How big of an air filter do I need? - JeepForum.com
post #1 of 9 Old 09-08-2011, 07:40 AM Thread Starter
82KansasCJ
82KansasCJ's Avatar
1982 CJ7
Running the Holley 390 on my 258 and right now I'm running a small holley air filter that is triangular in shape but I'm not sure how good it really is with the washable filter. Not alot of clearance for a large filter.
Thoughts on how much filter I need and what I might use?
Current filter and location can be seen in this pic:
1982 CJ-7....not perfect but still alot of fun!
82KansasCJ is offline
post #2 of 9 Old 09-08-2011, 08:23 AM
John Strenk
John Strenk's Avatar
1976 CJ5
The bigger the better.
I've seen an offset air cleaner off some truck that fits the MC2100 and should fit your Holley. You could get an 90* adapter and make a separate box or performance air cleaner that you can tuck away someplace.
I've made my own before with some thick flat sheets of aluminum. I just laid a filter on top cut to fit and then cut an opening for the carb. It worked as an open filter but if you have any skill with a welder you could make it enclosed.
In fact, with all the talented fabricators on site, I'm surprised no has made a custom one to sell. Hint Hint...
Maybe something like this with the with the cold air intake on back or side to a intake on the side of the hood. Real easy to hook up a warm air connection also for winter.
John Strenk is offline
post #3 of 9 Old 09-08-2011, 09:20 AM
swatson454
1983 CJ7
Those foam things are a fire hazard. I've seen more than a couple of engine fires caused by a back fire through the carb. They're really restrictive too.
I know you're tight on clearance with the brake booster but I think you can squeeze a 4 inch high x 8 inch diameter filter in there. There are also several cool-air enclosures you can purchase that will help a little on power. I think it was gojeepin that posted links to several of them a week or so ago.
I'd try to dig them up for you but I've got to get out the door. I'm serious about the fire hazard thing.
Shawn
Live in a way that those who know you but don't know God will come to know God because they know you.
swatson454 is online now
post #4 of 9 Old 09-08-2011, 09:31 AM Thread Starter
82KansasCJ
82KansasCJ's Avatar
1982 CJ7
Shawn
Well that's no good at all! I'm starting to remember that when I picked this up from the PO he gave me a monster setup that he had made but not installed. I've got to find that box. Seems as if it had two of the "cone" typ filters on the end of some sort of tube.....my memory sucks.
post #5 of 9 Old 09-08-2011, 10:43 AM
WelderX
I second that on those foam air cleaners. They are dangerous.
WelderX is offline
post #6 of 9 Old 09-08-2011, 12:47 PM Thread Starter
82KansasCJ
82KansasCJ's Avatar
1982 CJ7
Snuck home at lunch and found this system that the PO had installed. Had all the hardware and went right on....better than the other? Will it flow enough air?
post #7 of 9 Old 09-08-2011, 02:27 PM
swatson454
1983 CJ7
I've never seen a set up like that before. It'll flow plenty of air! No fire hazard, and it isn't pulling smokin' hot air from directly over the header. I'd say you're in business
Shawn
post #8 of 9 Old 09-08-2011, 03:09 PM
JeepHammer
Running On Empty...
1973 CJ5
We tested those on the dyno, they are about worthess.
What worked on the dyno,
Assuming a 12" in diameter air filter, you need an inch for about every 100 Cubic Inches of displacment.
You can use a LARGER DIAMETER filter for more surface area when you reduce the height, like those 14" filters Edelbrock & Holley are so fond of,
And you need extra filter above about 5,500 RPM since Reversion is going to be an issue and the turbulance inside the air cleaner.
The WORST thing you can have for a filter is what is shown in the picture you posted!
The second worst thing you can have is a 'Velocity Stack' with a little fiter inside it...
I don't use K&N any more, found dirt tracks inside the carb, and I won't have that.
If you oil a K&N enough it doesn't pass dirt, it's restrictive,
If you let up on the oil, it lets dirt pass,
So I don't use them.
REMEMBER,
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
JeepHammer is offline
post #9 of 9 Old 09-08-2011, 03:34 PM Thread Starter
82KansasCJ
82KansasCJ's Avatar
1982 CJ7
JH, So the triangle one is worthless & the K&N style is crappy too?
258 oil filter starfire340 Jeep CJ Forum 27 09-05-2012 10:49 PM
Oil Filter Relocation Kit Minus The Filter??? MidJob Darthteddy Jeep CJ Forum 4 07-11-2010 09:11 PM
Best Air Filter For Motorcraft 2100 Air Filter NWA_CJ7 Jeep CJ Forum 9 07-22-2008 08:23 PM
Replacing Air Filter with Open Filter budacj7 Jeep CJ Forum 5 06-09-2008 07:16 AM
Oil Filter Etchandy Jeep CJ Forum 5 12-06-2007 09:11 AM
