Quantcast How do I fit 33's and not break the bank?!? - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > How do I fit 33's and not break the bank?!?
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineBLOWOUT SALE -- SYE Slip Yoke Eliminator Kits, NP231 TransNEW BOLT-ON Dash CB Mount 97-06 TJ Wranglers
Old 11-05-2008, 02:50 PM   #1
jeepfanatic
This is driving me crazy! I wanna know if it's possible to fit 33's under my CJ7 without spending a lot of cash? I've been told to fit 33's under it with spring over would require drive line work, brake hose lengths re-done, different steering components, etc.... I want max flex, and have been told this is easier with SOA set-ups. When it comes to SUA set-ups I've been told 4.5" min to fit 33's and most of those kit's require the same mods as an SOA, and I wont get the same flex. Is there a cheap way to build a CJ to run 33's and still get me over some rocks?
Spencer
jeepfanatic is offline   Reply With Quote
Old 11-05-2008, 02:54 PM   #2
Rezneck
Unregistered Shooter
Rezneck's Avatar
Well, sawzall makes it possible.
Throw the bums out!
48 CJ-2A, Bone stock except it has Allstate locking hubs.
86 CJ-7, 4.0 HO, AX-15, D-30, AMC-20
84 CJ-7, YJ tub and fenders, 258 ci, T-176, D-30, D-44 Trutracs F/R, 4.27s, 33s
77-90ish Wagoneer/TJ/CJ Yard Sale Special, 360AMC, TH400, Quadratrac, D-44s F/R, 3.07s, 34" LTBs.
Rezneck is offline   Reply With Quote
Old 11-05-2008, 03:05 PM   #3
jeepfanatic
I've thought about just cutting fenders up, but I still want some lift to go with that. I got some great ideas from some guys about fitting TJ flares on my rig, I still plan on running them in the rear. The front I don't wanna cut to much out of, but I'm not sure I like the TJ flares so I'm still in the air...
Spencer
Old 11-05-2008, 03:23 PM   #4
jeepfanatic
I was just looking at TJFANS thread and I'm looking for the same thing I just wanna know the best bang for the buck method... I'm not a fan of body lifts with this jeep do to the amount of rust in the body, I think a body lift would just be a major headache! LOL
Spencer
Old 11-05-2008, 03:32 PM   #5
Mike Romain
Off Road Forever
Location: Off the Grid in Chester Grant, Nova Scotia, Canada
I run 33x9.5 BFG mud's with a 2.5" OEM spring arch and replacement keeper spring with a further 1/2" lift from YJ shackles.
I have no issues as you may be able to see in my photo albums. Remember I am already there taking photos of the folks trying to get there....
Mike
86/00 CJ7 Laredo, 33x9.5 BFG AT's, 'glass nose to tail in '00, 'New' frame,wires and plumbing in '09. Carter BBD Carbed 4.0 HO in '10. Some Canadian Bush Jeep Runs and Build Photos: http://mikeromainjeeptrips.shutterfly.com (10 new albums added Sept 16/10)
Mike Romain is offline   Reply With Quote
Old 11-05-2008, 03:59 PM   #6
jeepskate
What do you consider 'a lot of cash'? You've gotta pay to play to some extent and what you lack in cash you'll have to make up for in knowledge and fabrication ability.
'86 CJ-7 Laredo: 4.2,T-999,D300,D30/D44,'94 YJ tub, full cage, Shrockworks rockers, OYR corners, AC,cruise,restored seats,3 tops,2.5" Superlift,F-T shackle reversal, RS9000x's,35" Dunlop Mud Rovers.
'83 Scrambler: time & money pit under construction with parts from CJ's,YJ's,TJ's,FSJ's,GM,Ford,IH,Honda,Toyota and a whole lotta aftermarket & custom stuff.
http://www.jeepskate.net
jeepskate is offline   Reply With Quote
Old 11-05-2008, 05:47 PM   #7
SuB8HaVeN
Yeh, it depends on what width of tire you want to run. If you get 33x9.5x15s, they tuck under your fender so you're not going to rub even with only a 1-2" lift. I ran some BFG AT 33x9.5s at one time with only a 2" lift, and they didn't rub at all, even in the front turned lock to lock. The 33x11.5 or wider will require a bit more lift in the 4" range.
1986 Jeep CJ7 4.2L I6 T176 (restoration in progress)
1961 Willys 4x4 Wagon L-226 I6 T90 (restoration also in progress)
SuB8HaVeN is offline   Reply With Quote
Old 11-05-2008, 05:51 PM   #8
Indy
Comp cuts/flat fender would be the cheapest method. I think I've got room for 35's with my cut cj5 and 1" ranch springs.
Never underestimate the power of stupid.
