How can I tell what type / height of a suspension lift (leaf spring) - JeepForum.com
post #1 of 3 Old 04-02-2008, 09:42 PM Thread Starter
tlhigh
1980 CJ7
1980 Jeep CJ7
The jeep currently has 38x12.50x15 tires. It's got a 3" body lift. It also has a suspension lift (either 2 1/2 or 4 inches rough country) and a shackle lift. Wedge on the back springs...
The wheel wells have been trimmed and the front fenders cut and shaved to allow fit of the larger tires.
I want to drop the jeep back down to a 2 1/2 suspension lift and no body lift or at most a 1" body lift... and replace the front fenders back stock. Planning on running 31 or 32's instead of the 38 and if necessary I'll replace the rims as well to go to 15x8 instead of the 15x10...
How can I tell the size of the suspension lift and/or whether the pitman arms have been replaced or a transfer drop kit has been installed?
Any other information or parts I may need that I haven't thought of in order to drop the jeep?
Terry
tlhigh is offline
post #2 of 3 Old 04-03-2008, 04:51 AM
Mr.Crowley
Mr.Crowley's Avatar
1980 CJ7
dpes the springs sit on top of the axle,or below? beings RC lifts tend to sag,I would venture to say you probably have a spring under 4'' with the body lift..
for the parts listed,look at the steering box where the drag link mounts and look for one of these
and for the tc drop,there will be a spacer of some sort between the frame and skid plate,so if theres a gap theres a drop
1980 cj7 258 weber,5'' of lift,33'' boggers,lincoln locked,lockright and a snorkle...Khaki Jeep Club member No. 1
1984 cj8 350 on 35's..the wifes
Originally Posted by Me
"offroad it, and wave then you might understand"
BLS Home Chapter... Where it all Started
:hahaha: yj
My low Buck Rock Crawler project Project..Stop by and check it out..
Mr.Crowley is offline
post #3 of 3 Old 04-03-2008, 11:01 AM Thread Starter
tlhigh
1980 CJ7
Leafs sit below the axle... leafs, wedge, bracket, axle
I'll check for the steering arm pictured as well as the space between the frame and skid later today... Try to get some pics posted as well...
After reading some other posts, I think the shackles are providing about 2" of the lift (about 4 inch of shackle should give about 2 inch of lift)...
It may not even have a leaf lift. Could the lift just be provided by a 2" shackle lift and larger shocks? (wedge in rear to just reposition for the drive shaft?)
tlhigh is offline
SOA or Leaf spring lift? ET48 Jeep CJ Forum 56 01-06-2009 07:28 PM
HELP! suspension lift height questions kirkhbauer Jeep CJ Forum 1 08-07-2008 01:32 AM
Leaf Spring removal from lift kit Repete Jeep CJ Forum 6 09-08-2007 01:27 AM
shock and strut or leaf spring suspension? 78cj7401ci Jeep CJ Forum 2 09-27-2005 10:58 AM
Suspension lift height 2 or 4 inch? mustangdave357 Jeep CJ Forum 5 05-24-2005 10:41 AM
