#1 | |
Home garage air compressor help
Sorry this is not directly related to my Cj build but it does play a large part. I need a little help on my air compressor purchase. These are in my budget but I can not decide which is better. Seems that the Husky Pro has better reviews. Any help is appreciated.
http://www.sears.com/shc/s/p_10153_12605_00916762000P?mv=rr or Husky 2.0 Running HP 30 Gallon Vertical Compressor - VT6315 at The Home Depot
1984 CJ8 Scrambler, 258, MC2100, daystar 1", 4" Skyjacker Soft Ride, 31X10.5 on stock wheels, raptor lined. |
#2 |
4Wheelin' dreamin
I have the 33 gal Craftsman, and it's great, not too loud, the only time I've had a problem with it is when I was using my cut-off tool, for everything else it's perfect.
#3 |
I have a 5hp100 gal tank, but i also have a Dewalt 30 gal 110 compressor that use a lot because it's portable, it's direct drive and oil less, 200 psi, built in regulator, fairly quite, and decent recovery. I think I paid 300-350 a couple of years ago, but it was the only one of that size that would keep up with my framing nailer
Dave
Wrongway My fleet: 86 CJ7 5.7 vortec. 4L60,D44's,OBA,Air tank bumpers w/D rings detroits,4.88,35" bfg, mt's 9500ti warn 86 CJ7 2.5 detroits, OBA 4.56, air tank bumpers, w/D rings,9500I warn 31x10.5x15, Trxus 86 CJ7 bone stock, w/factory 44 never seen the dirt soon to be for sale 87 Wrangler also never seen the dirt. |
#4 |
Whatever you do don't buy an oil less compressor. Save a little extra and get this one, Campbell Hausfeld 60 Gallon Cast Iron Air Compressor - 3310006 | Tractor Supply Company
2003 Rubicon 3" Zone lift, 1.25 body lift, 1" MML, 33" MTZs |
#5 |
I've been very happy with my Husky, had it for about 7 years and it gets used almost every day.. It's plugged into a 20amp panel and it will trip the breaker once in a while on start up when its really cold in the shop.. I need to convert it to 240v, it is a dual voltage motor which is pretty handy..
"The arrogance of officialdom should be tempered and controlled, and assistance to foreign hands should be curtailed, lest Rome fall." - Cicero - 55 BC |
#6 |
What is perferred, oiled or oiless motor and does the difference between the HP on the motors (2HP vs 1.6HP) mean much.
#7 |
I need the compressor to be portable so the 60 gallon is probably not an option and I do not have a 220 outlet in my garage. Husky actually has a 60 gallon 220v for $399.00 like the Campbell Hausfeld compressor. When I googled air compressor reviews I found that the Husky is actually made buy Campbell Hausfeld but sold at home depot under the Husky Pro name.
#8 |
I just went through this myself. You really need to decide what you want the compressor to do , then purchase accordingly. Don't skimp on this tool. I was lucky enough to be able to over purchase and went for a 5 hp 80 gal Ingersol Rand. It's done everything from air gun to cut off wheel to D/A sander with out a single problem. I too have heard not to go with the oilless, but I don't remember why. So If those two were my only options, I'd take the Huskey.
FYI, Wiring a 220 outlet isn't that bad of a job. |
#9 |
I think I could handle wiring a 220 outlet, but portability is a big issue. This is the other option if I go with the 220v. it is only $20 more than the 30 gallon 110v in the store. I wonder if I could put some wheels on it?
http://www.homedepot.com/Tools-Hardware-Air-Compressors-Tools-Accessories-Stationary-Compressors/h_d1/N-5yc1vZ1xr5Zbb2r/R-100083906/h_d2/ProductDisplay?langId=-1&storeId=10051&catalogId=10053
1984 CJ8 Scrambler, 258, MC2100, daystar 1", 4" Skyjacker Soft Ride, 31X10.5 on stock wheels, raptor lined. Last edited by littleturner76; 03-09-2010 at 09:47 PM.. Reason: post link |
#10 |
Muddin Maniac
I agree with of the the 2 choices, I would go with the Husky
United States of America
Born: July 4, 1776 Died: Nov 4, 2008 SUICIDE |
#11 |
Ok, I see that the forum has spoke :+). I will rethink this...... but my choices are now the 30 gallon husky or the 60 gallon 220v. I am trying to keep the price below $400.00 so it will be tight.
#12 |
#13 | |
Muddin Maniac
Granted it not portable but with 100 ft of hose it will reach any where in my yard I need to take it
#14 | |
Way out of my reach $$$$$$.
#15 |
Most problems with the oil less style compressors are that THEY ARE NOISEY. GAWD AWFUL NOISEY. As in WHAM, WHAM, WHAM... NOISEY. I know that the Craftsman one I bought (and is now in my son's garage) is LOUD.
As was replied, you really need to determine the biggest air hog tool that you will be using on a continuous basis. Impacts, air nailers, etc. don't use a bunch of air. So oil less compressors will work fine. Grinders, cutoff wheels, sanders, polishers, .etc use a bunch of air. So you need to go BIG, or put up with the 'work/wait, work/wait' routine as the compressor tries to keep up. Sandblasters will use everything you've got and more. I've got a 7.5 hp 24cfm @ 90psi, 80gal IR: ![]() My sandblast cabinet will cause it to cycle continuously: ![]() IMO, you can go two ways: Inexpensive and live with the limitations. Or spend the money, and upgrade to a 5+ hp, 60-80 gal tank, 220v unit, and never have to upgrade again. Trust me, mine is going on the truck with me if/when I ever move. At the very least (110v), I would recommend something along this line: FREE SHIPPING — Ingersoll Rand Garage Mate — 2 HP, 5.5 CFM, Model# P1.5IU-A9 | 2 - 9 CFM | Northern Tool + Equipment This style is available from a variety of mfg's.
"In the end...It's all Hack." |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
