home made case spreader - JeepForum.com
post #1 of 28 Old 07-12-2011, 11:30 AM Thread Starter
BioTex
1979 CJ7
As some of you know, I'll be swapping gears in a pair of D44's.
I'm thinking I want to make a case spreader similar to this one, but hate to reinvent the wheel. Has anyone already made one that works well?
Any dimensions you care to share? Any do's or don'ts?
Currently:
79 CJ7 "CJ Express" 4.2L, NV4500, D44 rear
69 800 with SBC, SM465, NP205, 14BT
BioTex is offline
post #2 of 28 Old 07-12-2011, 11:53 AM
Cutlass327
Cutlass327's Avatar
1978 CJ5
There's not much you can do to change that design for "reinventing the wheel". Just make sure you use a dial indicator to prevent over-spreading the case beyond it returning back. I forget the specs for that..
Rick
Cutlass327 is offline
post #3 of 28 Old 07-12-2011, 11:57 AM
CSP
Having pulled/installed several carriers/ring/pinon sets in Dana 44s, I've never needed a case spreader.
Unless you're looking for something to do I wouldn't build one unless you get to the install and just can't get the carrier back in.
Stubborn carriers are easy to remove by stuffing a shop rag between the ring/pinion teeth and turning the pinion. No banging/prying necessary.
CSP is offline
post #4 of 28 Old 07-12-2011, 12:43 PM
agear
I have one I bought I can give you the dimensions on. If necessary. I bought it but I did not need it on my amc 20. I thought I had the carrier cocked in there when I put the carrier in the housing but I bet if I would have persisted in trying to pry it out , trying different positions with the crow bar all day long and maybe even longer I would have got it out. The rag method sounds interesting. Also you can use a small piece of wood as a fulcrum on the bottom of the housing and long crow bar or pry bar or whatever it's called about three feet long or so and press down and the pry bar should pry the carrier toward you and probably up some.
1984 jeep cj7, 258 I6, rebuilt T176,rebuilt Dana 300, amc 20 , dana 30, 4.10's Trac-lok in rear , 4.10's detroit soft locker in dana 30, 2.5 inch bds suspension lift, 1 inch polyurethan body mount lift. Line ex. weber carburetor. factory tach. factory clock ,oem replacement speedomter cluster, and oil pressure gauge, factory volt gauge.
agear is offline
post #5 of 28 Old 07-12-2011, 01:31 PM Thread Starter
BioTex
1979 CJ7
A machinist friend suggested I make one is why I ask. He said as many times as you add/remove shims, that it is not worth it to no have one handy. He mentioned .001" when spreading.
I suppose i could try to do the job without one, then I can make one if it proves too hard. I mean, I know I can force things, but don't want to damage anything either. I like having good tools...
Currently:
BioTex is offline
post #6 of 28 Old 07-12-2011, 02:04 PM
keith460
Jeep. There's Only One
keith460's Avatar
I made one a couple of years ago that served its purpose. Two pieces of curved steel we had laying around at work bolted to the pumpkin and a simple all-thread nut or coupler nut that had a set screw in one end that allowed the smaller threaded rod stay stationary while the other threaded rod pushed on the housing to open it by about 1mm. That is all that is needed to install and remove shims as you do not want to deform the housing.
1984 CJ-7 Renegade
keith460 is offline
post #7 of 28 Old 07-12-2011, 03:03 PM Thread Starter
BioTex
1979 CJ7
I would love the dimensions if you don't mind. I may make one since this won't be the last time I set up an axle.
Currently:
BioTex is offline
post #8 of 28 Old 07-12-2011, 03:06 PM Thread Starter
BioTex
1979 CJ7
Kieth460:
I would have been nervous to use the cover bolt holes, but obviously they work. What kind of a force would you estimate it takes to spread 1 mm?
Are we talking no big deal, or it was a lot, and nearly bent my home made tool?
Currently:
BioTex is offline
post #9 of 28 Old 07-12-2011, 03:29 PM
agear
Okay, working on it.
agear is offline
post #10 of 28 Old 07-12-2011, 04:31 PM
agear
agear is offline
post #11 of 28 Old 07-12-2011, 04:37 PM Thread Starter
BioTex
1979 CJ7
I found a HF 12 ton press today at a garage sale. so I bought it. I know it is marginal, and need a 20 ton, but for the price I couldn't pass it up.
Is there a crush sleeve on the D44?
The cool thing I found was an I-beam 14' long. Perfect for my shop trolly hoist I've been wanting. Might have to install it before I tackle the rear axle. Shure will save me a lot of free beers!
Currently:
BioTex is offline
post #12 of 28 Old 07-12-2011, 04:39 PM Thread Starter
BioTex
1979 CJ7
Got measurements? Looks like I could build that easy enough.
Currently:
BioTex is offline
post #13 of 28 Old 07-12-2011, 04:44 PM
agear
The solid pieces are the sides and are 1 3/16" thick , 2inches wide. The bottom and top pieces are made out of 5 /16" thick steel. The blocks sandwich and welded in between the bottom and top pieces are 1 5/16" and 2 inches long. Are you gonna be able to make this................. ? Cuz I got a lot of measurements....
agear is offline
post #14 of 28 Old 07-12-2011, 04:56 PM
foggybottombob
The D44 does not use a crush sleeve except for the Isuzu Rodeo/Honda Passport version. Other Dana 44 housings use pinion preload shims. There are at least a couple of ways to deal with the pinion preload while you setup the gears.
I've setup at least a dozen Dana axles and have never used a case spreader. The only problem I have ever had from not having a spreader is that you can get the total amount of carrier shims too high (this can happen if you use the same shims you had and put in new carrier bearings). If you get too much total carrier shim then it can shave metal off the sides of the tubes to the outside of where the carrier bearings seat. These little pieces of metal can get under the carrier bearing races and give you wrong readings.
Getting the carrier out is one issue. I use two pry bars and something like folded up denim to pad the housing faces. Putting the carrier back in is another issue. I have a big semi hard plastic hammer to re-seat the carrier after changing carrier shims.
One thing you absolutely want are carrier setup bearings. You can make them if you need to.
foggybottombob is offline
post #15 of 28 Old 07-12-2011, 05:41 PM
lucdog
lucdog's Avatar
1980 CJ5
I've never needed a spreader to remove a carrier. On installing, I use a plastic dead blow. I thought it might help to install the carrier, with the spreader. Especially with the preload and thin shims.
From what I remember reading somewhere, is it a fact, you can't have enough carrier bearing preload?
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
My home made snorkel chris78cj7 Jeep CJ Forum 21 03-13-2011 11:41 AM
home made flares can I see yours? jakemary Jeep CJ Forum 1 12-22-2008 06:39 PM
home made snorkel questions jeepnut00 Jeep CJ Forum 10 02-02-2007 09:47 AM
Home-made Snorkel BigMike20 Jeep CJ Forum 4 11-27-2004 01:52 PM
Let me see your home made bumpers Jeep Daddy Jeep CJ Forum 6 10-24-2004 03:19 PM
