how to adjust door latch - JeepForum.com
post #1 of 4 Old 10-25-2013, 12:49 AM Thread Starter
pazur
1981 CJ7
I got a full yj door fitted to cj7 and cannot not get them to close properly.
The latch when compeletely closed, the distance between those two "jaws" is too small for a striker (5/8" OD).
Is there an easy way to fix this i.e. slightly enlarge the latch?
pazur is offline
post #2 of 4 Old 10-25-2013, 10:19 AM
superj
go pull the striker off a junkyard jeep to compare the sizes or remind me later and i will measure my yj striker bolt for you. i have used cj and yj doors on my yj with no problems like that though
I don't feel like working on anything at this time so i sold my yj.
superj is offline
post #3 of 4 Old 10-25-2013, 11:03 AM
graydragon2
Instead of enlarging the latch I would look for a smaller striker first. How much too small is the latch.
graydragon2 is offline
post #4 of 4 Old 10-25-2013, 11:54 AM
Spieg8
1984 CJ8
Not clear on your problem... are you saying the gap for the post between closed jaws is smaller than the diameter of the post? Which is 5/8", the post or the gap? What is the measurement of the other (how much is the difference)? Is this a factory door post, or did you install it yourself?
Can you also get a measurement of the end of the post (how thick is the top of the "T")? I've seen some aftermarket posts that are too thick t the end and cause problems as well (this can be filed down to work better if that is the case).
Spieg8 is offline
