Quantcast How do you separate steering box from steering shaft? - JeepForum.com
EGGERS BROS. INC YOUR JEEP SOURCE
CALL 1-800-274-2460
Competitive pricing!
Go Back JeepForum.com > Models > Jeep CJ Forum > How do you separate steering box from steering shaft?
Old 07-24-2008, 08:52 AM   #1
qwert98
Let me apologize in advance for making up terminology...
(I have an '86 CJ7)
My steering box started leaking PS fluid pretty bad from the seal between the box and the steering shaft. I got the steering box out EXCEPT for the shaft that is connected to it. I removed a clamp right in that area (around the shaft) - expecting it to release the steering box, but it didn't.
Does anyone know how to get the steering shaft out of the steering box? Once It's out, is there a rebuild kit, or a new seal that I could buy?
Thanks!!
qwert98 is offline   Reply With Quote
Old 07-24-2008, 09:00 AM   #2
bleoh
Are you talking about the shaft that connects the steering column to the steering box? If so it is a splined commection and the bolt that goes through the clamp goes through a little bit of a keyway. Once the bolt is fully removed then the issue is rust, etc.. holding it on. Try a good spray, like PB Blaster and give it plenty of time to soak.
bleoh is offline   Reply With Quote
Old 07-24-2008, 09:13 AM   #3
Ininkus
I took a wrench and put it between the two and pryed. Came off pretty easy, but you may be fighting more rust than I was.
That said though, I'm hoping I didn't cause any damage doing it this way... make sure it's not going to hurt anything before you do it.
1991 YJ, 2.5, Rough Country 2.5", 75k Miles, Bone Stock Everywhere Else!
1977 CJ5, 4.3 Chevrolet, Fiberglass Tub, 3.5" Lift, 31" Tires [SOLD]
Ininkus is offline   Reply With Quote
Old 07-24-2008, 12:12 PM   #4
qwert98
Yes, it's just the shaft that connects to the steering box. In this pic below, it would be facing you angled toward the left (if the shaft was still there).
So I just have to pry it off? Any idea if the seal leak can be ficed? It's leaking right at that area that the shaft attaches...
http://images.google.com/imgres?imgurl=http://i123.photobucket.com/albums/o306/keith460/84%2520Jeep%2520Project/Chasis35.jpg&imgrefurl=http://www.jeepsunlimited.com/forums/showthread.php%3Fp%3D7638871&h=600&w=800&sz=130&hl =en&start=34&um=1&tbnid=VvywQvDwHEsLBM:&tbnh=107&t bnw=143&prev=/images%3Fq%3Dcj7%2Bsteering%2Bbox%26start%3D20%26n dsp%3D20%26um%3D1%26hl%3Den%26sa%3DN
Old 07-24-2008, 03:51 PM   #5
smokedog
I just replaced mine for the same leak. About $160 at auto zone for a rebuilt box. Go ahead and replace it and be done with it.
I also agree use PB. I loosened the top as well and just grabbed with two hands from underneath and went ta pullin..... Mine was a PTA. Once you get it out clean the splines and spray some WD40 prior to re-install. Might make it a bit easier. Man a new box really makes a difference in the steering response.
Good luck
Smokedog - Brandon, MS
84' CJ7 Renegade - 258, Holley Carb, D.U.I. Distributor, K&N Intake system, T176, D300, SOA lift, YJ springs, Bilstein 5150 shocks, Currie Rock Crawler Shackles, 4.56 gears, Trussed Ford 9 Rear, Dana 44 Front, heavy duty steering, YJ Power Brakes, 3' body lift, 315/75/16 Buckshots, Pro Comp Series 99 16x10 wheels. Future Mods: 383 stroker, bedliner and paint.
smokedog is offline   Reply With Quote
Old 07-25-2008, 09:36 AM   #6
qwert98
Great! Thanks Smokedog!!!
Did you even look into rebuilding the seal? Probably not worth the hassle, but I'd like to say I looked into it...
Old 07-25-2008, 06:44 PM   #7
dreski1
I did purchase a seal kit from Napa. But if you are having trouble with rust holding the steering shaft in place, you will most certainly have MUCH more trouble disassembling the sector box. It requires some large wrenches to remove large nuts, and a small (oz-inches) torque wrench to preload the bearing once you replace the seals. That is the easy part.
The recirculating bearing come out very easy, but are bit of a trick to get back in, that is, once you finish chasing them around your shop floor a few dozen times.
Spend the $160 and get a new box with a warranty!!
____________________________________________
86 CJ w/ 91 YJ tub, V8 304, , HEI, T150, ACM20 w/ 33's. Chili Pepper Red.
dreski1 is offline   Reply With Quote
Old 07-26-2008, 11:23 AM   #8
smokedog
No, when it comes to steering I just thought since the part was relatively inexpensive might as well get a new one and tighten the steering up even though mine drove pretty good. It definately made it more responsive.
Glock Forum
