How do I swap out windshield wiper motor on 1984 CJ7 - JeepForum.com
post #1 of 6 Old 11-16-2011, 09:38 AM Thread Starter
myovino
1983 CJ7
Windshield Wiper Motor Swap Out 1983 CJ7
My windshield wiper motor would not return to proper resting position when turned off and the intermittent wiper would not work either so I decided to replace the motor. To replace the motor you will need to lower the windshield to access the wiper motor. Remove the three torx head screws that secure the motor to the windshield frame and remove the wiring clip. You will also need to remove the two black plastic access covers at the base of the windshield frame to access the linkage(good time to lubricate the linkage). Remove the clip from the linkage where the first access opening is located closest to drivers side and slide the motor and linkage out. You will need to disconnect the wiring harness from below the dash to remove entirely. Remove the clip that attaches the linkage to the motor and re-install on the new wiper motor. Install the new wiper motor in the same steps, only reversed of course. Put everything back in the same position that it was removed to prevent the wipers from not working properly.
myovino is offline
post #2 of 6 Old 11-16-2012, 12:13 PM
Field
"You will need to disconnect the wiring harness from below the dash to remove entirely"
i get to this part and cannot find the wiring harness. did you have to remove the dash at all or is this something i should be able to find by scrunching under the dash. is there any markings to help find the correct harness? there is a mess of wires under my dash and i cannot seem to find what to disconnect. any more detail on this would be helpful.
thanks
Field is offline
post #3 of 6 Old 11-16-2012, 01:14 PM
lucdog
lucdog's Avatar
1980 CJ5
I've always been able to pull the connector up thru the hole in the cowl.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #4 of 6 Old 11-16-2012, 01:22 PM
BubbaK
1983 CJ7
You have an intermittent speed on your motor??
'83 CJ-7_258 I-6_T-4_D300_AMC20/D30_Bone Stock
BubbaK is offline
post #5 of 6 Old 12-03-2012, 11:00 AM
Field
yes i have an intermittent speed on my motor
Field is offline
post #6 of 6 Old 12-03-2012, 02:27 PM
248107
Guest
1983 CJ7
Did you check the ciruit breaker that powers it for power.
248107 is offline
Windshield Wiper Motor Rollbar Jeep CJ Forum 2 02-05-2011 07:51 PM
Windshield Wiper Motor Rollbar Jeep CJ Forum 2 02-05-2011 05:03 PM
windshield wiper motor swap joewages Jeep CJ Forum 0 11-24-2006 02:57 PM
windshield wiper motor CJ7Dex Jeep CJ Forum 5 01-22-2006 08:13 PM
Windshield Wiper motor. cj5mudman4x4 Jeep CJ Forum 11 03-24-2003 07:56 PM
