Horn mounting - JeepForum.com
post #1 of 9 Old 08-20-2013, 06:49 AM Thread Starter
2007st1300abs
1978 CJ7
Horn mounting
Hi , can you tell me what side of the engine bay where the horn on a 1978 cj-7 should be?
Thanks !!
2007st1300abs is offline
post #2 of 9 Old 08-20-2013, 07:36 AM
WindKnot
1977 CJ7
On a '77 it's toward the front of the left inner fender. (Right about where the red with the white trace wire comes out of the loom. The '78 MAY be different, but I doubt it. (It would be the same color at the horn relay. My relay also has a yellow and a black wire [possibly with a trace?])
I'd rather be lost on the trails than found at home!
Phoenix Rising- A Flame Off Restoration?
WindKnot is offline
post #3 of 9 Old 08-20-2013, 07:41 AM Thread Starter
2007st1300abs
1978 CJ7
Thanks
post #4 of 9 Old 08-20-2013, 10:34 AM Thread Starter
2007st1300abs
1978 CJ7
Ok , so when I push the horn button I can hear the horn relay clicking , I then go and test the terminals and the 14 gauge solid red is hot all the time , then checking the brow with white stripe when pushing the horn button the test light goes out and solid when not being pushed . The red with a white strip which should go to the horn does not light up when the button is pressed. I did also try another relay and had the same results ??? Any help would be greatly appreciated thank-you.
post #5 of 9 Old 08-20-2013, 06:29 PM Thread Starter
2007st1300abs
1978 CJ7
bump
post #6 of 9 Old 08-21-2013, 11:03 PM Thread Starter
2007st1300abs
1978 CJ7
It turned out to be a bad horn relay.
post #7 of 9 Old 08-23-2013, 07:10 PM
WindKnot
1977 CJ7
We'll take those all day long!
WindKnot is offline
post #8 of 9 Old 08-29-2013, 08:10 AM
turbogus
1978 CJ5
For those of us with these fender skirt mounted horns on CJ's a prank I read goes like this, as the wiring for the left turn signal is in such close proximity to the horn wiring run a spliced wire from the turn signal wire to the horn power lug............
The parts shop that stocks part for Skylab II will not have parts for our year/model of Jeep
We cannot accurately judge the trajectory of a speeding critter (cat, dog, sasquatch)
Record heat waves and floods only occur when we visit that area
turbogus is offline
post #9 of 9 Old 08-31-2013, 09:25 AM
paveland
paveland is offline
