How do you adjust brake light switch? - JeepForum.com
post #1 of 12 Old 08-24-2011, 07:44 PM Thread Starter
HMS
I replaced my master cylinder today with one from Autozone due to leaking cap/top. Now my brake light won't go off. All I can figure is that that the shaft on the new was a little longer than the old one. Anyhow, does anyone know of an easy way to adjust the switch? I can hardly get my hand near the switch much less adjust it.
Thanks, Howard
1983 CJ7
HMS is offline
post #2 of 12 Old 08-24-2011, 08:08 PM
lucdog
lucdog's Avatar
1980 CJ5
The shaft was shorter, anyway, it helps to be a contortionist. I used a open end wrench, once the nut closest to the firewall is loose, I used one finger to turn them. Its a royal PITA.
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #3 of 12 Old 08-24-2011, 08:46 PM
mopar346
You may have pushed the switch up in the bracket when you were doing the install. The switch is threaded pr ribbed on the out side and it just pushes into a bracket and the "threads" hold it in place. To adjust have the brake pedal in the relaxed (ie foot off) position and reach in and push the switch in until it bottoms out. There is no real push back pressure on the switch so it doesn't need to be hard/solidly secured. again chances are when you were playing the the master cylinder rod you probably just pushed the pedal up far enough to move the switch, no biggy. At leadt this is how my 84 is so I feel sure your 83 is that way as well, and yes it is a PITA to reach.
Good luck.
Careful your character's showing
mopar346 is offline
post #4 of 12 Old 08-24-2011, 09:00 PM
lucdog
lucdog's Avatar
1980 CJ5
Good luck.
The one I just replaced uses 2 nuts. And it may be possible to bend the tab on the brake pedal a little.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
lucdog is offline
post #5 of 12 Old 08-24-2011, 09:05 PM Thread Starter
HMS
Thanks for the info. I take my Alieve in the morning before I contort myself out of shape.
Howard
HMS is offline
post #6 of 12 Old 08-24-2011, 09:13 PM
mopar346
Bill
Interesting, what year? Just learning Jeeps, and yes with the type that secures with nut you can adjust (read bend) the bracket for proper adjustment.
mopar346 is offline
post #7 of 12 Old 08-24-2011, 09:41 PM
lucdog
lucdog's Avatar
1980 CJ5
1980 CJ5 , the bracket can only be bent, approximately 0.125" to keep proper contact. IIRC the hanging pedal set I took from a 1995 YJ, was the same, 2 nuts, and my 1983 CJ 7 is the same as the 1980.
Good luck HMS.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
lucdog is offline
post #8 of 12 Old 08-25-2011, 03:52 AM
mopar346
That's strange, I moved mine last weekend when I was fixing the ignition cylinder rack & pinion (?gears behind the key). I reset it in the fashion mentioned above, it definitely had no retaining nuts. I am just beginning to learn Jeeps, so I ask questions. Mine is an 84 powersteering, non-tilt column, manual brakes with a T4 if that matters.
mopar346 is offline
post #9 of 12 Old 08-25-2011, 07:36 AM
lucdog
lucdog's Avatar
1980 CJ5
Just checked my 1984, it has the "slide" type you describe. So Im probaley mistaken on the 95YJ.
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
lucdog is offline
post #10 of 12 Old 04-22-2013, 12:09 PM
Armystrider
adjusting brake switch
just pull on switch a couple clicks or until it meets pedal
Armystrider is offline
post #11 of 12 Old 04-22-2013, 12:23 PM
John Strenk
John Strenk's Avatar
1976 CJ5
Good luck.
My 84 switch worked this way on my 76 brake pedal also. I updated the 76 harness to an 84 harness.
John Strenk is offline
post #12 of 12 Old 04-22-2013, 01:01 PM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Perfect....but only a year and a half too late for the OP.
Matt
Matt1981CJ7 is online now
'72 CJ5 brake light switch shank38242 Jeep CJ Forum 2 04-29-2009 05:14 PM
where is the brake light switch bobby0872r Jeep CJ Forum 5 03-10-2009 10:04 PM
Brake light switch/turn signal switch ivaskaj Jeep CJ Forum 19 07-31-2008 05:15 AM
brake light switch 82cjman Jeep CJ Forum 3 12-05-2007 10:10 AM
brake light switch jgoshow Jeep CJ Forum 5 07-23-2007 03:45 PM
