In the homestretch. Final electrical help and questions - Page 2 - JeepForum.com
post #16 of 34 Old 07-03-2013, 08:31 AM
row684
Originally Posted by Jeeprage
Update:
I got the wipers working, and the hazard switch was jammed in causing running light issues. They don't flash with the switch, but DO work with the turn signal stalk (should be good enough for inspection).
The parking and reverse lights are still constantly on. Is this likely a bad brake switch? How do reverse lights connect under-hood? I don't think I have anything run to the trans yet.
These should be my last issues to at least get the Jeep inspected. I need to sort out the Temp, Fuel, and Oil pressure gauges still.
Reverse lights ground to the tranny I believe. Maybe the wires to the tranny is pinched on something grounding it if you don't think the switch is hooked up yet?
I also have an issue with my headlight switch turning all my lights on with the dimmer switch after doing a "painless" harness. Pull the knob out and they wouldn't come on until I turned up the brightness of the dash lights! Lol I won't hijack your thread just something to try maybe?
row684 is offline
post #17 of 34 Old 07-03-2013, 09:30 AM
John Strenk
John Strenk's Avatar
1976 CJ5
Revers lights are switched with the tranny, they do not go to ground. The reverse switch has tow terminals.
Has to be a short to some power circuit. or a badly miss wired PO feature. I would disconnect the plug at the driver door ans check the connections there to see if the problem is in the rear harness or forward harnes.
row684, what lights? Dash lights, Parking lights, headlights?
John Strenk is offline
post #18 of 34 Old 07-03-2013, 12:40 PM Thread Starter
Jeeprage
Jeeprage's Avatar
Disconnect the rear harness? Won't that disconnect all rear lights, short or not? Where is the reverse switch?
2015 JKU - 6m
Jeeprage is offline
post #19 of 34 Old 07-03-2013, 12:51 PM
John Strenk
1976 CJ5
Yeah, that is to try to figure out if there is a short, were it is. You can check the plug near the driver door to see if there is power there when there should not be.
post #20 of 34 Old 07-03-2013, 07:07 PM Thread Starter
Jeeprage
Jeeprage's Avatar
Disconnected the brake switch and lights are off. I think pedal throw is too tight with the fiberglass firewall and setting off the lights. Need to see if i can adjust the switch at all. I will work on reverse lights after this is sorted. Thanks
2015 JKU - 6m
Jeeprage is offline
post #21 of 34 Old 07-03-2013, 07:44 PM
John Strenk
1976 CJ5
Some switches just need to be pushed in farther to make contact when the pedal is at rest.
Yes, I had to increase the length of my pushrod withy fiberglass tub. It's nice to have the brake and clutch at the same height.
post #22 of 34 Old 07-04-2013, 05:11 AM Thread Starter
Jeeprage
Jeeprage's Avatar
I had redrilled pedal hole to mount the push rod but perhaps not far enough. I will try to adjust the switch this weekend. Feels good to be moving forward.
2015 JKU - 6m
Jeeprage is offline
post #23 of 34 Old 07-09-2013, 08:37 PM Thread Starter
Jeeprage
Jeeprage's Avatar
Just to close a thread... tail lights are working (I had to adjust the switch and bend tab slightly), running lights are sorted, and reverse lights function. I have 1 headlight that the low beam isn't working on. I just bought new headlights, thinking it was an easy fix... but new bulb is doing the same. I'll have to try chasing down the wiring between lights, I don't know why only one would work.
Other option is to just attempt a rewire with relays.
2015 JKU - 6m
Jeeprage is offline
post #24 of 34 Old 07-09-2013, 09:04 PM
John Strenk
1976 CJ5
Go with relays. Much brighter lights.
post #25 of 34 Old 07-09-2013, 09:24 PM Thread Starter
Jeeprage
Jeeprage's Avatar
You don't happen to have a preferred write up, do you? Or preferred relays? I can search tomorrow otherwise, but want parts by the weekend so i can wrap this up.
2015 JKU - 6m
Jeeprage is offline
post #26 of 34 Old 07-09-2013, 09:36 PM
John Strenk
1976 CJ5
I'm Lazy,
I'm going to buy this: http://www.summitracing.com/parts/upd-34263 $37.00!!
You just plug it into your old headlight plug and plug the new plugs onto your old Headlights. '
Real simple....
But you could look up Jeephammers post on making a harness with Circuit breakers and everything.
http://www.jeepforum.com/forum/f8/he...t-mods-686559/
post #27 of 34 Old 07-10-2013, 04:50 AM Thread Starter
Jeeprage
Jeeprage's Avatar
I'm Lazy,
Real simple....
Too easy... I just ordered that harness. Thanks.
Maybe it will fix my issue of one low-beam out, maybe it won't. I'm assuming a contact in the left socket is corroded, but the only other thing I can think of is a wire is cut, which I didn't see.
2015 JKU - 6m
Jeeprage is offline
post #28 of 34 Old 07-10-2013, 04:52 AM
John Strenk
1976 CJ5
Let us know how it works out for you.
post #29 of 34 Old 07-10-2013, 06:02 AM
team-green
A question about the signal flasher...
86 should not have a turn signal flasher in the fuse box. Does the box even have terminals to hold the turn signal flasher in place? if it does then it's a fuse box earlier than 1984.
Hi John,
do you know the reason why the relay is no longer installed in the fuse box?
I thought it was a mistake by one of the previous owners and wanted to change the whole thing on my CJ7-1985.
Well I have not done it yet.
Greetings Jochim
team-green is offline
post #30 of 34 Old 07-25-2013, 01:04 PM
CJ7ROB
I'm Lazy,
Real simple....
John this is nice. Im going to order one now too. Do you guys know if the courtesy lights just plug into the headlight switch? It looks like my Jeep never came with the courtesy lights. These below aren't mine, but I have the same ones I found used, Thx.
CJ7ROB is offline
