How to determine best timing...? - Page 2 - JeepForum.com
post #16 of 162 Old 11-08-2013, 09:55 AM
swatson454
1983 CJ7
Wasn't trying to be anecdotal. Just pointing out that initial timing is pretty important and those two stories popped right up in my little brain. It can make or break the set up of a Weber 32/36.
Back to the OP, it will depend on your altitude, your desired in-gear idle rpm, engine condition and probably a host of other things. I usually recommend starting at 8* and just drive test the thing over the course of a week or so while going up in 2* increments. It'll probably behave better to a point, then it won't really seem to make a difference and, once you get to that point, a further increase in base timing will start to sound like an engine full of steel marbles. Make sure you don't go there!
Like I mentioned, on an old stocker, especially one with ping-prone "smogger" heads from the '80s, you won't want more than 12*.
Shawn
Live in a way that those who know you but don't know God will come to know God because they know you.
swatson454 is offline
post #17 of 162 Old 11-08-2013, 09:58 AM
Grumpy_one
1976 CJ5
Not to hijack this thread, but when I decide to upgrade my 76 to the CDI module and 79 dizzy, how would I go about finding absolute static/initial timing?
Grumpy_one is offline
post #18 of 162 Old 11-08-2013, 10:00 AM
ASteve
1972 CJ5
Before you set timing make sure you perform Shawn's Finding TDC:
http://www.jeepforum.com/forum/f8/fi...r-tdc-1290121/
Sorry if this has already been covered but...
SC
ASteve is offline
post #19 of 162 Old 11-08-2013, 10:09 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Asked and answered in the first 2 posts.
Matt
Matt1981CJ7 is offline
post #20 of 162 Old 11-08-2013, 10:10 AM Thread Starter
2Xtreme
2Xtreme's Avatar
1979 CJ7
SC
Got it.
Took care of this step before putting the radiator back on so I had plenty of access and CLEARLY marked TDC on the balancer.
2Xtreme is offline
post #21 of 162 Old 11-08-2013, 10:17 AM Thread Starter
2Xtreme
2Xtreme's Avatar
1979 CJ7
Originally Posted by Matt1981CJ7 View Post
IMO, it would run even more "flawlessly" if you hook the vac advance up to manifold. Matt
'Flawlessly-er'...??
2Xtreme is offline
post #22 of 162 Old 11-08-2013, 10:18 AM
Grumpy_one
1976 CJ5
Matt
Read it, got it, read some more, lost it, read it again got it again. Thanks.
post #23 of 162 Old 11-08-2013, 10:24 AM
Matt1981CJ7
1981 CJ7
Yeah, it's called "information overload".
If you ask for the time, some folks will tell you how to build a clock.
"Brevity is the soul to wit".
Matt
post #24 of 162 Old 11-08-2013, 10:52 AM
JayCO
1982 CJ7
2X,
DO NOT set initial timing to the highest vacuum reading. It's likely to result in far too much advance. Use the vacuum gauge for the mixture screws on the carb. Use a timing light for timing.
Here's what I recommend. The total timing (initial and centrifugal) at the upper RPM ranges is what I've found to be the most critical for performance. IMO, you should strive for 30-35 degrees total at around 3000 RPM. Once you achieve that, then let the initial land where it lands. My 258 ended up around 11 BTDC initial.
Then hook your vac advance up to manifold vac, set your idle around 700 RPM and dial in the mixture, and enjoy.
Matt
Matt,
If you're ever willing, I'd love your help with this. Nothing better than a lesson from a knowledgeable jeeper. Just let me know, and I'll head out your way. With beer!
JayCO is offline
post #25 of 162 Old 11-08-2013, 11:24 AM Thread Starter
2Xtreme
2Xtreme's Avatar
1979 CJ7
Originally Posted by JeepHammer View Post
Not trying to be 'Witty'... Trying to give useful, detailed information.
I wasn't aware this was a 'Comedy' forum. ...
It's a quote from Shakespeare....
2Xtreme is offline
post #26 of 162 Old 11-08-2013, 11:39 AM
JeepHammer
Running On Empty...
1973 CJ5
Got the message, loud and clear... un-polluting your thread...
REMEMBER,
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
JeepHammer is offline
post #27 of 162 Old 11-08-2013, 11:42 AM
roscopcoltrane
Solid thread right here. Thanks fellas.
roscopcoltrane is offline
post #28 of 162 Old 11-08-2013, 02:56 PM Thread Starter
2Xtreme
2Xtreme's Avatar
1979 CJ7
2Xtreme is offline
post #29 of 162 Old 11-08-2013, 03:06 PM
roscopcoltrane
Damn JeepHammer. I was looking forward to really tearing into what you had posted tonight in the garage. Back to the old search function...
post #30 of 162 Old 11-08-2013, 03:36 PM
lucdog
lucdog's Avatar
1980 CJ5
Originally Posted by 2Xtreme
Really 2X, roll eyes from the 258, Carburetor, ignition, TH400. What's this noise, expert.
WTF!
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
