how can i do to re-connect the front axle of my CJ7?? - JeepForum.com
post #1 of 4 Old 05-30-2002, 06:22 PM Thread Starter
Marco Contreras
Post how can i do to re-connect the front axle of my CJ7??
Help me please, the front axle of my CJ7 is disconnected, i dont know how can i do to re-connect this, please, if you can help, add some graphics, i appreciate this so much. thank you. mcontreras@prosoft2k.com
Marco Contreras
Mexico
Marco Contreras is offline
post #2 of 4 Old 05-30-2002, 08:56 PM
hollywood
Post
Does it have a front drive shaft? Specifically how do you mean "disconnected"? Everything in the front should look pretty much like everything in the rear. Write back with what parts are missing.
- Jeff
'83 cj
Another 7 by "CJ's Heaven"
hollywood is offline
post #3 of 4 Old 06-02-2002, 08:18 PM
hollywood
Post
Marco, I got the other message you sent me. If the front driveshaft is turning but the wheels are not, you might have a problem with the hubs, or something broken in the front diff. Block the wheels and put the transfer case in neutral. Crawl under the jeep and turn the front driveshaft with your hand (with the front hubs locked in). While doing this, look to see if either of the front axle u-joints are turning. If the u-joints (front axle shafts) are turning, then you have a problem with the locking hubs.
- Jeff
'83 cj
post #4 of 4 Old 06-03-2002, 08:55 PM
hollywood
Post
If the front drive shaft turns, but the the front axles don't, you probably have something broken in the front diff. You can take off the diff cover to see what's broke, but you will most likely have to bring it somewhere to have it fixed.
- Jeff
'83 cj
CJ striker doesn't connect to ACME doors slothmonxtr Jeep CJ Forum 17 11-11-2010 11:43 AM
CJ7 Ebrake to Foot pedal connect... Ford_Prefect Jeep CJ Forum 8 03-27-2009 09:20 PM
Narrowtrack rear axle with 2" spacers match up with a widetrack front axle? Blthomas Jeep CJ Forum 1 05-11-2007 08:25 PM
Front differential cover replacement/Front Axle mattmosman Jeep CJ Forum 2 09-18-2006 06:54 AM
where do all the carb lines connect? jeepin cj-5 Jeep CJ Forum 1 07-05-2003 10:47 PM