Indy is offline   Reply With Quote
Old 11-05-2008, 06:05 PM   #9
John Strenk
What was I thinking
1976 CJ5
My 33's 12.5 stuff the wheel well on my cj5 with a setup like Mikes. But I have Narrow track axles also so if I went with wide tracks, they would rub a lot.
John Strenk is offline   Reply With Quote
Old 11-05-2008, 08:08 PM   #10
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
I'm running 33s with 4" YJ springs SUA. I just let the rear tires "self-clearance" the fenders...
'80 CJ5 w/AMC360, T176, D44 w/Detroit 3.73s, RE 4" YJ lift and 35s..
Ground Pounder Fab
Lower 2
Guardrail
Down Schoolbus
Slickrock Tellico
Save
Crozet
More Crozet
BESRK is offline   Reply With Quote
Old 11-06-2008, 08:36 AM   #11
Redmanchew
aka Mike
Redmanchew's Avatar
1982 CJ7
I have 2.5 RC lift and a little, meaning whatever WP warrior is on thier HD shackles, i think 3/4 tops. I'm running 33x10.5 on 8" rims with 4" Back space stock pittman arm.. I leave my sway bar hooked up on the trail so the front dose not hit anything and i need to do a little trim on the back flares beacuse under full stuff i catch the body. But that could be done with a set of YJ/TJ flares if you wanted and not have to worry. As far as brake lines if yours are more then 10 years old might as well replace them and go for a little longer ones... Nothing says pucker like going down a steep hill on the trail and having a brake line explode.
This will also defer some of your "lift cost" to the "brake improvement" ledger and make it more acceptable to the accountant since the "brake improvment" ledger has a big red "SAFTEY" on the front and the "Lift" ledger has "Fun" on it.
1982 CJ-7 2003 4.3 chevy vortec, 4L60E, Clocked Dana 300 33x10.5x15 BGF TA KO on Crome Modular rims. Vanco Brake Booster. Power steering conversion. Warn front and rear bumpers with swing away. Moser 1 piece rears. Rear OX.
Support your local MS foundation. You don't know how much this disease sucks until it affects someone you love.
http://main.nationalmssociety.org/site/TR/Walk/VABWalkEvents?px=6419856&pg=personal&fr_id=18331
Originally Posted by twoleos617 View Post
To reiterate for the 1,067th time, when towing...
remove rear axle, xfer in N, trans in 5th, remove neg batt cable, key to Run and go??
Redmanchew is offline   Reply With Quote
Old 11-06-2008, 09:22 AM   #12
PavementPounder
Cool as Ice...
PavementPounder's Avatar
SOA for 33's is overkill.
4" SUA springs and a small shackle lift or a 1" (max) body lift should be fine. Just don't buy AAL's, or a crappy brand of lift. BDS or RE will ususally come in over the advertised height, too.
This is how NAXJA Midwest Chapter elected officials like to treat their resident users and former multi-year supporters.
<--- Click "Classifieds" under my avatar to see all my parts (mostly CJ & XJ) currently for sale on JeepForum!
PavementPounder is offline   Reply With Quote
Old 11-06-2008, 05:22 PM   #13
Rob55
I purchased my rig with a 2.5" RE lift and a 1" body lift running 32" tires and never had a problem. Currently running 35" tires with a 4.5" RE lift and a 1" body lift, with no problems (I have to admit I don't work the suspension as hard as some might though - I do the Rubicon once a year and that is probably the hardest wheeling I do). But one more thing to consider is the additional weight you are building into the rig. I have added close to 1000lbs with bumpers, spare, winch, cage, sliders, skids, extra fuel, etc and as I measured the "sag" I lost (clearance) about 1" in the rear, 1.5" in the front from before adding stuff. Hope that helps.
1984 CJ7, 258, MPI, 4.0 head, Borla, 700r4, amc20 (detroit), Dana 30 (OX), 4.56 gears, Warn Hubs, Dana 300 with 4:1, 4.5 RE lift with 1" body, Bilsteins, dual battery, PS, PB, full cage, two dogs in the back....
Rob55 is offline   Reply With Quote
Old 11-06-2008, 05:29 PM   #14
01TJCRAWLER
teraflex 2" lift....springs,shocks,quick disconnects and the bump stops extensions that came with the kit. 33/12.50/15 maxxis bighorns and they will stuff all day long with about 1/4" clearance @ the bottom of the wheel flare and drop all the way out till the spring comes unseated about 1"from it's pad.
not bad if you ask me for a $600.00 complete lift kit.
01TJCRAWLER is offline   Reply With Quote
Old 11-06-2008, 08:52 PM   #15
jeepfanatic
Does this require a longer drive shaft, and drop pitman?
Spencer
Glock Forum
