high pressure fuel pump for injected engine conversion
#31 | ||
The WJ filter is the regulator as well, and my understanding is that it does have a check valve.
______________________________________ In Process: 2002 4.0L and NV3550 Swap |
#32 |
Off Road Forever
Location: Off the Grid in Chester Grant, Nova Scotia, Canada
Similar to the CJ filter then. It is also a regulator with a metered hole for the return line, but it has no check valve.
Mike 86/00 CJ7 Laredo, 33x9.5 BFG AT's, 'glass nose to tail in '00, 'New' frame,wires and plumbing in '09. Carter BBD Carbed 4.0 HO in '10. Some Canadian Bush Jeep Runs and Build Photos: http://mikeromainjeeptrips.shutterfly.com (10 new albums added Sept 16/10) |
#33 |
have been reading your posts. My dad put EfI on his 76 cj-5 and put a ford external pump on it. Living in IL he ahd no problems but whenwe went out to colorado he had problems with the external being able to pump the fuel. Ford must have also had the same problems with just their external set-up because they started offering their "high altitude" version which included an in-tank pump, along with the external. If you don't plan on going to high altitudes you may never see a problem, but it mightbe something to look into. We proceeded to put in-tank pumps in and haven't had any issues.
82scrambler 258 /W EFI twinsticked 300 4.56s locked front and rear |
#34 |
What tank and In tank pump are you using? Did you retro fit the Stock tank?
Also, Can you use the external pumps with AN fitting or are the push fitting OK? |
#35 |
Anyone? I need to get my CJ up an going again..
#36 |
It wasn't clear who you were asking or what your reference was.
I'm using the stock tank that I cleaned with the e2182, g3, and wj filter.
#37 |
Ooops.. Sorry. Are you using Threaded connections? Thanks for the reply. I was actually asking the guy who did the in tank pump also.
#38 |
I am not planning on it. I have all the parts ready to go, just haven't put them together.
#39 | |
Jim |
#40 | |
Regulator or no?
Ok, just read your post. I'm setting up a 2003 4.3 VORTEC and haven't seen anything calling for a regulator. the stock vehicle the engine comes from doesn't have one. I just want to make sure I get this right!
#41 |
Can you use the E2000 or the others as an in tank pump as well?
I belive they are all pretty much the same but I want to make sure I do not blow myself up rigging a In tank pumpe setup with my Stock sending unit. |
#42 |
yamaguy what is or where did you get that fuse/relay holder that is mounted on the pass finder from?
#43 |
According to my Chiltons manual, my regulator is on the fuel rail of the engine. Mine is a 2003 5.3 Vortec and I just finished installing the new Airtec 8248 pump. I went with this pump after speaking to an Airtec factory rep on the phone. He told me that "only" the 8248 was designed to run as a stand alone apllication complete with check valve. Have yet to try to fire the engine up, hopefully this week.
#44 |
@mayo..
do you have some pics from the 5.3 swap? ![]() |
#45 | |
Fuel Starvation Issue 75 Wagoneer
I have a 1975 Wagoneer with a 360 V8. It used to have a 4bl carb but I converted to multi point EFI a few years ago. The system was supplied to me by CustomEfis. The system uses the E2182 EFI pump, the stock fuel tank and the stock 5/16 line to supply the pump. From the pump to the fuel rail I use a high presuure 3/8 hose and no filter. The pump is mounted on the inner side of the Jeep's frame (so no heat issue from the twin exhaust running down the outer side of the frame) and is a few inches from the front of the fuel tank. Fuel to the pump is supplied by atmosheric pressure through the 5/16 line from the back and over the top of the tank. There is a regular fuel filter before the pump's inlet. When the system is operating normally it works absolutely fine with no problems at all at a steady 40 PSI (I have a fuel pressure gauge mounted on the fuel rail). The problem I'm having is the following: From a cold start and after about 45 minutes driving the fuel pressure starts to drop and the engine finally stalls after a couple of minutes or so. I need to wait about 15 minutes before I can start up and drive away for the problem to recur in a little while. The problem has been noticed to be aggrevated by hot weather conditions (I live in Athens Greece). In the summer, and again from a cold start, the problem appears after about 15-20 minutes. I suspect the problem is fuel pump cavitation from heated fuel. I will try to install the pump in the tank (which should resolve the problem once and for all), but this may be practically very difficult to do on this vehicle. The alternative options I'm considering are: 1 - to open a 1/2 inch hole at the lowest point of the tank (which is at the back of the tank) and run a 1/2 inch line to supply the E2182. Keeping the tank always more than 1/4 full should give the pump sufficient and constant fuel availability for the pump to prime, even in hot weather conditions. 2 - The E2182 is rated 50 GPH which is way over what the system needs. So maybe installing the E8228 with a 38 GPH rating (and similar PSI rating) will reduce the amount of fuel being circulated between the engine and the tank per unit of time, and thus keep its tempreture lower. Also, I understand the E8228 has a 5/16 inlet which will eliminate the need to open a 1/2 inch hole in the tank. For either option above, if deemed viable, would installing a low pressure electric pump to supply the EFI pump help in any way? In any case I will take down the tank again and have it thoroughly cleaned. Worn tubing in the tank has already been replaced. I would highly appreciate your comments and any other suggestions you may have. Thanks. Manolis |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
