Hole in firewall where a/c lines were - JeepForum.com
post #1 of 3 Old 11-16-2011, 02:17 PM Thread Starter
stingercub2
1983 CJ7
Does anyone have any good ideas on how to plug the Hole left behind in the firewall after the A/C lines were removed. I filled the rubber boot with silicone for know but I sure would love a solid rubber boot or maybe a good homemade solution.
stingercub2 is offline
post #2 of 3 Old 11-16-2011, 03:10 PM
baldfatdad
1984 CJ8
I actually found a rubber piece that fit there from a junk yard jeep. Other that that you could take a piece of sheet metal, caulk it and screw in on from the engine side.
baldfatdad is offline
post #3 of 3 Old 11-16-2011, 03:19 PM
keith460
Jeep. There's Only One
keith460's Avatar
Jeep CJ's without A/C had a oval shaped flat plate to cover the firewall opening that was sealed to the tub with Body Sealant.
I'll check to see if I have a picture of it.
1984 CJ-7 Renegade
keith460 is offline
1995 Wrangler YJ Tub Swap, firewall hole question certifiablejeep Jeep CJ Forum 6 03-30-2009 09:20 AM
Weber 34 conv, nutter, Vacuum lines / Fuel lines valkadesh Jeep CJ Forum 29 06-11-2007 09:21 AM
CJ clutch lever hole in firewall location?! nickv Jeep CJ Forum 8 05-29-2007 10:05 PM
Running auto trans lines...use braided or hard lines? Pacfanweb Jeep CJ Forum 7 08-15-2006 10:07 PM
brake lines, gas lines, which order certifiablejeep Jeep CJ Forum 6 06-30-2003 04:03 AM
