Horn is constantly on - Page 2 - JeepForum.com
post #16 of 24 Old 04-29-2013, 09:37 PM
jimdubose
1978 CJ5
click on this link and read through it:
http://civilianjeep.info/Strenk/Stee...placement.html
you are at the point where you need a lock plate removal tool. they can be purchased many places (simply google lock plate removal tool, check your local parts houses). here is one for 20 bucks at autozone
jimdubose is offline
post #17 of 24 Old 04-30-2013, 02:05 AM
John Strenk
John Strenk's Avatar
1976 CJ5
Well you are missing the spring contact here. You will have to dig deeper into the column now.
Try disconnecting the Turn signal connector and see if the horn stops. That would tell you if the problem is in the column or someplace else.
John Strenk is offline
post #18 of 24 Old 04-30-2013, 06:08 AM Thread Starter
Gigemags05
1980 CJ7
When you say I'm missing the spring contact, are you talking about the pin inside the spring? Or is there another piece? I have the spring and the pin.
I guess I'll be getting a lock plate puller.
Gigemags05 is offline
post #19 of 24 Old 05-01-2013, 02:50 AM
John Strenk
1976 CJ5
Pin and spring. I didn't see it in the picture. If you got a picture of it with the pin in place, that would be great. I havn't found such a picture yet...
Did you try and disconnect the turn signal harness yet? you don't need a puller to do that yet...
post #20 of 24 Old 05-01-2013, 06:07 AM Thread Starter
Gigemags05
1980 CJ7
No I haven't tried yet. I'll be out of pocket for a few days so I'll try it when I get back.
How would I disconnect the turn signal harness?
post #21 of 24 Old 05-01-2013, 10:56 AM
texasdave
texasdave's Avatar
1980 CJ7
I have seen horns short internally and blow constantly. If you have access to another horn you could try it. but I agree with John I think it is your column. Unless you have a direct short caused by bare wire.
texasdave is offline
post #22 of 24 Old 05-01-2013, 10:58 AM
texasdave
texasdave's Avatar
1980 CJ7
Not wanting to hi-jack the thread but does anyone know where you can get the original sounding Jeep horn, the one that sorta sounded like the meep meep from the Road Runner (cartoon character) for you youngsters.
post #23 of 24 Old 05-02-2013, 02:41 AM
John Strenk
1976 CJ5
This is the plug:
It's usually mounted on the bottom side of the steering column.
post #24 of 24 Old 05-02-2013, 10:06 AM Thread Starter
Gigemags05
1980 CJ7
Oh ok. That should be easy enough to check.
Thanks!
