How big of a deal is this (my stupidity)? - JeepForum.com
post #1 of 4 Old 10-23-2009, 12:11 PM Thread Starter
CaptKirk
I forgot to grease the poly bushings on my new BDS lift kit. Bad, I know. Is it a must to basically break it back down and grease them with the special poly grease? Any suggestions?
CaptKirk is offline
post #2 of 4 Old 10-23-2009, 12:23 PM
Mike Romain
I think you kinda know the answer eh? Dry parts either wear real fast or bind up.
Mike
Mike Romain is offline
post #3 of 4 Old 10-23-2009, 01:09 PM
Fjguercio
1978 CJ7
When I removed the stock style shackles the rust was imbeded into the rubber. I do not even think the shackle could rotate during the flex. NOT GOOD.
If you had greasable shackles maybe get away with. But sounds like you will be doing a remove and grease. It will keep the rust at bay and help with flex/rotation. I would also consider drilling the bolts, installing zerc / grease fitting so you can add grease as PM, use lithium or similar so does not rot the polly bushings.
Fjguercio is offline
post #4 of 4 Old 10-23-2009, 01:36 PM Thread Starter
CaptKirk
Thanks guys. I literally could kick my own arse. Dumb.
CaptKirk is offline
Here is a deal for someone.. MoC Jeep CJ Forum 3 08-14-2009 02:42 AM
Deal or No Deal? shok47 Jeep CJ Forum 4 07-20-2009 07:27 PM
CJ7 DEAL! Have too LOOK! tschneider2005 Jeep CJ Forum 6 02-20-2009 12:07 PM
Done Deal Jack-Jack Jeep CJ Forum 2 08-30-2005 03:57 AM
Deal or no deal Bronco Axles soler Jeep CJ Forum 2 05-14-2003 06:20 PM
