Holes in CJ7 body - JeepForum.com
post #1 of 13 Old 01-29-2014, 09:07 PM Thread Starter
Plastixrecycler
Holes in CJ7 body
So I removed all the diamond plating from my 1985 CJ7 and uncovered numerous holes in the body. Not only did the PO drill through the diamond plating, into the body, but there are also a bunch of random bolts "badazzled" throughout the body. I want to get these repaired the right way, not using bondo. Does anyone else have experience with repairing holes in their body? What's the estimated cost to get them professionally repaired?
There's really no rust on the Jeep, here are some pics of a few of the holes. Some of the holes may look rusty but its just dirt.
Plastixrecycler is offline
post #2 of 13 Old 01-29-2014, 09:27 PM
SouthernGypsy
De Oppresso Liber
SouthernGypsy's Avatar
Around here my welder would do up a body like that for about $250 and it's ground smooth when he's done, all you need is a little scratch filler. Different areas have different prices and also depends on how well ya know the guy.
~ SouthernGypsy's Jeeps ~
2004 Jeep TJ Rubicon 4.0L/Automatic
1983 Jeep CJ-7 Limited 4.2L/5 Speed
SouthernGypsy is offline
post #3 of 13 Old 01-29-2014, 10:22 PM
BagusJeep
1981 CJ7
Small holes in sound metal can be plug welded fairly easily. If they are small not a lot of heat will be used and the surface will remain flat.
Larger holes may cause more problems. I like to put a patch on the back and tack weld it on from the front and then fill.
I have had some success in the past with welding in flush new sheet metal patches to much larger holes but the heat can distort the thin panels.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #4 of 13 Old 01-29-2014, 10:38 PM
nixer600
Buy you a welder and get her done! The welder will pay for itself quickly
/\ Yeah, what he said. /\
nixer600 is offline
post #5 of 13 Old 01-29-2014, 11:29 PM
only in a jeep cj
An experienced welder will know now to fill those or patch any larger ones without warping it. Either way, a light application of a flapper disc or the like will need to bring it smooth. A thin skim will be needed and blended out. If not, the shinny black paint will highlight the repair areas with wavy light reflections. Its that body work and the paint work that will drive the cost up.
I would leave them for now. Then practice some on a scrap piece (of the same gauge) and do the work right before the whole Jeep gets painted IF or when....or your be driving around with sections of the decals missing and large patch areas of primer.
Ed
1975 CJ-6 1983 CJ-8
1986 CJ-7 Laredo 1986 TJ-7 Trail Jeep
2003 Inca Gold TJ Rubicon
only in a jeep cj is online now
post #6 of 13 Old 01-30-2014, 01:35 PM
30YR_MCPO
1978 CJ5
Yeah 250 or so, depending on what else needs to be pulled out/covered up from splatter. Good Luck!
30YR_MCPO is offline
post #7 of 13 Old 01-30-2014, 02:48 PM
Renegade82
1982 CJ7
Clamp a piece of copper to the backside and plug weld it in increments from the front. Flap disk it flat and paint.
The end of a defining era.... JEEP R.I.P. 1941-1986
My frame off Re-Build: (the 4 year saga....)
Renegade82 is offline
post #8 of 13 Old 01-30-2014, 07:29 PM Thread Starter
Plastixrecycler
Thank you for all the replies! These are all really helpful, I'll probably end up welding them myself like Renegade and Only in a CJ suggested. Thanks for the input.
post #9 of 13 Old 01-31-2014, 08:14 AM
CSP
Flat washers make better filler for larger holes that filling the entire hole with weld.
CSP is offline
post #10 of 13 Old 01-31-2014, 10:16 AM
wm69
What about pin holes in a floor pan? My "rust-free" CJ sat up for a couple years, and when I pulled the rubber floor mats I had some nice rust in the passenger floor. Still solid, but has pin holes. Can these be welded up and smoothed over (after sandblasting or phospho bath to eliminate all the rust) or do I need to cut the whole panel out and weld a new one in? Given that they're only pin holes I would LIKE to go with the less drastic of the two.
Hope this isn't too much of a hijack. I have some "extra" holes that need to be welded up as well, and was going to do it all at once.
wm69 is offline
post #11 of 13 Old 01-31-2014, 10:45 AM
Renegade82
1982 CJ7
The thing about pinholes is that they are just the edge of thin metal and what will eventually be a larger hole. Take a pick and poke at the hole. It will make it bigger and reveal more thin rusting metal, but better now than shortly after repairing it. And if your welding it you need to get to thicker good metal anyways or it will just keep burning thru and making a mess. It's usually best to just cut a larger square hole out, encompassing several pinholes, so you know your back to good metal and a square patch is easier to weld back in.
post #12 of 13 Old 01-31-2014, 10:51 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Originally Posted by wm69
What about pin holes in a floor pan? My "rust-free" CJ sat up for a couple years, and when I pulled the rubber floor mats I had some nice rust in the passenger floor. Still solid, but has pin holes. Can these be welded up and smoothed over (after sandblasting or phospho bath to eliminate all the rust) or do I need to cut the whole panel out and weld a new one in? Given that they're only pin holes I would LIKE to go with the less drastic of the two. Hope this isn't too much of a hijack. I have some "extra" holes that need to be welded up as well, and was going to do it all at once.
You'll probably find that those pin holes will turn into thumb-sized holes once you start grinding off the rust. I hope I'm wrong.
In any event, try to remove as much of the rust as possible, then hit it with a acid-based rust neutralizer before welding and refinishing.
Good luck
Matt
Matt1981CJ7 is offline
post #13 of 13 Old 01-31-2014, 11:09 AM
jhughes2013
1977 CJ7
haha, I have bigger holes than that that the PO tried to bondo. The bondo fell out and now they're speed holes...
'77 CJ7, LS1, NV4500/D300, Ford 8.8, 4" of lift, 33x12.50 BFG ATs...
jhughes2013 is offline
