How to adjust tie rod sleeve? - JeepForum.com
post #1 of 14 Old 08-25-2013, 01:58 PM Thread Starter
jeep714
1981 CJ7
Hey everyone,
I had to replace my tie rod that goes from knuckle to knuckle, and I'm having trouble getting it all the way on. I've replaced one before where I was able to tighten it all the way by hand, but I can't get this one to budge really. Any tips?
Peter
jeep714 is offline
post #2 of 14 Old 08-25-2013, 02:23 PM
LumpyGrits
Spread the slit opening just a bit and then grease the threads.
I have also used a 12 gauge bore brush on a drill motor to 'clean' the inside threads too.
LG
Have'n you along, is like loose'n 2 good men
LumpyGrits is offline
post #3 of 14 Old 08-25-2013, 04:39 PM
baldfatdad
1984 CJ8
The last drag link I got was too long. I never did get it all the way together, so the steering wheel sits a bit crooked.
baldfatdad is offline
post #4 of 14 Old 08-26-2013, 09:46 AM
Redmanchew
Redmanchew's Avatar
1982 CJ7
there is a specific tool for adjusting the tie rod/drag links..
http://www.walmart.com/ip/19264080?w...742316&veh=sem
I had a mechanic friend loan me one before i went with my BDO HD setup. I would have more then likely bought one of them if i had kept my stock setup...
1982 CJ-7 2003 4.3 chevy vortec, 4L60E, Clocked Dana 300 35 x 12.5 x 15 KM2 on Cragar 399's. Vanco Brake Booster. Power steering conversion. Warn front and rear bumpers with swing away. Moser 1 piece rears. Rear OX.
Support your local MS foundation. You don't know how much this disease sucks until it affects someone you love.
Originally Posted by twoleos617 View Post
To reiterate for the 1,067th time, when towing...
remove rear axle, xfer in N, trans in 5th, remove neg batt cable, key to Run and go??
Redmanchew is offline
post #5 of 14 Old 08-26-2013, 09:52 AM
CJ7ROB
Use a pair of channel locks or vice grips to turn it.
CJ7ROB is offline
post #6 of 14 Old 08-26-2013, 10:38 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
I recommend buying the correct tool, or borrowing one.
I've tried to adjust mine with channel locks, and couldn't get the blasted thing to budge.
LG, what do you use to "spread the slit"? Large flathead screwdriver, or.....?
Thanks,
Matt
Matt1981CJ7 is offline
post #7 of 14 Old 08-26-2013, 11:26 AM Thread Starter
jeep714
1981 CJ7
Thanks for all the responses. I don't see that my tie rod has an adjusting sleeve though. The ends just screw on to the rod itself..
Peter
jeep714 is offline
post #8 of 14 Old 08-26-2013, 11:32 AM
LumpyGrits
Matt, screwdriver if really mashed closed. Broom stick handle is pretty close to correct ID.
LG
post #9 of 14 Old 08-26-2013, 01:52 PM
Redmanchew
Redmanchew's Avatar
1982 CJ7
if your talking about an upgraded tie rod with lock nuts on each end then are you sure you have a right and left end? one with the notch in the nut is reverse thread (righty loosey).
post #10 of 14 Old 08-27-2013, 12:01 PM
keith460
Jeep. There's Only One
keith460's Avatar
I was going to say the same thing. Make sure you have a set of left and right hand threaded tie rods.
1984 CJ-7 Renegade
keith460 is offline
post #11 of 14 Old 09-07-2013, 08:57 PM Thread Starter
jeep714
1981 CJ7
I'm pretty sure they are a set, they came with the tie rod. One side goes all the way screwed in with no problem. The other side will go about 3/4" an then become very difficult to turn. Not sure what to do about that still..
Peter
jeep714 is offline
post #12 of 14 Old 09-08-2013, 01:00 AM
Spieg8
1984 CJ8
Peter
Sounds like you got a bad kit. You can try to chase the threads with a tap and die, or return/exchange it for a new one (personally I'd return it... tired of fixing defects that manufacturers should be catching in their quality control process ).
Spieg8 is offline
post #13 of 14 Old 09-11-2013, 08:03 PM Thread Starter
jeep714
1981 CJ7
Yeah you were right, I got a bad kit.. The new one is installed! I have one more question though, when installing the steering stabilizer, does it have to go a certain way around the tie rod? Like underneath it or on the side? The instructions pretty much say just make sure it doesn't hit anything
Peter
jeep714 is offline
post #14 of 14 Old 09-11-2013, 11:26 PM
Spieg8
1984 CJ8
Ya, the main thing is to keep it from rubbing anything. You also want to make sure it doesn't limit tie rod travel in either direction (stabilizer shouldn't fully extend or fully compress even when at full left turn or full right turn). Ideally you want the stabilizer to be up above and parallel to the tie rod, but this is not always possible in every situation... just get it as close as you can.
Spieg8 is offline
