How do I lower the windshield? - JeepForum.com
post #1 of 10 Old 10-18-2009, 02:47 PM Thread Starter
kcraw
After a search on here and google, I can't find any directions for lowering the windshield, which leads me to believe it's obvious. I removed the two hand bolts on either side of the windshield, but it didn't want to move. Is there something else I have to undo?
Thanks
kcraw is offline
post #2 of 10 Old 10-18-2009, 02:54 PM
Tumbleweed01
If you don't have any top hardware attached to the top of the windshield, those two bolts are all that holds it up. Cowl gasket is likely stuck and holding it. Just push gently at the top of the windshield frame forward.
Tumbleweed01 is offline
post #3 of 10 Old 10-18-2009, 03:47 PM
PERK
on the windshiel hinges, there is a small hole on top. wouldn't hurt to give them a squirt or two of wd40. gasket is stuck on cowl as stated above. put even pressure on each side of frame and slowly rock it. it will go.
PERK is offline
post #4 of 10 Old 10-18-2009, 04:29 PM
mmerlina
Image Glassworks, Inc.
mmerlina's Avatar
Please note that everyone is saying even pressure! The frame will easily twist and break the glass if you push too hard on one side.
Just go real slow and steady on the pressure.. I'd push at the top center to keep it from twisting.
Mike
1986 Jeep CJ7 (
Remanufactured 258, ARB lockers front & rear, 4.10 Yukon gears, 35x12.5" Super Swamper SSR's, Motorcraft 2100, 4.5" Rubicon Express Extreme-Duty lift, York 210 OBA, Big Daddy steering, Tatton rear CV driveshaft, Herculined interior, TJ flares, lots of body & upholstery work
mmerlina is offline
post #5 of 10 Old 10-18-2009, 04:54 PM Thread Starter
kcraw
Damn it. I just broke a hinge!
I did find some tweezer looking things under the windshield frame when I broke it. Still trying to figure that one out.
kcraw is offline
post #6 of 10 Old 10-18-2009, 07:46 PM
LibertyJeeper
Picture?
10char
Originally Posted by walkerhoundvm View Post
Just keep in mind: things are never as bad as they seem. These are jeeps, built by man and any problems you come across can be solved by man - even you! Best of luck.
Looking for axles 4.10's or higher
LibertyJeeper is offline
post #7 of 10 Old 10-18-2009, 07:50 PM Thread Starter
kcraw
Of the hinge or the tweezers? If it's the hinge, you're a sadist! . If it's the tweezers, literally they are some sort of grooming implement. Being a guy, I'm just gonna call them tweezers.
kcraw is offline
post #8 of 10 Old 10-18-2009, 08:14 PM
TBrock
I got here late. Was going to warn you to put PB or something like that in there.
Once you get your new hinges, remember to keep them lubed with oil (WD dries out).
Tweezers? 4:20?
Default Jeeper #68
MilitaryJeeper.com
TBrock is offline
post #9 of 10 Old 10-18-2009, 08:23 PM Thread Starter
kcraw
Tweezers? 4:20?
Haha! I bet you're right. Too bad it's just the tweezers.
kcraw is offline
post #10 of 10 Old 10-18-2009, 08:31 PM
TBrock
I bought an old firebird back when I was in the AF. I was working on it at the base auto hobby shop and found a big bag (had to be 2oz) up in the dash. They called the cops and the only thing saving my butt was that it was so old it was white! I think my heart actualy stopped when it fell out on the floor!
Now, any used car I buy, I have the cops run a drug dog through it.
Default Jeeper #68
MilitaryJeeper.com
TBrock is offline
Windshield to body lower seal install. cityjack Jeep CJ Forum 2 07-27-2009 08:47 AM
258 lower end advice. Patter Jeep CJ Forum 3 09-02-2008 04:24 PM
Windshield Compatibility - CJ7 windshield to replace a '76+ CJ5 frame? kbazurpe Jeep CJ Forum 3 08-30-2008 09:02 PM
Windshield seal - Will YJ windshield seal work on a CJ CJ83 Jeep CJ Forum 8 04-16-2008 03:29 PM
Lower Low on Dana 300? Aphelion79 Jeep CJ Forum 8 05-03-2005 06:52 PM
