home made case spreader - Page 2 - JeepForum.com
post #16 of 28 Old 07-12-2011, 07:37 PM
foggybottombob
Originally Posted by lucdog View Post
I've never needed a spreader to remove a carrier. On installing, I use a plastic dead blow. I thought it might help to install the carrier, with the spreader. Especially with the preload and thin shims.
From what I remember reading somewhere, is it a fact, you can't have enough carrier bearing preload?
Bill
You can have too little or too much carrier bearing preload.
foggybottombob is offline
post #17 of 28 Old 07-12-2011, 08:45 PM
VACJ7
VACJ7's Avatar
I made a crude one when working on my AMC 20 but only used it once. It worked well but found I really did not need it and pry bar removed carrier easily and plastic deadblow to put it back.
VACJ7 is offline
post #18 of 28 Old 07-13-2011, 06:17 AM Thread Starter
BioTex
1979 CJ7
With so many guys saying I won't need the tool, I've decided to do the job without. Thanks to all for helping. I'm starting to get comfortable with the idea of swapping the gear set. Waiting for the master set to arrive.
Currently:
79 CJ7 "CJ Express" 4.2L, NV4500, D44 rear
69 800 with SBC, SM465, NP205, 14BT
BioTex is offline
post #19 of 28 Old 07-13-2011, 07:57 AM
CSP
With a D44 the shims are under the bearings, so you aren't going to damage them installing the carrier assembly.
I can see a spreader coming in handy on an AMC 20 or Ford 8.8, where the shims sit outside of the bearings.
CSP is offline
post #20 of 28 Old 07-13-2011, 12:26 PM
80cj
80cj's Avatar
1980 CJ5
Originally Posted by BioTex View Post
A machinist friend suggested I make one is why I ask. He said as many times as you add/remove shims, that it is not worth it to no have one handy. He mentioned .001" when spreading.
I suppose i could try to do the job without one, then I can make one if it proves too hard. I mean, I know I can force things, but don't want to damage anything either. I like having good tools...
You don't have to struggle with removing the case during your setup process. There is no need to preload the carrier bearings until you get to your final setup. During yor setup process, just set your diff carrier endplay at "zero". When everything looks good, then go ahead a preload the carrier bearings.
80cj is offline
post #21 of 28 Old 07-13-2011, 02:05 PM Thread Starter
BioTex
1979 CJ7
Good to know! Thanks for the tip.
Currently:
BioTex is offline
post #22 of 28 Old 07-13-2011, 05:34 PM
agear
let me know if you still need those measurements
1984 jeep cj7, 258 I6, rebuilt T176,rebuilt Dana 300, amc 20 , dana 30, 4.10's Trac-lok in rear , 4.10's detroit soft locker in dana 30, 2.5 inch bds suspension lift, 1 inch polyurethan body mount lift. Line ex. weber carburetor. factory tach. factory clock ,oem replacement speedomter cluster, and oil pressure gauge, factory volt gauge.
agear is offline
post #23 of 28 Old 07-13-2011, 06:40 PM
keith460
Jeep. There's Only One
keith460's Avatar
Kieth460:
I would have been nervous to use the cover bolt holes, but obviously they work. What kind of a force would you estimate it takes to spread 1 mm?
Are we talking no big deal, or it was a lot, and nearly bent my home made tool?
Hardly any force, just enough to get the carrier in and out while swapping in shims. I used grade 8 bolts where it bolted to the pumpkin cover so they would not fatigue as much.
1984 CJ-7 Renegade
keith460 is offline
post #24 of 28 Old 07-13-2011, 11:00 PM
80cj
80cj's Avatar
1980 CJ5
On both AMC 20 and Ford 8.8, if you use the thick OEM style shims, it is easy to drive them ibetween the bearing cup and housing with a plastic mallet. Just got done doing an 8.8 which gets preloaded .012. No problems
80cj is offline
post #25 of 28 Old 04-16-2013, 11:17 AM
KenK01
Having pulled/installed several carriers/ring/pinon sets in Dana 44s, I've never needed a case spreader.
Unless you're looking for something to do I wouldn't build one unless you get to the install and just can't get the carrier back in.
Stubborn carriers are easy to remove by stuffing a shop rag between the ring/pinion teeth and turning the pinion. No banging/prying necessary.
I can't believe how easily this method worked and thank you very much. after looking for spreaders and trying everything I knew trying to get the gear set out of very stubborn dana 44 , put the shop rag in there and it popped right out. highly suggest this method... doesn't hurt a thing and really works!
KenK01 is offline
post #26 of 28 Old 04-16-2013, 07:15 PM
86cj74.2L
86cj74.2L's Avatar
If you have a open diff a crowbar through the center section to keep it from spinning works good as well. I did that on the Dana 60 front axil of my cummins to change oil seals.
86cj74.2L is offline
post #27 of 28 Old 04-16-2013, 07:35 PM
CSP
That crowbar method sounds better. I just pulled the carrier out of the D60 going under my pickup and I had to insert the rag several times. It took a lot to get that carrier out and it chewed the rag to pieces. Oddly enough it went back in really easy after the new axleshaft seals were installed.
CSP is offline
post #28 of 28 Old 04-16-2013, 09:01 PM
86cj74.2L
86cj74.2L's Avatar
Heavy bugger ain't it?
No wonder my truck weighs 6300lbs.
I killed the drivers side seal by my own stupidity. I never cleaned the crud out of the tube, as well as coating the splines with grease to catch the dirt so the seal can wipe it clean.
I now have a dowel rod with half a soup can lid nailed to it to scrape out the junk. And the miller seal driver tool.
My home made snorkel chris78cj7 Jeep CJ Forum 21 03-13-2011 11:41 AM
home made flares can I see yours? jakemary Jeep CJ Forum 1 12-22-2008 06:39 PM
home made snorkel questions jeepnut00 Jeep CJ Forum 10 02-02-2007 09:47 AM
Home-made Snorkel BigMike20 Jeep CJ Forum 4 11-27-2004 01:52 PM
Let me see your home made bumpers Jeep Daddy Jeep CJ Forum 6 10-24-2004 03:19 PM
