How can I tell if the PO did the 4.0 head swap? - JeepForum.com
post #1 of 5 Old 05-26-2010, 01:48 AM Thread Starter
danheit
danheit's Avatar
1979 CJ7
Judging by some other upgrades, I can easily see the PO doing the 4.0 head swap. Is there an easy way to find out? How can I tell?
I NEED A SINGLE 15X8 MICKEY THOMPSON OR SIMILAR ALUMINUM BULLET HOLE WHEEL!!!!
Build Thread: 1979 CJ7
danheit is offline
post #2 of 5 Old 05-26-2010, 03:54 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Look for the head casting number near the 3 & 4 spark plugs.
1987-1990 Jeep 4.0L used head casting 2686
1991-1995 Jeep 4.0L used head casting 7120
1996-1999 Jeep 4.0L used head casting 0630
CJ7-Tim is offline
post #3 of 5 Old 05-26-2010, 04:26 AM
5-90
5-90's Avatar
1988 XJ Cherokee
1975-1986 6-258 would get the #2685 head (if you're wondering,) and the 1999-2006 head was numbered 0331 (also, it had COP/DIS - and therefore bosses to mount the coil rail, which need not have been used - and if you see #0331 you'll want to pull the valve cover and look for "TUPY" cast into the surface on top of the head - those are the ones that are not prone to cracking, and appeared 2001.5-2002. Ish.)
The later 258 heads still had siamesed #3 and #4 exhaust ports as well - if you only see five exhaust primaries, it's the 258 head. If you see six, it's the 242ci. I believe the 258ci manifolds were cast iron log-style jobs, and I know the 242ci manifolds were all tubular steel.)
"recon" (sic - reckon)(tm) "hihgly"(tm) "seceed"(tm)
"Outback AIDS - Alcohol-Induced Dizzy Spells"
5-90 is offline
post #4 of 5 Old 05-26-2010, 05:18 AM
Fatman
Fatman's Avatar
2008 CJ7
It will have a 4.0 exhaust.
Thread Links:
Fatman is offline
post #5 of 5 Old 05-26-2010, 11:43 AM Thread Starter
danheit
danheit's Avatar
1979 CJ7
Dunno what kind of exhaust and intake it is, as I am running a Clifford Performance Aluminum intake and a header (cracked, of course).
danheit is offline
Your opinions: complete 4.0 swap or just 4.0 head swap? '83Laredo Jeep CJ Forum 9 05-22-2011 05:04 AM
4.0 head swap ward1980cj Jeep CJ Forum 2 09-21-2009 03:34 PM
4.0L head swap bluwtrsurfr Jeep CJ Forum 2 10-30-2008 07:58 AM
Another 4.0 Head Swap ?? jennandal Jeep CJ Forum 3 01-14-2008 01:20 PM
4.0 head swap jdb_us1 Jeep CJ Forum 2 06-05-2006 05:37 PM
