Holley carb - Need air filter but clearance issues with brake booster - JeepForum.com
post #1 of 6 Old 04-06-2013, 02:43 PM Thread Starter
Jeeprage
Jeeprage's Avatar
Previous owner had a Holley carb installed (and from my brief start up, runs well) but it won't clear the brake booster with filter installed. I don't know what he was running for brakes since I bought the Jeep in pieces, but the air filter won't fit.
Holley measures 5" opening for a filter but I'm not finding anything online. What are you guys using for Holley (or Motorcraft 2100 - I think I read similar dimensions) carbs with boosted brakes? I don't have a stock intake available.
2015 JKU - 6m
Jeeprage is offline
post #2 of 6 Old 04-06-2013, 02:48 PM
Caish
1987 XJ Cherokee
Time to get a smaller diameter universal air-filter.
Just tell the parts store you need it for a Ford/Holley.
Join us on Jeeperz Creeperz on Google+
Facebook: Arkansas Jeeps
Caish is offline
post #3 of 6 Old 04-06-2013, 02:50 PM Thread Starter
Jeeprage
Jeeprage's Avatar
Do I need to run a vent line into the air cleaner housing? I'm assuming I can use a small standalone filter in place from the valve cover?
2015 JKU - 6m
Jeeprage is offline
post #4 of 6 Old 04-06-2013, 03:08 PM
Caish
1987 XJ Cherokee
Most aftermarket airfilter lowers had a boss stamped into it so you can drill it and plumb your crankcase to the bottom of the air filter.
If your not smog checking I wouldn't worry about it and just get a small filter that plugs into the bung on the valve cover.
Caish is offline
post #5 of 6 Old 04-07-2013, 07:16 AM Thread Starter
Jeeprage
Jeeprage's Avatar
Thanks. Picked up a small Spectre last night at Autozone that seems to be doing the trick. I'll have to run a separate filter for engine valve cover.
Mass does have emissions, but testing is out for something this old. There still may be visual, but I'm not as worried.
2015 JKU - 6m
Jeeprage is offline
post #6 of 6 Old 04-07-2013, 02:14 PM
CJ258
1974 CJ5
Just Googled offset aircleaner and this is on of the hits. http://www.streetsideauto.com/p/tran...FYFxQgodknMATQ
CJ258 is offline
