the HS arms.
So here is my question. Can I move the front axle forward the 2" and not relocate the steering box or is that going to cause interference with steering components? Are the Waggy springs really that much better than the YJ springs that the effort is worth it?
Quite frankly I don't want to mess with swapping in a new steering shaft changing the hoses etc, I'll just stick with the YJ springs. But if I can get that extra little bit of performance for 0 cost, I'll take it.
Thanks for your patience durring this long question. My OCD getting the better of me and I am having a hard time making the decision without advice from you all.
With a great Jeep comes an empty wallet.
Chewtoy is offline
post #2 of 4 Old 09-08-2011, 11:27 AM
CSP
Depends on what pitman arm you use, the diameter of your draglink/tierod, steering arm length, etc.
With Waggie springs on my CJ adding 2" to the wheelbase my draglink was into the tierod in an inverted Y configuration with high steer arms and a Waggie pitman arm.
The easiest way to avoid this regardless of the variables is to use high steer arms that place the tierod behind the axle.
CSP is online now
post #3 of 4 Old 09-08-2011, 06:25 PM Thread Starter
Chewtoy
1976 CJ5
I was thinking of using my stock pitman or a waggy to keep it all in the same family. draglink and tierod came with the waggy axle.
For the high steer arms, I found the two following sites. Are there others? I suppose I can try to sell the HT arms I have already to cover part of the cost of the new ones.
http://www.harshterrain.com/parts/St...or_GM_10_Bolt/
http://rockstomper.com/catalog/steering/highsteer.htm
Chewtoy is offline
post #4 of 4 Old 09-08-2011, 07:44 PM
Fatman
Fatman's Avatar
2008 CJ7
If you're sticking a waggy up front you]re going to be outboarding the spring hangers and shackle mounts.
Add a 2x4 tube crossmember to the front, push the mounts forward 4" and weld in a new steering box mount out of 3/8. Pretty simple
I've been using the CJ pitman arm for these but this next project I'm running 7/8 heims w 3/4 inch bolts, don't think there is enough meat on the CJ pitman arm to drill it 3/4 so I'm looking at info on the Astro Van or 70's Camaro pitman arms
Thread Links:
Fatman is offline
Steering for 5" front stretch garretj64 Jeep CJ Forum 9 06-07-2011 08:05 AM
Used Steering Column Ignition on lock wheel won't move 4lowherewego Jeep CJ Forum 1 10-07-2010 11:20 AM
Dana 60 front stretch gbrew Jeep CJ Forum 0 05-24-2010 09:34 PM
How can I move front axle foward 1" yojeep79 Jeep CJ Forum 7 09-26-2009 01:57 PM
Anyone move front axle forward?? only in a jeep cj Jeep CJ Forum 1 06-24-2006 02:03 AM
