How do you pack a steering knuckle with grease? - JeepForum.com
post #1 of 13 Old 09-02-2007, 08:38 AM Thread Starter
part.changer
1976 CJ7
I'm waiting until it's too cold to ride to do some of the more major repairs on my Jeep, so, in the meantime, I need to lubricate heavily.
My steering knuckle (at the bottom of my steering shaft) leaks something onto the ground pretty consistently. Ultimately, I want to pull the entire assembly and repair it, but, for now, I just want to make sure it's got plenty of lubricant.
Where do I add lubricant and what type? Haynes punts saying go to a professional... wimply.
I can post pics if necessary, but I just want to keep it running until I can rebuild completely.
part.changer is offline
post #2 of 13 Old 09-02-2007, 02:42 PM Thread Starter
part.changer
1976 CJ7
Knucklehead?
post #3 of 13 Old 09-02-2007, 02:57 PM
StevenH
So your steering box is leaking?
StevenH is offline
post #4 of 13 Old 09-02-2007, 03:05 PM
hfjeff
hfjeff's Avatar
Where exactly are you talking about? Is it the bell shaped assembly at the end of the steering shaft that attaches to your steering gearbox? Or are you talking about the gearbox itself?
MINE: 1995 YJ/2.5L/115K/Completely Stock
MY DAD's: 1978 CJ7/ AMC 360 .030" over/ Motorcraft 2100/ Edelbrock Performer/ Proform HEI Ignition/ Hedman Headers with dual Flowmaster 40's/ Taurus Fan/ FK-35 Control/ Painless Harness/ Rebuilt T150 & Dana 20/ 4" Lift/ 31" Procomp Mud Terrains/ All Fiberglass. (SOLD)
MY BROTHER's: 1996 ZJ Limited/5.2L/117K & Completely Stock.(SOLD)
hfjeff is offline
post #5 of 13 Old 09-02-2007, 03:11 PM Thread Starter
part.changer
1976 CJ7
Hmm, I didn't know there were two different things down there. All I know is that there's something pooled at the bottom of my steering shaft every day.
Is there more than one place on the shaft/assemblies that that could be coming from? I'll take pictures if needed.
post #6 of 13 Old 09-02-2007, 05:40 PM
79cj7reny
1979 CJ7
BEtter post pics to be sure.
79cj7reny is offline
post #7 of 13 Old 09-02-2007, 08:56 PM
bigjoe
1977 CJ7
Post pics. Should help.
bigjoe is offline
post #8 of 13 Old 09-03-2007, 12:01 AM Thread Starter
part.changer
1976 CJ7
Pictures coming tomorrow.
post #9 of 13 Old 09-03-2007, 10:55 AM Thread Starter
part.changer
1976 CJ7
Here are the pictures. Make sure to maximize.
post #10 of 13 Old 09-03-2007, 11:09 AM
StevenH
That's power steering fluid, check the lines at the steering box and see if they leak or are loose. Check the line all the way to the pump, it could be running down on the box. The steering box could be leaking also, it's hard to tell with all of the power steering fluid there.
StevenH is offline
post #11 of 13 Old 09-03-2007, 11:18 AM Thread Starter
part.changer
1976 CJ7
Cool... so worst case scenario I'll just keep an eye on the power steering fluid level.
post #12 of 13 Old 09-03-2007, 11:42 AM
GPER
1979 CJ7
Here is a link on how to rebuild the power steering box.
http://www.pirate4x4.com/forum/showthread.php?t=570869
GPER is offline
post #13 of 13 Old 09-03-2007, 05:47 PM Thread Starter
part.changer
1976 CJ7
Thanks alot for that pirate link.
Steering Knuckle removal problem 2002fordgt Jeep CJ Forum 5 06-03-2009 11:38 PM
Will a high steer knuckle fix my steering problem? rivers edge Jeep CJ Forum 5 09-24-2007 09:23 AM
Dana 30 Steering Knuckle ball joint style kappa505 Jeep CJ Forum 0 12-21-2006 09:28 PM
Steering knuckle ball stud Indy Jeep CJ Forum 8 12-08-2006 03:53 PM
Steering knuckle swap..disk brakes CJ5 '75 T Hoff Jeep CJ Forum 0 02-19-2002 02:37 PM
