Holley carb-- is this too much? - JeepForum.com
post #1 of 6 Old 01-17-2010, 06:00 PM Thread Starter
way_of_life
1978 CJ7
Someody just gave me a lightly used (perfect condition) Holley 80555 (650 cfm). Is it way too big for a 304? I don't have any crazy engine mods or anything that would require tons of cfm but using a free carb is better than buying a new one and having a carb collection
-- I am aware that this wasn't made for the edelbrock r4b intake manifold- I'll get an adapter if I decide to use the carb
Here's what Holley says about it--
•Vacuum secondaries allow use on wide variety of vehicles
•Electric choke
•Single feed fuel inlet
•Q-Jet Replacement, spread bore bolt pattern
•Vacuum for: PCV,EGR, power brakes, distributor,air cleaner & canister
•Performance upgrade for stock to mildly modified vehicles
•Universal calibration for easy bolt-on performance
Holley Performance Products 650 CFM Four Barrel Street Carburetor*0-80555C
°lllllll°
way_of_life is offline
post #2 of 6 Old 01-17-2010, 07:31 PM
Military Jeeper
1979 CJ5
For a 304, they recommend the 470 cfm..............some run the larger, but most run the 470. Do a search on Holley Avenger, and you'll see what I'm talking about. I just searched the other day and based on the searching I got the 470 cfm.
JeepForum.com - Search Results
Jason "MJ" - 79 CJ-5 | SOA/HI-STEER | 304/T18A/D20 w/3:1 TeraLow | Holley Avenger Carb | Edelbrock Performer Intake Manifold | DUI Distributor | K&N Filter | Centerforce 2 Clutch | Waggy D44's | 4.11's | ARB's | Hydroboost | HAD Shafts | 35 Toyo MT's|
Military Jeeper is offline
post #3 of 6 Old 01-17-2010, 08:21 PM
texasimport
1978 CJ5
On a bone stock a 650 might tiny bit big, but you could sure tune it for that motor.
Talk to Ricky, I think that was his name, at Holley tech support and he will tell you that the Holley web page is in error. As stated on the 470TA box, if you read all the small print, it is designed for use on a 258CI straight six.
That said still I bet there are lots of guys here that are very happy with a 470TA on a 304. Nice thing about a Holley, you can adjust it all day long.
78 304-CJ5
texasimport is offline
post #4 of 6 Old 01-17-2010, 09:21 PM
TKFireman
1980 CJ7
I have a Holley 670TA on my bone stock 304. Came with it when I bought the jeep. Runs pretty good, took a little tuning and I get around 10 mpg with it, but works well. I changed the power valve and that seems to help a lot, think I need to re-jet it to a smaller size to dial it in further
"If your gonna be dumb, you gotta be tough"
TKFireman is offline
post #5 of 6 Old 01-18-2010, 09:35 AM
texasimport
1978 CJ5
TKFireman. . . .Do you happen to know a few more details about your carb set up. I just got my 304 back from the machine shop, full rebuild, balanced, torquer cam, performer intake, shorties, 40 over.
On your accelerator pump stuff, what size squirt nozzle you using, what accel pump cam and what color secondary spring. I live bit higher than you so my main jets will be different.
Your input will give me some rough ideas if mine is close or not.
78 304-CJ5
post #6 of 6 Old 01-18-2010, 09:38 AM
TKFireman
1980 CJ7
Everything is stock right now, except for the power valve, don't know anything about the rest of the parts, got to do more reading, pm me so we don't hijack this thread
Holley 470 Carb on 258 Bear-Olemiss Jeep CJ Forum 2 04-20-2009 05:32 AM
Holley carb Q BaliJeeper Jeep CJ Forum 5 04-14-2009 12:11 PM
holley Carb ID petey156 Jeep CJ Forum 4 08-04-2008 01:12 PM
Holley Carb? green cj 78 Jeep CJ Forum 1 07-27-2005 11:01 PM
Holley 670 carb on a 304 ecstrate Jeep CJ Forum 5 05-03-2004 11:28 PM
