How do I test a 8274 winch motor? - JeepForum.com
post #1 of 8 Old 02-04-2012, 11:50 AM Thread Starter
*Thunder
1979 CJ7
I bought a used 8274 winch. I am in the process of rebuilding it, and realized I never checked the motor. It there an easy way to test that motor? I have no electrical leads right now. I was hoping I could connect it to a charger or jumper cables. Any help would be appreciated!
*Thunder is offline
post #2 of 8 Old 02-04-2012, 12:09 PM
LT1CJ7
LT1CJ7's Avatar
1983 CJ7
LT1CJ7 is offline
post #3 of 8 Old 02-04-2012, 12:23 PM Thread Starter
*Thunder
1979 CJ7
I've been through that write up, which is very helpful. Unfortunately I have most everything taken apart. Is there anyway to do a quick test on the motor itself, no solenoids connected? The motor is still connected to the housing.
*Thunder is offline
post #4 of 8 Old 02-04-2012, 12:47 PM
LT1CJ7
LT1CJ7's Avatar
1983 CJ7
Battery - jumper cables -neg to ground/motor body.
Pos. to in lug then pos. To out lug.
LT1CJ7 is offline
post #5 of 8 Old 02-04-2012, 01:15 PM Thread Starter
*Thunder
1979 CJ7
That's exactly what I needed.
Thanks!
*Thunder is offline
post #6 of 8 Old 02-04-2012, 04:28 PM
Trapshooter
Be sure to hang on tight when you apply the juice to that motor. They jump real nice from the torque. You don't want to drop that thing on your toe, it will leave a mark.
Good Luck...........
'86 CJ7, 258, Carter BBD, Nutter'ed, TeamRush'ed, T-18, Twin Sticked Dana 300, D30 Frt-Pwr Lok L/S-4.10, AMC 20 Rear-Mosers-Detroit Locker-4.10, 2.5 BDS Lift, 1" Body Lift, 33" Wild Country M/Ts, Black Spoke wheels
'45 CJ2A, L134 Go Devil, T-90 Tranny, Warn O/D, T-18 T-Case, Dana 25 Frt, Dana 41 Rear, 531st CJ made
My 401 build:
Trapshooter is offline
post #7 of 8 Old 02-04-2012, 05:36 PM Thread Starter
*Thunder
1979 CJ7
Gotcha. Thanks for the warning!
*Thunder is offline
post #8 of 8 Old 02-04-2012, 07:29 PM
JWMII
1978 CJ7
You can check it out with Volt ohm meter. It'll do everything you need to do to ensure it is good including checking for shorted coils,(field and com),opens including the armature and you will know if it is any good without having to put power to it and run it. The manufacturer can give you the electrical spec or better yet they might be here in this forum if you search.Jack.
JWMII is offline
S vs I terminal on winch solenoid 8274 arkiemurph Jeep CJ Forum 7 01-19-2012 07:59 PM
8274 winch brake not holding joes1982CJ Jeep CJ Forum 5 02-25-2010 08:15 AM
OEM jeep 8274 winch joes1982CJ Jeep CJ Forum 12 10-11-2009 04:44 PM
8274 Winch Plate Help... poppatello Jeep CJ Forum 5 02-08-2009 11:50 AM
warn winch 8274 sierra1boy Jeep CJ Forum 7 01-05-2006 07:28 AM
