How to diagnose and repair a miss? - 77 CJ5 258 w/ 1bbl carb - JeepForum.com
post #1 of 4 Old 03-09-2014, 02:45 PM Thread Starter
CJ7KAHUNA
So I've been helping my nephew work out a few issues with his 77 CJ5. When I got here it would not charge so we got that sorted out and replaced a gauge. Once that was done it was running great so he went ahead and changed out his worn our tires. Yesterday he took it out to run a few errands. When he left the store he was at he noticed that from the time he started it up it had a miss that hasn't been there before. As he drove the miss seemed to get a little bit worse. The way he described it - at lower acceleration it wold miss real bad but when he would get on it a little bit and get into the higher RPM's it would get better.
This jeep has the stock 1bbl carb and points style ignition. The carb was recently rebuilt by a mechanic and has worked great since. The plugs are not fouled and the plug wires are relatively new - what is the best way to diagnose what is causing this miss and fix it? Any help is greatly appreciated.
My childhood was typical. Summers in Rangoon, luge lessons. In the spring we'd make meat helmets.
When I was insolent, I was placed in a burlap bag and beaten with reeds. Pretty standard, really.
CJ7KAHUNA is offline
post #2 of 4 Old 03-10-2014, 04:53 AM
Mike Romain
A miss can be a lot of things. I would first be checking the inside if the distributor cap for carbon tracks and be looking at the condition of the points while in there.
Next I usually take a spray mist bottle of water and I lightly spray the distributor cap and wires with water while it is running in a dark place or at night. If I get a 'light show' off the wires, they need replacing.
Mike
Mike Romain is offline
post #3 of 4 Old 03-10-2014, 04:06 PM
RWise
1981 CJ5
Check the points gap. They have been known to change. No feeler gauge, got a paper match?
RWise is offline
post #4 of 4 Old 03-11-2014, 06:49 PM
Cutlass327
1978 CJ5
Points in a 77?
Another thing - Check for leaking intake gasket. Very common.
Rick
Cutlass327 is offline
