holley truck avenger - JeepForum.com
post #1 of 7 Old 04-12-2008, 04:33 PM Thread Starter
petey156
1977 CJ5
So I bought a brand new holley 670 Truck avenger,
I runs good but...
when i start a cold engine should it rev to around 1200 for a minute or so and then settle to 650?
I think that it should, but it I have to keep it runnung, by pumping the accelerator.
Its on a ford 351W with a t-176 . the choke wire is a iggnition controlled 12 volts.
what is out of adjustment? how do i fix it? I think it has to do with the high idle, and the and the choke, but i am not sure what to do with that.
thanks!!
petey156 is offline
post #2 of 7 Old 04-12-2008, 07:56 PM
jayhawkclint
jayhawkclint's Avatar
1970 CJ5
Sounds like it to me, here's the manual:
http://www.holley.com/data/Products/...99R10268-4.pdf
My '70 CJ5 Build Thread:
jayhawkclint is offline
post #3 of 7 Old 04-13-2008, 12:19 PM
mud4me
I have the same carb.
It sounds to me like you have a stuck float in one of the two bowls.
If that's the case, you can try to tap on the bowls lightly with a wrench and hopefully it'll become un-stuck.
Or you'll have to remove the bowls and do a visual inspection and correct. Even though your carb is brand new, I find it best to have some new bowl gaskets on hand, as they sometimes tear when the bowl is pulled off the carb. And when you remove the bowls you need to be very careful that the needles are re-installed correctly.
86 CJ-7, 360, Holley Avenger, T-18, Dana 20, 4" suspension,
mud4me is offline
post #4 of 7 Old 04-13-2008, 03:52 PM
jayhawkclint
1970 CJ5
Stuck float seems less likely to me on these carbs, possible I guess, but not likely. Remember, externally adjustable floats are one of the major benefits of this carb, so no need to take the bowls off; just remove the sight plugs and see where the fuel level sits.
I guess I forgot to ask the obvious first, but did you turn the idle stop up? It's the screw on the throttle linkage side of the carb.
post #5 of 7 Old 04-13-2008, 06:25 PM Thread Starter
petey156
1977 CJ5
i set the idle to 650 when everything was warm, by adjusting the idol stop on the linkage side. was that wrong..
petey156 is offline
post #6 of 7 Old 04-13-2008, 08:03 PM
mud4me
When my carb was new - the front float stuck and a simple tapping the bowl with a wrench fixed it.
mud4me is offline
post #7 of 7 Old 04-15-2008, 07:18 PM
alpinedog
The choke on mine works perfect if I don't gun it while initial fire up. So if you have the electric choke, take off the air cleaner, have someone pump it once while cold, turn the key, and you verify if the choke is working right. If not, the choke is stuck and just needs to be cleaned or oiled.
alpinedog is offline
Holley Truck Avenger vs EFI or TBI A-Teamer Jeep CJ Forum 10 12-01-2006 08:13 PM
holley truck avenger rcgkaw Jeep CJ Forum 7 11-01-2006 06:43 AM
Holley Truck Avenger YJ_Aaron Jeep CJ Forum 24 10-06-2006 09:15 AM
Holley Truck Avenger 470 Cfm? 77 renegade Jeep CJ Forum 4 02-20-2005 09:41 PM
Holley Truck Avenger? BillR Jeep CJ Forum 3 07-13-2002 12:00 AM
