How do i change speedo gear in transfer case - JeepForum.com
post #1 of 4 Old 02-04-2013, 10:17 AM Thread Starter
charlesgreatmax
1977 CJ5
Need help
charlesgreatmax is offline
post #2 of 4 Old 02-04-2013, 01:38 PM
ZombieCrush1
1981 CJ5
Depending on your set up, 1st unscrew the input cable from the t-case, pull out the gear, remove the c-clip from the input cable, slide off the gear, install the new gear and re-install.
ZombieCrush1 is offline
post #3 of 4 Old 02-04-2013, 03:04 PM
agear
You may need to index it. It can be clamped down in 3 or so different positions like clocking if I may.
1984 jeep cj7, 258 I6, rebuilt T176,rebuilt Dana 300, amc 20 , dana 30, 4.10's Trac-lok in rear , 4.10's detroit soft locker in dana 30, 2.5 inch bds suspension lift, 1 inch polyurethan body mount lift. Line ex. weber carburetor. factory tach. factory clock ,oem replacement speedomter cluster, and oil pressure gauge, factory volt gauge.
agear is offline
post #4 of 4 Old 02-04-2013, 03:25 PM
CSP
Asked and answered. The idea is to have a little patience with an existing thread instead of waiting less than an hour and posting the same thing again.
http://www.jeepforum.com/forum/f8/speedo-gear-1473713/
CSP is offline
