How to Build a Hyrdroboost brake system? - Page 2 - JeepForum.com
post #16 of 36 Old 06-07-2012, 06:30 AM
billybooster2
1983 CJ8
Can i is a 99-04 mustang set up or does it have to be 98 and back? Thx?!!
billybooster2 is offline
post #17 of 36 Old 08-19-2012, 07:15 PM
billybooster2
1983 CJ8
for anyone following this thread - yes it can. And going from a manual brake set up to this hydroboost was an EASY install but for the difficulty in removing the 30 year old hard lines from the proportioning valve. But once done, the rest is easy....! So far at least.!!! Thanks (COAS ANDALL THE OTHERS I HAVE FOLLOWED) for your help and advice(s).
post #18 of 36 Old 08-20-2012, 12:38 PM
Cutlass327
1978 CJ5
So does that adapter from Mike fit so you don't have to cut/weld the pushrod from the pedal?
What is the advantage of the Mustang parts over the Astro parts?
Which of these is the most direct bolt-in, with minimal fabricating/adapting?
Rick
Cutlass327 is offline
post #19 of 36 Old 08-20-2012, 04:39 PM
billybooster2
1983 CJ8
I bought the mustang spacer from partsmike. Make sure you get the central hole. Not the offset one. Then go to vanco and buy the pressure hose kit currently $175. Have some hard lines made with the mustang ends at one end and the cj proportioning at the other. That cost me $25. Nothing was welded, threaded, tapped or otherwise changed.
post #20 of 36 Old 08-20-2012, 05:22 PM
cjjon7
1983 CJ7
A YJ booster bracket works fine too...for the astro booster, not sure about the mustang units. All that had to be done was elongate two of the booster mounting holes. Then just bought a 4" coupler nut from mcmastercarr and cut to appropriate length to extend the pushrod. Done!
cjjon7 is offline
post #21 of 36 Old 08-21-2012, 01:03 PM
billybooster2
1983 CJ8
Taking the plunge and removing what uou have is 89% of the battle. I had hard lines made for me. No fabbing anything else. I truly feel its a new car!
post #22 of 36 Old 12-04-2013, 09:36 AM
drespecki
1983 CJ7
Was wondering on the mustang hydroboost.... There are 2 types of mustang hydroboost:
The 99+ GT boost unit that has an angle master cylinder mount
The older style 96-98 that is a vertical master cylinder mount.
Now, there are also 2 types of master cylinders for these:
The 99+ mc that has an angle mount and I think is 1 1/16 bore
The older style 96-98 mc that is a vertical mount and 1" bore
Can I use the 1" bore master on both units? Does the 1" straight mc hit the accumulator on the 99+ booster? Seems like it would.. To me, the 99+ boost unit looks like it has a bigger/longer accumulator...
Lastly, I think I NEED to use the 1" on a disk/drum setup or does that not matter with the hydroboost?
Thanks!!
It only hurts while you're breathing..
drespecki is offline
post #23 of 36 Old 12-04-2013, 10:28 AM
Cutlass327
1978 CJ5
I would think the larger bore would be more ideal. The larger the master cylinder piston area, the more fluid is pushed for better power at the slave end (each wheel cylinder or caliper). This would mean less effort for more braking power.
Rick
post #24 of 36 Old 12-04-2013, 01:34 PM
drespecki
1983 CJ7
Okay, I did find out some basic differences, just not sure which one is best for a stock type CJ7 with disk/drum setup..
96-98 mustang V8 hydroboost:
Vertical MC with 1" bore
Shorter accumulator
99-04 mustang V8 hydroboost:
Canted MC with various bores.. 1", 1.062", 1 1/16", and 1 5/8" bores
Longer accumulator, looks like the 96-98 master cylinder will not fit without hitting it.
post #25 of 36 Old 12-05-2013, 02:04 AM
billybooster2
1983 CJ8
Originally Posted by drespecki
Okay, I did find out some basic differences, just not sure which one is best for a stock type CJ7 with disk/drum setup.. 96-98 mustang V8 hydroboost: Vertical MC with 1" bore Shorter accumulator 99-04 mustang V8 hydroboost: Canted MC with various bores.. 1", 1.062", 1 1/16", and 1 5/8" bores Longer accumulator, looks like the 96-98 master cylinder will not fit without hitting it.
Well i have a partsmike fender wall adapter and a sloping m/c, horizontal accumulator. Stops on dime. Not sure of bore but 35's lock with ease.
post #26 of 36 Old 05-18-2014, 06:34 PM
moranda
sorry to resurrect an old thread but I have a 99-04 hydroboost master cylinder. The question I have is how does the bracket from partsmike connect to the hyrdroboost/master cylinder?
moranda is offline
post #27 of 36 Old 05-18-2014, 08:43 PM
4S50
If the parts mike adapter is the same as that used by WFO Concepts; you need to remove the nut on the mounting shaft, remove the factory mounting plate, put on the CJ plate, and tighten up the nut. Nothing to it. Now shortening the push rod, that can be another issue.
4S50 is offline
post #28 of 36 Old 05-21-2014, 07:31 PM
billybooster2
1983 CJ8
^what he said plus...instead of shortening rod, space bracket to firewall
Sent from under this leak
post #29 of 36 Old 05-23-2014, 12:13 AM
moranda
Yeah thats what I was thinking I would do. Glad its been done before. Just need to get the thing going while its nice outside.
moranda is offline
post #30 of 36 Old 05-26-2014, 10:05 PM
moranda
One more question. Whats the best way to get the nut off that plate?
moranda is offline
rebuilt brake system and can not get any pedal lew12b Jeep CJ Forum 12 10-17-2011 06:08 AM
brake and Fuel system REDo ajstewart Jeep CJ Forum 1 11-07-2008 11:09 AM
CJ7 - air in brake system! What to do? vladrulli Jeep CJ Forum 7 07-07-2008 01:46 PM
My brake system is in need of some help.. nyTroX Jeep CJ Forum 8 03-23-2007 08:19 PM
flinstone brake system tiko_joe Jeep CJ Forum 3 05-11-2006 08:33 AM
