How do I Determine what model Transmission I have? - JeepForum.com
post #1 of 16 Old 12-21-2012, 06:57 AM Thread Starter
highred
1979 CJ7
I have a '79 CJ7 with a 258 I6. All I know is that the transmission is a 3 speed. How do I determine what model it is? I know nothing about transmissions but I would like to know the various types available to my year CJ. I want to learn more so I know what I have AND so I can service/repair it correctly when needed.
Is there a resource for learning more about CJ transmissions?
Thanks,
Rob Caldwell
highred is offline
post #2 of 16 Old 12-21-2012, 07:04 AM
VooDoo2
1978 CJ7
There isnt that many options. Is it Auto or manual? Do you have quadratrac?
VooDoo2 is offline
post #3 of 16 Old 12-21-2012, 07:30 AM
78FordF150
1983 CJ7
Factory three speed manual, is a T150.
Measure with a Micrometer
Cutter with an ax
Beat it to fit
Paint it to match
My NP435 install
78FordF150 is offline
post #4 of 16 Old 12-21-2012, 07:35 AM
shadoow
here's a link for good general information. Look under the 'Knowledge' section on the left side then browse the manual transmissions to see what's available for your year jeep. There's good info on how to identify what trans you have.
http://www.novak-adapt.com/about/history.htm
another way is to decode your VIN, assuming your trans is original to your jeep. Just do a search on this forum for VIN coding.
shadoow is offline
post #5 of 16 Old 12-21-2012, 08:11 AM Thread Starter
highred
1979 CJ7
It's a manual. What's a "Quadratrac"?
It looks like some other may have answered my question. Thanks.
highred is offline
post #6 of 16 Old 12-21-2012, 08:31 AM
82JeepCJ7
1982 CJ7
Autos commonly had the quadracrap transfercase after them. You can spot them easily by the offset rear axle, and a knob on the dash along with about 2 miles of leaky vacuum hose.
Beat it to fit, paint it to match!
Wheel, Wrench, Repeat.
82JeepCJ7 is offline
post #7 of 16 Old 12-21-2012, 08:37 AM
CSP
Only '76-79 CJ7s with automatics had the Quadratrac transfer case, so if you have a manual you don't have it.
The '79 three speed as said, would be the Borg Warner T150 with a Dana 20 transfer case behind it.
Lots of Jeep specific equipment data can be found here: www.jeeptech.com
CSP is online now
post #8 of 16 Old 12-21-2012, 08:52 AM Thread Starter
highred
1979 CJ7
Ok. I could not find any "VIN Coding" after searching this site. So I Googled it and found this site: http://www.jeepz.com/forum/vin.php
When I did the search, I receive the following results:
Year: 1979
Plant / Transmission: Toledo, 3-speed, Left Hand Drive
Model: JEEP®, 94 inch Wheelbase,
Gross Vehicle Weight (GVW) Rating: 4150 lbs GVW, models 83, 84, & 93
Engine: 6 Cyl, 258 CID, 2 Bbl.
It does not tell me if it is a T150. But, after reading the Novak site, it did tell me that:
The T150 was strong, and the last of the Jeep three-speeds
- Compatible with AMC engines and adaptable to GM and Ford engines
- Iron case and top cover. Close-ratio first gear with direct-drive in third-gear
- Fairly strong and extremely compact
- Compatible with the Dana 20
- 1976-1979 Jeeps
All good information.
What I am most concerned/interested in knowing is how to service this transmission and determine its useful life. I am fortunate that I was able to track down the original owner and learned that the engine was rebuilt at 80K miles. The total miles on the Jeep today id 147K and there has never been any trouble with the transmission. I am also wondering about the life of the clutch as it has never been replaced.
Since I am doing a frame off restoration, I would like to be able to do as much as I can to the transmission now as it is easy to access.
Thanks,
Rob Caldwell
highred is offline
post #9 of 16 Old 12-21-2012, 09:06 AM
CSP
Useful life will depend on how it was treated. If it shifts fine there really is no reason to tear into it. Give it a fresh bath of fluid and it will probably live a long life. Most of the time they get swapped out not because they are bad or worn out, but because the first gear is so high and not really conducive to four wheeling where you need to crawl along slowly.
CSP is online now
post #10 of 16 Old 12-21-2012, 09:29 AM Thread Starter
highred
1979 CJ7
What's the best fluid to put in a 147K T150?
highred is offline
post #11 of 16 Old 12-21-2012, 10:30 AM
bigjoe
1977 CJ7
Replace with what factory calls for the T-150. Most likely a gear oil like 90 weight. Sorry can't recall what the shop book calls for off the top of my head.
Seems like everyday is a Monday.
77' CJ-7 83' Chevy K10
bigjoe is offline
post #12 of 16 Old 12-21-2012, 11:30 AM
CSP
GL4 rated gear oil in the weight of your choice.
CSP is online now
post #13 of 16 Old 12-21-2012, 11:54 AM Thread Starter
highred
1979 CJ7
Thanks. I just read that GL5 is not good at all for T150's. But that there is some information floating around out there that says to use it.
highred is offline
post #14 of 16 Old 12-21-2012, 02:47 PM
james04si
james04si's Avatar
1977 CJ5
There are some GL-5 that is safe for yellow metals and can be used. The t-150 has brass syncro rings and regular GL-5 is corrosive and will damage them over time. It's best to just go down to your local napa and pick up a gallon of GL-4 for $20. You can use it in both the tranny and transfer case just not the differentials as GL-4 is not for hypoid gears or something like that.
james04si is offline
post #15 of 16 Old 12-21-2012, 06:51 PM
248107
1983 CJ7
The GL-5 with the MT-1 rating is okay from what i've been reading
248107 is offline
