How does larger tires effect speedometer and odometer? - JeepForum.com
post #1 of 6 Old 05-28-2007, 08:18 AM Thread Starter
Lupulin
Hey guys. I've got a a set of 33 x 12.5's on my 81 cj7 jeep. How does this effect my speedometer and odometer readings? Do you have a conversion ratio? I would make me think that the speedometer and the odometer would read incorrectly - to the low side. Does anyone have the size of the factory tires?
81 CJ 7
Lupulin
Lupulin is offline
post #2 of 6 Old 05-28-2007, 09:27 AM
gosupes
The factory size was somewhere around 28". There are speedometer conversion tables all over that will give you an idea of how fast you are going by using RPM, tire size and gear ratio. The circumference of the larger tire is almost 18% more than the stock tires, so your gauge will read about 18% low.
It's just a Jeep, and if you don't wheel it once in a while, it's not even that.
gosupes is offline
post #3 of 6 Old 05-28-2007, 09:41 AM
Mr.Crowley
Mr.Crowley's Avatar
1980 CJ7
if you have a tranny with a 1-1 top gear no overdrive I'll be willing to bet your about 5-7 mph under the the actual peed your going..
so if your speedo's showing 45 your really going 50
1980 cj7 258 weber,5'' of lift,33'' boggers,lincoln locked,lockright and a snorkle...Khaki Jeep Club member No. 1
1984 cj8 350 on 35's..the wifes
Originally Posted by Me
"offroad it, and wave then you might understand"
BLS Home Chapter... Where it all Started
:hahaha: yj
My low Buck Rock Crawler project Project..Stop by and check it out..
Mr.Crowley is offline
post #4 of 6 Old 05-28-2007, 10:31 AM
Indy
Indy's Avatar
You can't do a straight assumption of speed. The error gets larger the faster you go, so you need to know the % and do the math. Or get a new speedo gear and call it good.
I'm the only gay eskimo.
Indy is offline
post #5 of 6 Old 05-28-2007, 01:45 PM
fatterman
fatterman's Avatar
http://www.jeeptech.com/javaAps/Speedo.html
this site will tell you what tooth count you need.
fatterman is offline
post #6 of 6 Old 05-28-2007, 02:50 PM
80cj
80cj's Avatar
1980 CJ5
Run your odometer against highway mileage markers. It will give you a good idea of how much you're off.
80cj is offline
How Far off is my Odometer/Speedometer? CherryCj7 Jeep CJ Forum 16 11-11-2009 08:17 PM
Effect of vacuum leak PaulS Jeep CJ Forum 3 06-05-2008 09:56 AM
81 CJ Speedometer/Odometer Lupulin Jeep CJ Forum 4 05-13-2007 03:22 PM
effect of tires on speed T-$$ Jeep CJ Forum 2 08-24-2006 07:17 AM
