Home made dual battery tray - JeepForum.com
post #1 of 16 Old 08-12-2009, 05:52 PM Thread Starter
jatepper
I searched the forum and the dual battery sticky and found no plans for making a dual battery tray. I want to attempt to make one. Does anyone have plans?
1986 CJ7 Laredo - Auto 14k miles
1985 CJ7 Renegade - Auto 33k miles
1982 CJ8 Scrambler - T5 T-SPD
jatepper is offline
post #2 of 16 Old 08-12-2009, 05:55 PM
RetiredSERE
RetiredSERE's Avatar
1980 CJ7
Been thinking about it myself. I just plan on patterning out two batteries side by side then make up a plate out of 3/16 and then fab supports. Should be one of the easier fabs.
Dave
Shoot, Move, Communicate
Admit to Nothing, Deny Everything, Make Counter Accusations...
I Feel Like a Monkey F***ing a Football..
RetiredSERE is offline
post #3 of 16 Old 08-12-2009, 06:02 PM Thread Starter
jatepper
Dave
I have found while working on the jeep that nothing is ever easy, although it does sound like it should be!
jatepper is offline
post #4 of 16 Old 08-12-2009, 07:55 PM
JeepHammer
Running On Empty...
1973 CJ5
Angle iron with a center support under the batteries,
Center support makes a good place for tie down.
Just a square frame with center support, so it's not a big deal.
REMEMBER,
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
JeepHammer is offline
post #5 of 16 Old 08-12-2009, 09:00 PM Thread Starter
jatepper
Cool. What about mounting it to the firewall. I am worried about the extra weight with another battery. Do most people use the same holes their OEM battery tray used or will I need to drill some more holes and add extra nuts and bolts?
jatepper is offline
post #6 of 16 Old 08-13-2009, 03:36 AM
JavaTee
1979 CJ5
Here's some pics for us visually stimulated fabricators
http://cjoffroad.com/forums/topic.as...l,battery,tray
Later, T.J.
'79 CJ5 258 w/MC 2100 & Team Rushed, NP435/Dana300 <--twin sticked, NT Dana 44 (w/Aussie) rear, and NT Dana 44. 3" susp lift, Currie shackles, 1" body Lift, Durabaked tub inside & out.
Military members (current or completed service) check out
JavaTee is offline
post #7 of 16 Old 08-13-2009, 06:01 AM
JeepHammer
Running On Empty...
1973 CJ5
I used 'Nut-Serts', Also called 'Riv-Nuts'.
It's a threaded sleeve you can insert in sheet metal, expand, and leave behind threads to bolt something up.
Extra places to bolt to the firewall,
Then same support arms the single battery tray had.
Seems to be working OK so far, have about 4 years on it with no problems.
REMEMBER,
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
post #8 of 16 Old 08-13-2009, 07:42 AM Thread Starter
jatepper
Thats more or less what I was looking for. Thanks for the link. The battery tray looks much easier to make with the fender off like the pictures in the link displays.
jatepper is offline
post #9 of 16 Old 08-14-2009, 03:41 AM
JavaTee
1979 CJ5
I don't think it's easier, nor harder with the fenders off (esp. for a prior service Marine ). After you fab up the tray, and either weld the lower bolts to the tray, or fit/weld on the brackets for the lower support, it should be a 'slip-in and bolt-up event'.
I rebuilt my single tray to accept a larger battery. It took more time for the paint to dry than to cut, grind, fit and weld up the wider/longer tray.
Later, T.J.
JavaTee is offline
post #10 of 16 Old 08-14-2009, 08:40 AM Thread Starter
jatepper
Yeah, my main concern was the weight of the extra battery, but it seems to be working for you guys. An extra battery is another 30-40 lbs or so and I just want to make sure I dont strip out any nutserts or anything with the extra weight and have the battery tray fall off while Im wheeling.
jatepper is offline
post #11 of 16 Old 08-14-2009, 11:49 AM
Stan99
1978 CJ7
Ive built a few of these. The way I do mine is to brace off of the fender instead of just the tub. I didnt have any of the original braces for the battery tray so I figured if I was going to do anything that wasnt stock then I might as well go a different route. It is made just like everybody else says, with some angle iron.
This is the only pic I have right now. I can post some more later if you like.
1978 Jeep Cj7 Soa, Shackle Reversle, 36x13.5x15 Irocks, 4.5 Stroker MPI, Dana 300 twin Sticked, 4.88's
Stan99 is offline
post #12 of 16 Old 08-14-2009, 12:46 PM
NWA_CJ7
1983 CJ7
I made my own. While I do not have any directions I do have some pics. I have a source with an over abundant supply of stainless steel so that was my metal of choice. I'm not complaining.
83 CJ7 AMC 360, nuttered & team rushed. Dana 44 rear geared & locked, Dana 30 front geared & locked Dana 300 T. Case 4" Tough Country Lift, 1" daystar body lift, 1/2" shackle 35x12.50x15 MT MTZ's on MT classic 2's, Besrk Bumpers, Genright Tube Fenders
NWA_CJ7 is offline
post #13 of 16 Old 08-14-2009, 01:07 PM
xeroOTG
Originally Posted by NWA_CJ7 View Post
Thats absolutely beautiful! I believe I have been motivated! After I rewire my EFI... darn my redneck engeneering degree...
My jeep gives a whole new meaning to the phrase, Just Empties Every Pocket!
1975 Jeep CJ5 258 TBI EFI, T-18, D-20, D44 rear, 4.11.
1992 Jeep Cherokee 4.0L, AW4, NP231 October 2009 - August 2012
1998 Jeep Cherokee 4.0L, AX15, NP231 - August 2012
xeroOTG is offline
post #14 of 16 Old 08-14-2009, 04:45 PM
OMR
Stan99 and NWA CJ7 great job on the boxes both
NWA I've been thinking of making an s/s box, then polishing the parts that show ... but then again, I come up with these hair-brain ideas and never get them done, so it will probably just be mild steel and painted
Mark
'86 CJ7 - 258 - Howell - 'Rushed' - 2.5" sl, 1" bl - T5 - d44 rear - 33 x 12.5
OMR is offline
post #15 of 16 Old 08-15-2009, 06:35 AM
JeepHammer
Running On Empty...
1973 CJ5
ON the cheap side...
One time I made one of these for the natives, I said something about the materials going to cost around $100...
He ran out and brought me some bed frame rails, and went to the local second hand stores and got me a bunch more for about $5 a set...
Plenty of angle iron that worked fine for a battery tray,
(Battery trays are like beer, You don't OWN them, you only rent them from the corrosion gods!)
And I haven't ever forgotten about that cheap source of angle iron...
Yard sales, second hand stores, ect....
So if you are a cheap bastard like me, keep your eyes open, you might be surprised what you find in places like that!
REMEMBER,
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
Dual Battery Tray Hogwild Jeep CJ Forum 6 07-13-2011 06:00 AM
CJ7 Battery Tray... Battery Mount Rupie25 Jeep CJ Forum 7 12-20-2009 10:19 AM
Dual Battery Tray: Write up jatepper Jeep CJ Forum 12 09-14-2009 02:43 PM
Dual Battery Tray for CJ...Preferences? KSToyz Jeep CJ Forum 1 10-08-2007 02:33 PM
dual battery tray a84jeepCJ7 Jeep CJ Forum 5 05-06-2006 11:13 AM
